TR6 TR6 timing cover seal and gasket fix
hondo402000
I have read some post about replacing timing cover seal. I am currently fixing an oil leak, I thought was a timing cover seal but once I remove every thing it appears it is the timing cover gasket. If your planning on doing this repair here is what I went through so far.
remove carboard shield. remove radiator, unbolt steering rack, remove fan, remove harmonic balancer. pull off timing cover, seal was not bad but gasket was the problem of leaking oil, apply new gasket, install new seal why not if you have gone this far. make jig to hold timing tensior to reinstall timing cover, make sure you unbolt water pump it took me 1 hour to figure out the water pump is in the way when reinstalling the timing cover, drink a beer, cuss a lot, losen water pump, install timing cover, insert spacer with bevel out WRONG do it again, get it right this time, bevel toward engine,drink a beer again, well its not finished but i think the oil leak will end after the fix, but I am sure that was the protective coating that kept the frame from rotting. hopefully reverse everthing directions and it will run.
AltaKnight
Piece of Cake! /ubbthreads/images/graemlins/smile.gif
hondo402000
hondo402000
I got every thing back together this morning, sand blasted all the parts and painted them too, It stopped leaking oil, oooo but I have not cranked it yet
G
What does cranking it and leaking oil have to do with each other?
Bill
Brosky
I'm getting ready to start this project, but no one has mentioned anything about the sterring rack. Why did you unbolt it?
Bugeye58
[ QUOTE ]
Bill
[/ QUOTE ]
Bill, if he hasn't cranked it yet, there is no oil flying around inside the timing cover to proof test the fix.
Jeff
G
With the car on stands (wheels off ground), unbolting the rack and wiggling the unit forward will give you more room to work.
The wheels will just toe in a bit when you do this. It just bolts right back in place.
Bill
Brosky
Thanks Bill.. Just curious, Is it absolutely necessary or just a nice thing to do?
J TR6 tr6 timing cover removal Triumph 3
E TR6 TR6 Timing Cover Fasteners Triumph 7
E TR6 TR6 Timing Cover Seal Triumph 7
E TR6 TR6 Timing cover removal Triumph 10
A TR6 TR6 Timing cover miss-alignment???? Triumph 10
J TR6 73 TR6 Static Timing Questions Triumph 6
P TR6 1970 TR6 Timing Question Triumph 2
sundown TR6 1973 TR6 timing light Triumph 3
floyd TR6 timing 75 tr6 Triumph 6
W TR6 Timing Light TR6 Triumph 1
Scott_Hower TR6 TR6 crank/timing gear quality issue? Triumph 2
TR3TR6 TR6 TR6 Timing issues Triumph 54
c5racer 1500 Timing Chain Upgrade to TR6 Spridgets 1
W TR6 TR6 Timing chain oil seal question Triumph 3
wangdango TR6 TR6 timing questions??? Triumph 5
wangdango TR6 76 TR6 timing questions Triumph 1
7 TR6 Timing the 72 TR6? Triumph 4
E TR6 TR6 Timing Triumph 27
veale001 TR6 TR6 TIMING QUESTION............................... Triumph 35
I TR6 TR6 timing help Triumph 8
B TR6 TR6 Camshaft Timing Triumph 4
S TR6 Ignition timing on TR6 Triumph 3
R TR6 Ignition timing on '72 TR6 Triumph 14
bash TR6 TR6 timing chain sprocket alignment Triumph 3
Webb TR6 TR6: Intake Vacuum & Timing Triumph 15
I TR6 Ignitions timing specs for 69 TR6 Triumph 13
I TR6 69 TR6 static vs moving timing - what is better? Triumph 6
T TR6 Does your TR6 have timing degree marks Triumph 21
SCguy TR6 Ignition Timing with a timing light on a a TR6 Triumph 16
Cain TR6 TR6 Crank Turning for Timing/Retard Unit Triumph 8
AltaKnight TR6 TR6 ignition timing Triumph 6
H TR6 TR6 Timing- Need help please Triumph 2
H TR6 TR6 Camshaft timing Triumph 2
S TR6 TR6 Timing Adjustment Triumph 4
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
