Re: The start of something big. Frame off restorat
Today was re-doing the dash!
Some prep work was done before this including book matching the burl veneer and quickly cutting out some particle board for a press top. First we've got everything laid out on the table.
We decided to do the face of the glovebox at the same time as the rest of the dash, so first we waxed up the edges of the glove box so that the glue would not adhere to the sides.
For glue we chose titebond III because of its water resistant properties for outdoor use.
An outline of the dash was traced onto the bookmatched and taped up veneer so that blemishes could be stuck within parts that will be removed or cut away.
We used a large vacuum bag from the Vac-U-Clamp company which was large enough for the dashboard.
for vacuum veneering you need make sure the vacuum will reach the whole bag and create and even pressure, cross-scored MDF is used to make a base that will go within the bag for the bottom of the 'press'
It's important to position the nipple on the corner of the board so that it can draw vacuum from all the way around and not end up with good pressure in just one area.
To ensure that the veneer didn't shift, it was tapped to a back board on the corners where the dash would not be affixed
Because of the holes in the dash, to get an even pressure with the vacuum bag, a top-plate was cut to match the outline of the dash, with the top corners rounded off so that they wouldn't damage the bag when under vacuum
