G
I finally managed to get the rear crank shaft backet off the block. This thing has never been off since 1959 (would that be 47 years?). No amount of dead blow hammer strikes would move it. Finally, I rigged a bridge across the face of the block where the oil pan bolts up and slowly, over about half a day, cranked till it broke loose (yes, that is aloose down here). The crank looks pretty good. My big question is what is that shaft-looking device right below the cam opening that has several large bolts screwed into it along the body of the block? The ends show a shiny metal plug, like the ends of a shaft, but looking down into the galley, it seems to be hollow. Is this something to be removed? I want to strip the block clean so I can make it spotless before I bring it to a machine shop to check everything out (magnaflux the crank, check the head, etc.) There appears to be no slap in the pistons (with my micrometer vision) and no scarring on any of the bearing surfaces. This thing may yet be resurrected. My plan is to make it as perfect as I am capable and either find a body to go around it or have a really expensive coffee table.
Bill
Bill
