Top trunnion pin removal.
catfood
I'm dismantling the suspension on the BN1 and the top trunnion pin is being very stubborn. What's the technique? The big hammer approach doesn't seem to be working!
steveg
On the car - you could apply penetrant and withdraw the castellated nut a couple of turns, heat the ends of the arms with a propane torch (avoid heating the pin itself), then use a large c-clamp with a socket wrench around the head of the pin (that would allow it to move). Tighten the c-clamp and push the pin out.
Off the car - you could remove the kingpin castellated nut and the shock fixing bolts; and take the shock with upper trunion to the work bench.
Apply penetrant such as kroil or PB Blaster to where the pin goes through the shock arms. Undo the castellated nut on the pin and replace it with a regular nut; back the nut out a couple of turns but leave it on the pin. Turn the shock sideways and support the arm ends over the gap in a large vise. Take your lead hammer and hit the nut - this should loosen the pin. Or if your vise is big enough you could use a socket per method one and squeeze the pin loose.
bob hughes
Have you managed to remove the bottom wishbone pins? You may have to do what I did and cut through them - bought an air driven recip saw as it takes an age by hand with just a blade. You may have to resort to cutting the top pin as well. To get the top trunnion off put the king pin and axle assembly in a large vice ( hold it by the bottom trunnion) and put a 3 foot bar through the top trunnion and use brute force and ignorance to push and pull that bar back and forth to rotate the top trunnion off. Hope that this is of some help.
:cheers:
catfood
catfood
I've only had problems with the top trunnion (still haven't had time to try Steve's suggestion). Everything else came apart relatively easily. The suspension was rebuilt about 12 years ago by Cape International so I'm not playing with 50 odd years of corroded joints. Pulling it all apart now ready to get the bodyshell fettled and repainted.
J Top Trunnion Bushing Fit Austin Healey 9
B Top Trunnion Bearing Kit Austin Healey 6
R BJ8 Top Trunnion removal Austin Healey 8
H top trunnion too tight Austin Healey 3
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
S TR6 Soft top material Triumph 10
Sarastro TR4/4A Convertible top installation problem Triumph 12
A TR6 TR 6 Soft Top Triumph 4
D BJ8 Top Installation Detail Austin Healey 3
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
B TR6 TR6 convertible top frame Triumph 0
zoohow BN4 Top Frame Installation Austin Healey 1
L Do you have a picture of these convertible top details? Spridgets 4
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
Frameman 1949 Soft Top Webbing Austin Healey 2
Overdrive45 Convertible Top Cover Fit Austin Healey 6
D Top installer recommendations NYC tri-State area Austin Healey 0
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
S For Sale FREE HARDTOP.. top is in Palm Springs, Cal. Call Bob ,562 400 5983 MG Classifieds 1
E Spitfire '69 Spitfire hard top Triumph 2
Celtic 77 MGB B-pillar repair kit for convertible top MG 1
Popeye TR4/4A Tonneau or top cover? Triumph 12
7 Top, hard Triumph 0
JPSmit Today's top tip - Rain X Restoration & Tools 3
Popeye General TR Old robbins top in box Triumph 7
KVH TR4/4A Closing the Soft Top Triumph 11
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Bayless How does '67 Sprite top attach to body? Spridgets 3
D Top Door rubber and fuzzy seal Spridgets 5
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
Donald1107 TR2/3/3A Soft top Triumph 14
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
luke44 TR2/3/3A Tr3 top - corner fastener Triumph 4
N MGB Convertible Top Frames MG 7
roscoe New / old hard top Austin Healey 16
nevets BN6 Soft Top Webbing Austin Healey 2
R BUGEYE SOFT TOP FIT Spridgets 2
AngliaGT For Sale Two Piece Top Frame - MGB '62 - '70 MG Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
M Wanted TRIUMPH TR3A Hard Top Triumph Classifieds 14
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
EWD TR6 Top Install Triumph 3
B TR2/3/3A Hard Top Part Triumph 2
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
JamesD BJ8 Top Frame Bumpers Austin Healey 12
