Wedge Stalling TR8 - Need help
AHBN1
Member
Hi all. First post on the forum for me but I have a problem. My 1980 (factory) TR8 with 38000 miles is stalling. It feels like an electrical issue as it just dies with no warning, caughing, bucking..etc. It just dies as if the key is being turned off. It started out as an occasional thing driving down the street, I'd pull over, turn the key and it would fire right up and be fine for the rest of the day. It has progressed to dying in the garage while idling at a perfectly smooth 800rpm. Again I tun the key and it fires right back up but will stall after a few seconds, minutes or whenever it feels like it. I have taken apart the ignition switch and fully cleaned it, no change. I have replaced the plugs, coil, wires, cap and rotor, no change. I will check the heat of the new coil next time it dies.
I have heard that the original distributors for these cars can cause problems. Have any of you out there experienced issues like this and if so what was your resolve? I should note that the car does have a Holley 390 carb instead of the original Stromberg 175CDs
Any thoughts would be appreciated
Dave
Darrell_Walker
Hi Dave,
It certainly sounds like an electrical (ignition) problem. Always fun to diagnose problems that are intermittent.
There is a Pertronix conversion for the distributor you can install, as well as complete distributors. My car came to me with a Pertronix conversion, and many folks with TR8 that I know no longer have the original internals, so it is possible that is your problem.
Do you have a timing light you can have connected when the car dies, to see if the ignition is dying? Or since the tach is driven by the ignition, does the tach needle seem to drop immediately when it dies? That may be another clue that it is ignition related.
I would also check all of the connections to the ballast resistor. There are quite a few connections in that circuit, and one of them being flakey could be an issue. Here is some good information on that part:
https://www.team.net/TR8/tr8cca/wedgelab/ignition/ballast/ballast.htm
Hope that helps!
-Darrell
A
AHBN1
Member
Hi Darrell,
Thank you for the response. The Pertronix system is an option I am looking into. Had one on a TR7 years ago and never had a problem. I have checked the ballast wires and all are fine - car stalls as soon as I disconnect one. I did check the coil when the car stalled this evening and it was cool to the touch so I'm leaning toward the distributer. I do have a timing light but have not tried a test with it yet but the tach drops to 0 and the ignition light comes on as soon as the car dies. I too have a GM distributer as a spare and may look into setting it up with an electronic ignition as I understand the GM units are trouble free. I guess I have more work ahead.
Thanks again, I'll update the forum if/when this situation is resolved.
Dave
A
AHBN1
Member
Hi tdskip,
Thanks for the thought and yes I'm sure I have good fuel flow. One of the first things I checked. Problem is the car starts and runs great until it warms up and then will die without notice, no sputtering or starving for fuel. I'm pretty sure it's an electrical issue likely related to the distributor. Frustrating as it's very intermittent but it wouldn't be British if it always ran as it should.
Dave
WedgeWorks
td-Next time it dies check for spark immediately and if you have spark then try bypassing the fuel cut off inertia switch next to the clutch master cylinder. The do go bad in time and will just cut out if you hit a bump or shift gears. All you have to do is make a small jumper wire. I had this issue in my TR8 coupe when I first bought it. I also know you have a three prong oild pressure switch too that is in line with the inertia switch as a safety device too.
A
AHBN1
Member
Hello,
Thank you for that advice and I'll be checking that inertia switch this weekend. Although the car does stall just sitting at idle this whole issue started to happen when shifting gears entering a highway and excellerating so it does make some sense. I'll let you know how it works.
Dave
Darrell_Walker
I'm not that familiar with Holleys, but after it dies, can you easily check for fuel in the float chamber?
tr8todd
Sounds like the ignition module in the distributor. They like to stop working when they get hot, and then start working again when they cool down. The wiring going from the oil pressure switch and the roll over safety inertia switch will cut out the fuel pump, so if you still have fuel in the carbs, those are not your problem. Stick to chasing the wires thru the ballast resistor and into the distributor. Look for frayed wires at the terminals. If after all of the checking things out, you still have the problem, try a different low tech/known working distributor as a diagnostic tool. You can use one from a small block Buick V8. Someone local to you must have one you can borrow.
philman
I had to adjust the idle mixture adjustments on mine to get it to idle properly with the holley carb. it would also die when stopping at a traffic signal. I also thought it may have something to crankcase breathing and it also improved after I replaced the filler cap with a breathable cap on the left valve cover. Anyway, that's how I got improvement in a similar situation. I am using a mallory distributor and MSD6 ignition.
A
AHBN1
Member
Update - Found some forums/websites that suggested that a change of the distributor's transformer (using an NTE98) could solve my stalling problem. I found one and made the change taking the time to clean the complete distributor while it was out and appart. Ran great but started the same stalling behavior after about 20 mins on the road - just like before. Crap! Does anyone out there have experience with the replacement/aftermarket units such as the Pertronix, Crane 700, Mallory...etc. I think I'll be replacing the Lucas system.
