TR6 tr6 5speed conversion???
ALLAN
Has anybody (or know anybody) installed the tr6--5speed conversion from New Zealand (Conversion Components) I need to know how it has worked out or if any problems. I am getting ready to install mine.
71tr
not me, considered it but decided to go original with the addition of a volvo overdrive to my six. I know there are a few guys on here that have done it, be patient.
michalotti_tr
I don't know anyone whos installed the New Zealand kit, but several people I've talked to have used the HVDA kit and have seemed very pleased with it.
DNK
There is a guy by the name of Hermann who sells a very slick 5 speed adapter to the 6. I highly recomend it from aaall the satisfied clients he has. I have the web site if you need it but just google tr6 5 speed I am sure he will be there.The best part for you is he is in CA.
A
ALLAN
Thank You, but I already have the New Zealand Kit, I bought a few years ago along with a Supra close ratio transmission to go with it, Im am finally getting ready to install it and wanted to find someone who already has---for any hints, advice or problems to look for. There was a company in California that handled theese kits, I think it was called XK-Unlimited. Thanks
billspit
No experience with any of these kits, but I would think the bugs or problems have been worked out or at least brought to light by now. I have a friend that put the Ford Type 9 trans conversion from England in his MGA. The biggest problem he had was getting all the parts from the vendor, who kept lying about delivery times etc. The conversion worked well except there was small alignment problem with the shifter itself.
DNK
allan- I know a guy in canada who has done his. I will ask him if it is ok to forward his address to you if you like.
big6
If you have the ability to weld aluminum, don’t waste your money on the kit. The circle patterns for a Toyota Celica and the TR6 are surprisingly close to the same. I used a donor TR6 transmission housing cutting out the starter mount and a section to weld in where the Toyota starter was removed.
I used the steel plate center hole of the engine mount as a fixture to weld the Triumph parts to the Toyota bell housing. I made a bushing centering the Toyota transmission input shaft with the engine mounting plate. It is amazing how close the bolt mounting holes are located between the two transmission bell housings.
You will have to fabricate a rear mounting bracket, rear yoke, shift lever, clutch disk, pilot bearing, throw out bearing, and speedometer cable. I can provide details if interested.
I completed the conversion about five years ago and have driven over 10,000 miles. This includes several trips from Spartanburg, SC to Charleston, SC and Savannah, GA. In fifth gear I can cruse at 70 mph tacking between 2000 and 2500 rpm.
The conversion is well worth the time to fabricate the parts. My conversion is not one way. I can re-install the TR6 transmission easily in one afternoon.
Don’t use the Toyota close ratio transmission. The shift points are too close for the differential ratio.
vettedog72
Bigsix:
Sounds like you know what your doing; if you have the info, drawings etc, I would appreceate a copy. Also, if you have some pictures it would be great. If I could get 70mph at 2000 or 2500 RPM's I would drive my TR6 from Atl to LA and enjoy the beautiful fall, winter and spring top down weather here in Louisiana.
BTW, what else have you done to your TR6?
A
ALLAN
Big 6, thats great you were able to build your own conversion--it sounds interesting, But with the cutting and welding you had to do is exaxtly why I went with a kit, which came with all parts needed including adapter to position the shift lever (that came with it)in the right position. All the mounting holes are not just close they are right on. The kit also came with the rear yoke and rear mount. The Supra transmission is known to be stronger than the Celica and smoother shifting. There is a small amount of difference in gear ratios between a close ratio and standard ratio and does hardly matter what the rear ratio is. wheather it is 4.11 or 3.50 a close ratio still gives you less of a drop in rpm between gears and the fifth gear is still overdrive. This is not a one way kit, it can always be converted back to stock. I havent installed mine yet but I know I have all the parts and All the holes line up.
martx-5
Will this conversion also work on the TR-3's and 4's??
PeterK
Yes. There is a different version for solid axle TRs that has a different rear gearbox mounting arrangement. I have one for both my 4A and 3A! See blindmoosefab.com or google for HVDA Triumph. PeterK
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
charlie74 ‘74 1/2+ TR6 Spotted 0
