TR5/TR250 TR250/6 Rear Trailing Arm Bush Options
glemon
I just got back from an airport speed run in my TR250, we basically do a quarter mile drag turn around, and then do some slaloms and such on the way back.
Anyhow, middle of my second run the car gets pretty squirelly, I jack it up on site and notice considerable play (.5" or so) in the rear suspension passenger side inner trailing arm mount, so I am done for the day. Drive home slow and careful after making sure nothing seems to be about to break or fall off, and take it apart.
The rear poly bush has compressed enough to allow this movement, as in permanently distorted.
I didn't think they were supposed to do that.
I have a rear sway bar and I am thinking maybe the fulcrum effect of the bar pressure when I turned very hard did it. But I still didn't think they were supposed do that.
Anybody else had this problem?
Thinking of going to a hard rubber bush or maybe trying the poly again, not sure at this point. Are the rubbers hard to press in, don't really want to have to take the trailing arm all the way off (brake line) if I don't have to.
Oh yes, the good news, my one good first run was only half a second off that of a Sunbeam Tiger's best for the day (basically a very stock and original Tiger, I know I would have no chance against a modified Tiger), and way ahead of the MGBs and such, I am sure I could have shaved that much or more off in subsequent runs....
SkinnedKnuckles
Let them sit for a day or so - the deformation is not so permanent. When I switched over to Nylatron bushes on the trailing arms I was shocked at the deformation in the polyurethane bushes that were removed. The holes were oblong! I put them on on my bench and went on with the installation. A day or so later they looked like new. Are they supposed to do that? No - but they are plastic, not rubber, so in hindsight it's not unexpected. When I get around to the front end again I'm going with the nylatron instead of poly.
Brosky
That's one of the reasons that guys go to those. Just to prevent that from happening. I'll be curious to see some pictures when you get it apart.
glemon
glemon
Brent, where did you get the nylatron bushings?, and yes mine are oblong too.
As far as rubber, I assume it will compress easier than poly, but it would decompress as soon as the pressure is off, not over a period of time. Interesting on the compression going away over time, will check them later tonight or tommorrow.
SkinnedKnuckles
As always for stuff like this - Good Parts.
Yes - rubber will give and forgive, until it breaks down. Then there is a hollow. The plastic deforms under load, but still has a grab on the metal bushing. The deformation is the weight of the car on the bushes.
I did the front in polyurethane, too, about 15-16 years ago. There is no lost wobble, but I wonder about the plastic set. I'll get to it eventually.
justin_mercier
I've got both a poly set and a hard ruber set of rear trailing arm bushings, and i'm trying to decide which set to use when I re-install my trailing arms this next week with new adjustable camber trailing arm brackets. I'll be honest that it looks like the hard rubber ones are better made than the poly ones, but how long do hard rubber ones last?
SkinnedKnuckles
I can't answer that one. Alot of so called "rubber" components these days aren't really a vulcanized rubber - they are a TPE - thermoplastic elastomer. Because it's cheaper. The TPE's have some really good & really bad properties - as in they can't stand up to heat as long as real rubber. Solvent (gasoline) resistance is another, but off topic. With all the topics on the poor quality of parts in general, I'd be careful on rubber ones.
glemon
glemon
Do the nylatron ride hard or make it more noisy?, found them on the Goodparts site, TS import list nylatron as "competition only" or something like that.
I have also read all polyurethane is not created equal, I notice you can also get "prothane" polyurethane, they are more exensive than most of the other polys but less than the nylatron, anyone have any experience with these?
tdskip
I have those Goodparts hard bushings in my TR6 and I haven't noticed them to be overly tough, spring and shocks will likely make a far bigger difference.
swift6
Harder bushings in the trailing arms won't really affect ride comfort/quality. The ultimate set up that some of the European fast road preparers are doing is to replace the bushing with a spherical bearing.
DNK
Shawn, one thing it does do , is put more force on the part. Correct?
SkinnedKnuckles
Same here. No extra squeaks. I also took a look at the site since it's been a while - didn't see any reference to "competition only".
swift6
What part? Stiffer bushings resist the force applied more than the softer, which could lead to higher cornering speeds which could lead to more force, but the stiffer bushing itself shouldn't equate to higher forces, just higher resistance.
DNK
Won't a poly or Nylatron or even in this case solid bushing in the TA area provide less shock,if you may, than a rubber one on a very hard thump or pot hole?
lbcs_r_fun
Why not ask someone who races an IRS Triumph. I would think that something this basic was addressed long ago. How about Kastner's preparation manuals?
lbcs_r_fun
tdskip said:
I think everyone races solid axle cars. :smile:
Group 44 raced a TR250 and TR6, which of course were IRS!
Group 44 TR250
I think Kas has a website with a forum. I am sure you could get some expert opinions there.
Good luck
T
DNK
Only cause I know what you meant the first time Tom
T For Sale TR4 TR250 Rear Fenders Triumph Classifieds 2
busybrit Wanted TR4, TR4A, TR250 Rear light WANTED Triumph Classifieds 0
arizonamike TR5/TR250 TR250 Inside Rear View Mirror Mount. Triumph 2
glemon TR6 TR250 TR6 Rear Springs Triumph 13
heliguy TR5/TR250 Rear sway bar install, TR250 Triumph 1
angelfj1 TR5/TR250 TR250/6 Telescopic rear shock retrofit Triumph 2
R TR5/TR250 Triumph TR250 Drooping Rear Chassis Triumph 2
kindofblue TR5/TR250 Rear brake hoses replacement on TR250 [IRS] Triumph 6
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
glemon Wanted TR250 Wheels Triumph Classifieds 1
conan69 TR5/TR250 TR250 seats Triumph 1
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
angelfj1 For Sale TR3, 3A and TR250 Parts for Sale Triumph Classifieds 6
Retired2020 TR250 steering column bushing Triumph 2
Retired2020 TR5/TR250 TR250 smith gauge Triumph 7
S TR5/TR250 "New" TR250 on the horizon Triumph 0
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
C TR5/TR250 Tr250 registry Triumph 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
oldbagpipe For Sale '69 TR6/TR250 Seats now available Triumph Classifieds 0
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S For Sale Triumph TR250 Factory Workshop Service Manual on CD/ROM – 1968 Models Triumph Classifieds 0
K TR5/TR250 TR250 question [Not asking for a friend] Triumph 17
T TR5/TR250 TR250 wiper switch and motor Triumph 1
T TR5/TR250 What lubricant for TR250 wiper box and cable? Triumph 2
glemon General TR TR250 Steering Wheel Options Triumph 6
P Wanted WANTED To Buy a TR4 or TR250 Triumph Classifieds 3
T TR4/4A TR4A/TR250 what are they worth Triumph 8
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
M Wanted WANTED TR4A or TR250 fendet Other British Classifieds 0
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
R Wanted TR4A / TR250 Center Console Triumph Classifieds 1
B TR5/TR250 Registry for TR250's? Triumph 1
brgrmyster TR5/TR250 1968 TR250 original emissions lines Triumph 0
RobT For Sale Triumph TR250 - $32K Triumph Classifieds 2
TRopic6 For Sale Flywheel for TR250/'69 TR6 Triumph Classifieds 0
B Wanted TR250 passenger seat Triumph Classifieds 0
M_Pied_Lourd TR5/TR250 Started my TR250 Restoration Project..... Triumph 16
