Wedge TR7 Engine Problem
johnrip
My 1980 TR7 engine was running great. The next morning it is sputtering, backfiring and bogging. My mechanic said that it was running on two cylinders, 3 and 4 were low compression. When he rechecked, compression was low on 2nd, but not 3 and 4. Any ideas???Could the carbs be washing out a cylinder?What would make compression change so? Do I need a new mechanic?
tdskip
I get several other opinions, but is doedn't sound right to me that the compression woudl suddenly change like that. Suggests the measurements were not done properly.
Generally speaking you want to start with the ignition systems first, then move to fuel.
Is she getting OK spark? Coil, points (assuming she has points and not an electronic ignition), and condensor all OK.
Fuel filter and pump OK?
Oil in the carb dashpot?
Dale
I probably can't add anything of value except to agree with what's been said. You might put some oil in each cylinder and check comp again. Might shed some light on the situation. If it was valves way out of adjustment they might improve if the engine was up to operating temp as it was when it last ran well. The suddeness with which it went funky makes me think it must be something simple like plug wires coming loose or moisture getting into something. The distributor cap clips on mine are a pain, and sometimes come adrift when I think they're secure. Dashpots are a definate check item as noted by tdskip. Do take care and thanks for letting me go on.
TR3driver
Great Pumpkin - R.I.P
I would sure want to have someone else check the compression (like yourself)! While what he reported is not impossible; his making a mistake is the most likely explanation, IMO. The only other explanation I can think of would involve multiple valves that decided to stick and then unstick.
ObiRichKanobi
I would start with the ignition too. Check all the wires, distributor cap and rotor, pull the plugs. If you have the Delco electronic ignition, pull the module and take it to Autozone and get it tested for free (put a good layer of thermal grease on it when reinstalling).
G
Maybe your mechanic isn't up to date on diagnosis. All he/she had to do was install an oscilloscope and low compression would show up as low KV demand for the affected cylinder. Also the scope tells all but a very few tales about what is happenning inside the engine. BTW, I'm an ASE Master, L-1 Advanced Engine Performance certified.... with 33 years under my belt. A lot of guys just do not have expensive diagnostic tools at their disposal.... but if you went to a professional, they should. It isn't very likely to be a mechanical issue unless you broke a rocker arm or such.
You must get back to basics... fuel and ignition must be exonerated first.
johnrip Wedge TR7 engine problem Triumph 6
mctriumph For Sale Tr7 engine Triumph Classifieds 0
T Wedge TR7 engine, need help identifying part. Triumph 5
A Wedge SU on TR7 Float Level Engine Angle Triumph 10
M Wedge TR7 Engine, transmission and more to go Triumph 0
B Wedge TR7 Engine Swap Triumph 12
johnrip Wedge tr7 engine idle low RPM bounce Triumph 3
johnrip Wedge TR7 engine Rebuild Triumph 2
M Wedge TR7 Won't Start When Engine is Warm... Triumph 4
YankeeTR Wedge Hmmmm...Engine problems with free TR7.. Triumph 18
1 Wedge TR7 and TR8 Engine difference Triumph 9
johnrip Wedge TR7 Engine Serial Number Triumph 2
S Wedge TR7 Engine Woes Triumph 11
J Wedge TR7 engine swap Triumph 17
Hegg Wedge TR7 Engine and Performance Triumph 33
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
O Wedge 79 TR7 no start Triumph 5
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
johnrip Wedge TR7 led light conversion question Triumph 1
S TR2/3/3A Tr7 and a little extra Triumph 2
P Wedge Florida TR7 Triumph 0
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
1 Wedge Which Parts to get from an '80/81 TR7? Triumph 1
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
johnrip Wedge TR7 carb seeping fuel Triumph 21
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
C For Sale TR7/8 Group 44 tribute race car for sale Triumph Classifieds 6
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
johnrip Wedge tr7 electric fuel pump Triumph 2
johnrip Wedge TR7 fuel pump Triumph 0
A Wedge Looking at a '80 TR7 ...... Triumph 4
TRopic6 For Sale TR7 Gearshift UKC 3248 Triumph Classifieds 0
Got_All_4 Wedge TR7 drive train torquing Triumph 2
GTP1960 Wedge "TR7 End of an Era" Hemmings article Triumph 11
