TR4/4A TR3/4 head thickness
Pulled out an old TR3/4 head today to take to machine shop. I bead blasted it, no obvious cracks but there was low place rusted in the head gasket area. Checked my TR4 shop manual to see what the deck height was std. Could not find info anywhere in the book on deck height. I've found it in the TR 6 shop book easy enough but its not listed that I can find in the TR3/4 book. Anybody got the std deck height. Mine measures 3.330. Hope its std so I can have the head surfaced out. Don't want to take out any more than I have to but how far can I go without pushing limit?
Marv
TR3driver
Great Pumpkin - R.I.P
TeriAnn has it posted on her web site as 3.330".
https://www.tr3a.info/FAQ_heads.htm
Found it: I've got an old post from Ken Gillanders that says 3.325" to 3.330"
On a street engine, the main limitation seems to be having the CR too high for available fuel. I ran one for awhile that had a bit more than 0.100" taken off, and it held up fine. Just had to add a healthy dose of MMT to every tank.
glemon
MMT? Some kind of anti-knock or octane booster-I googled and got Modern Monetary Theory, I am guessing that was not the direction you were going.
JerryVV
I've run .090 off 3.30 for maybe 40 years. Recent head gasket failure has me at .103 off. We shall see how that works out. At .090 93 octane worked fine. May need to retard timing some for current head. Lots of friends have run for years at .070 with no problems.
martx-5
I've skimmed 0.085" from the head and have 87mm liners (which will also increase compression), and run with 93 octane and no problems.
T TR2/3/3A tr3 head gasket Triumph 38
M TR2/3/3A Tr3 Head Rebuild Triumph 3
Got_All_4 TR2/3/3A The bolt on the back of the tr3 head Triumph 4
DornTRoriginal TR2/3/3A TR3 Head Gasket Questions Con't Triumph 3
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
Kleykamp TR2/3/3A 1961 TR3 control head. Triumph 5
K TR2/3/3A Can porting a TR3 Cylinder head be a DIY job? Triumph 6
G TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection Triumph 2
Scotsman TR2/3/3A Signal switch on TR3 Horn Control Head not canceling Triumph 20
C TR2/3/3A TR3 Low Port vs High Port Head Triumph 10
Lukens TR2/3/3A TR3 blown head gasket? Triumph 39
RedTR3 TR2/3/3A TR3 Head Gasket [Again] Triumph 4
RedTR3 TR2/3/3A TR3 Head Gasket Triumph 6
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
O TR2/3/3A TR3 Control Head Install Triumph 10
H TR2/3/3A TR3 head /cam Triumph 4
K TR3/4 Cylinder head temperatures? Racing 1
O TR2/3/3A TR3 Control Head Stator Tube Install Triumph 5
tinman58 TR2/3/3A Removing head studs TR3 Triumph 15
K TR2/3/3A The Aluminum Plug in the Cylinder Head ?[Again]TR3 Triumph 2
S TR2/3/3A tr3 head light switch Triumph 3
K TR2/3/3A Head bolt torque TR3 Triumph 3
H TR2/3/3A TR3 -- Pull the head "while I'm in there . . ." Triumph 9
K TR2/3/3A Internal view of a tr3 control head Triumph 7
mountainman TR2/3/3A TR3 Bright Head Lights Triumph 3
mountainman TR2/3/3A TR3 Control Head Wiring Triumph 11
Marvin Gruber TR2/3/3A TR3/4 cylinder head differences Triumph 3
newmexTR3 TR2/3/3A tr3 head rear oil leak Triumph 9
T TR2/3/3A TR3 head core plug [freeze plug] Triumph 6
S TR2/3/3A TR3 Copper Head Gasket -- quick questions Triumph 8
A TR2/3/3A TR3 head welding Triumph 4
S TR2/3/3A TR3 head is off -- awaiting head gasket Triumph 9
S TR2/3/3A Uggh! TR3 head gasket leak!!! Triumph 9
Got_All_4 TR2/3/3A Blown head gasket TR3 what to do next? Triumph 16
Tinkerman TR2/3/3A TR3 Oil filter head, long stud? Triumph 2
martx-5 TR2/3/3A TR3 Head Gasket Triumph 16
TR4nut TR4/4A Aluminum plug in TR3-4A cylinder head? Triumph 4
F TR2/3/3A TR3 Turn Signal/Horn control head Triumph 4
A TR2/3/3A TR3/4 head crack, can it be welded Triumph 11
K TR2/3/3A Torqing the head again?....rebuilt motor... TR3 Triumph 4
A TR4/4A TR3 / TR4 head crack repair Triumph 3
J TR2/3/3A TR3 control head internal pictures? Triumph 11
C TR2/3/3A TR3 Head Work Triumph 2
C TR2/3/3A TR3 Head Triumph 3
S TR2/3/3A head bolts on a tr3 Triumph 5
MGTF1250Dave TR2/3/3A TR3 Control Head Triumph 4
D TR2/3/3A Control Head [TR3] Rebuild Triumph 2
bluemiata90 TR2/3/3A TR3 Horn,control head and stator tube removel Triumph 9
MGTF1250Dave TR2/3/3A TR3 Control Head Help Triumph 9
E TR2/3/3A TR3 Cylinder Head Lubrication Triumph 11