Dave
Mickey Richaud
Dave -
When I had the TR8 (now owned by Brosky), I installed the Mallory Unilite distributor. Easy installation, and it worked nicely.
Mickey
A
AHBN1
Member
Hi Mickey,
Thanks for that info since the Mallory unit is the system I've been laning toward. The Mallory is a 3 wire installation but the Lucas is 2 wires. I would like to leave the resistor wired up and functional. How did you wire the Mallory unit into the existing wiring of the car? Your thoughts are much appreciated.
Dave
Mickey Richaud
Dave -
Afraid it's been a while since I installed it, but it was pretty straightforward.
Woody at the Wedge Shop (wwwthewedgeshop.com) is a great resource. And Paul (Brosky) should be checking in on this thread before long; he can give you some more specifics.
Mickey Richaud
You're most welcome!
One thing I do remember is buying a spare module for the Unilite to keep in the glove box just in case. They're not your normal stock item in parts stores, and you don't want to get stranded somewhere.
Deleted member 8987
Just a thought here. When it does this (and you may have mentioned it, but I missed it), have you removed the petrol cap? Do you hear a rush of air when you do so? Does it run afterwards?
Dave
A
AHBN1
Member
Hi TOC,
Yes I did try that and there was no back pressure in the tank. With all my research (the internet is a wonderful thing...sometimes!) and conversations I had I concluded that it was the problematic Lucas distributor. I have bit the bullitt and ordered a new Pertronix distributor testerday from Woody at The Wedge Shop. Sounds like a very common fix for my problem and once it arrives and I have it installed I'll update this forum for those out there that may have the same problem.
Dave
Overdrive45 Stalling at Traffic Lights in Hot Weather Austin Healey 20
R TR2/3/3A Engine stalling and backfiring Triumph 25
F BT7 Stalling Austin Healey 9
M Stalling Austin Healey 24
PATR8 Wedge Help.... Wedge stalling out Triumph 1
19_again MGB Stalling and then restarting after 4-5 minutes MG 32
justin_mercier Wedge Need help diagnosing a misfire / stutter / stalling when stepping on gas Triumph 8
pkmh Stalling issues Austin Healey 13
sjuengst BT7 stalling when hot Austin Healey 7
pkmh BJ8 Stalling Problems resolved [maybe??] Austin Healey 13
doates Freeway Stalling Triumph 20
pkmh BJ8 stalling out to due electrical issues Austin Healey 50
F Spitfire Spitfire Stalling Problems Triumph 16
P Stalling Triumph 11
pkmh 1967 Healey 3000 Keeps Stalling Austin Healey 43
J Stalling on downgrade stops...common? Triumph 7
sparkydave Got a new stalling problem Spridgets 4
Stewart Backfiring stalling and missing hard starting MG 5
Dave Richards Post for a new B owner-Car stalling, not starting MG 23
1 Cold weather stalling MG 15
M 87 XJ6 Stalling Problem Jaguar 3
George Zeck Carb Oil & Stalling Issues .... Spridgets 4
J stalling Jaguar 7
sparkydave Stalling when hot Spridgets 11
A engine stalling Triumph 8
Stewart MGB MGB Stalling MG 10
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
P Wedge Starting problems TR8 Triumph 3
tr6nitjulius Wedge Rare TR8 Triumph 0
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
Hamish Racing TR8 IMSA GTO around Spa Racing 0
MadMarx Wedge Dijon 2019 - Triumph TR8 IMSA GTO Triumph 0
MadMarx General TR Spa Summer Classic 2019 - TR8 IMSA GTO Triumph 1
MadMarx Brands Hatch - Triumph TR8 IMSA GTO Racing 0
MadMarx General TR Brands Hatch - Triumph TR8 IMSA GTO Triumph 0
MadMarx Wedge The IMSA TR8 is ready to go again Triumph 7
MadMarx Wedge IMSA TR8 video with some roar Triumph 0
MadMarx Triumph TR8 at Spa Racing 0
MadMarx Le Mans - YTCC - Triumph TR8 IMSA Racing 1
B Gold TR8 Waxhaw N.C. Spotted 2
MadMarx Wedge Canadian Group 44 TR8 at Hockenheim Triumph 2
MadMarx Wedge TR8 IMSA at Le Castellet Triumph 1
J Wedge TR8 research before purchase Triumph 16
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
S Wanted TR8 with blown motor or no motor Triumph Classifieds 0
T Wedge Triumph TR8 for Sale - 1,020 miles Triumph 3
S Wedge tr8 front end Triumph 0
