TR6 TR6 hard to start after running hard
G
Hey guys,
Quick question:
Why is my TR6 hard to start after a hard run all of the sudden? All electricals check out, timing, points, condenser, coil- all fresh. Think it is a fuel problem, maybe set too lean? I built the car myself ('cept the engine) and just lately it takes a lot of cranking with the gas pedel to the floor to get it to light up. Understand there could be a miriad of things to look at but rich/lean on triple ZS carbs maybe the culprit? Been fooling with them and may have them set wrong. (Greatest salvation was finally setting the point gap with a dwell meter)
If it were a tooth I could fix the **** thing.
Dr. Bill
Larry Kronemeyer
Does it start ok when cold? If so check the choke and make sure it is open all the way when hot, also, check the plugs for fuel burn if lean check carbs, if rich check choke.
Larry
G
Thanks Larry,
Plugs 5 and 6 were white, 3 and 4 were almost white and 1 and 2 were close to tan. I enriched the back carb 1/2 turn, the middle and first ones a little better than 1/4 and everything smoothed out, it now starts first hit every time. The Japanese starter doesn't even strain.
Bill
Steven
My 75 TR6 ran terrible for years when the motor was warmed up well. It stumbled, cut out, and was really hard to start on a warm engine. It also overheated occasionally. I found the secret to be.....run a summer thermostat during the hot months of the year. You can tune that thing til its spec perfect and it will still run like crap unless you change thermostats by the season. Mine has never run better in summer since i put in a summer t-stat. It only took 15 minutes to put in too.
aeronca65t
I'd agree that a colder thermostat in the Summer may help.
Also, assuming you've got reasonable carbs and igniton, you may want to check valve adjustment. Sometimes, "tight" valves will make an engine difficult to start when warm.
P TR6 TR6 hard starting Triumph 24
k60djg TR6 TR6 Hard Top Fitting Instructions Triumph 5
G TR6 How dry does your TR6 Hard Top keep you? Triumph 2
G TR6 Spotted TR6 Hard top for sale Triumph 0
I TR6 TR6 hard top advice please Triumph 3
hondo402000 TR6 TR6 Hard steering Triumph 6
hondo402000 TR6 TR6 Hard Steering Triumph 3
R_Lyle TR6 TR6 J-Type overdive hard engaging Triumph 9
eschneider TR6 what is TR6 hard top worth? Triumph 7
R TR6 Ebay TR6 Hard top Triumph 10
M TR6 TR6 Hard Top Seals Triumph 0
V TR6 TR6 Hard Top Triumph 13
hondo402000 TR6 TR6 hard steering Latest/ scrol down to see origin Triumph 3
hondo402000 TR6 TR6 Hard steering Triumph 8
BierRunner TR6 TR6 Trunk Lock Striker Triumph 2
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
