Hello,
I repaired my rear tunnel light and want to test it to make sure it works. How do I hook it up to the battery to test? The black is ground, but do I just hook up the solid purple wire to positive? What do I do with the purple/black wire? Should I put a fuse in between the light and battery?
My second question is has anyone ever added lighting to the center console? I wanted to put a light in where the heater controls are in the later model TR6. If you have done this, do you have a pic or can you tell me where you purchased one from?
Thanks for your help,
Kevin
Kevin
