TR4/4A TR4a frame options
tdskip
Thanks again for the help and collective wisdom on not going after the GT6+ folks, and as evidence that I am coach-able I spent today digging into existing projects.
These pictures are of the 1964 TR4a, which I bought when I was young and dumb (as opposed to my current state of being slightly older and dumb).
I realized <span style="text-decoration: underline">after</span> I bought the car that it had been in an accident. I can handle (I think anyway) the sheet metal issues but wanted to get your thoughts on the damage in the pictures below. Same drill as we were talking about - time to take her to a frame straightening specialist?
bgbassplyr
Is that the only frame damage that you have found?
A bit of a strange place for that to be the only damage.
The only cause I can think of that would damage only that one portion of the frame would be a wheel breaking off or or falling off the hub and jambing itself back into the frame. Unless some other damage is found, I would assume that is what happened.
Don't know if that little kink can be straightened. If not, a reinforcing patch could be welded to the frame as a reinforcement.
And replace the missing stud and nut on the rear of the spring pan.
Others with experience please weigh in.
Cool jack, love it.
DougF
That is a nice jack. I bought the same one at WalMart several years ago as a clearance item. But I think I paid a penny more. Haven't used my other one since.
TR4
Is there any way you can check the frame to see if it is still square or close to being square? If not, I would recommend taking it to a shop for their assessment to see how costly it would be to straighten it.
TR4nut
I have the same jack from my last Harbor Freight visit!
My in-expert opinion is that I'd just get it to an alignment shop and see how far you are off. Then I'd focus on the lower a arm mounts, as on a TR4A these were fragile, single stud mounts - the recommended change is to reinforce there and use later TR6 style 2 stud mounts. Hopefully if that are is in good shape any accident issues can be aligned out with shims which was not an option with TR2/3/4s.
T
tdskip
Thanks for the input guys - is the Bentley manual the best place to get frame measurements to make sure she is square still?
Based on the GT6+ conversation I know that the shop is going to want $800+ to fix this, so if I can just use shims to get the alignment right that would be a win (provided that leaving the frame like this wouldn't be an issue long term).
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
D Wanted TR4A Live axle frame Triumph Classifieds 0
D TR4/4A Tackling the biggest problem with my TR4A.... Frame Damage :[ Triumph 70
J Wanted Tr4a irs frame Triumph Classifieds 1
Rut TR4/4A TR4a frame Triumph 11
Rut TR4/4A TR4a or TR6 top frame? Triumph 4
Popeye TR4/4A TR4A front frame reinforcement / parts don't fit Triumph 6
C TR4/4A TR4A top frame buffer Triumph 3
M TR4/4A TR4A - need a windscreen frame vinyl trim kit Triumph 11
britlover TR6 TR4A IRS body on a TR6 Frame?? Differences? Triumph 10
M TR6 TR4A on a TR6 Frame? Triumph 19
M TR4/4A Another TR4A Frame Question Triumph 2
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
