TR6 speedo gear reduction
Fredshealey
anybody out there know of a speedo gear adapter,that would increase the speedo cable turns by about 50 percent-my speedo is slow,meaning it shows 40 mph instead of 60mph
any info would be greatly appreciated
Fred
Gliderman8
I have a ratio adapter on my TR6. I needed it after installing my 5-speed Supra transmission. You can get them at most speedometer shops or on-line. I think I paid around $100 a few years ago.
They look like this:
Gliderman8
Here's a place I just found on the net:https://speedometercablesusa.com/gear_box_adapters.html
I would wait to see where others on this forum have bought theirs before contacting any supplier without references.
Again, the link I supplied was found from a quick search on the net.....Caveat emptor.
4tecdog Speedo drive gear Spridgets 15
Rut MGB OD install, speedo drive gear MG 0
Q TR2/3/3A Speedo Gear Drive On Tr3 Overdrive? Triumph 0
ekamm TR2/3/3A Tr3 speedo drive gear needed Triumph 0
K TR6 Speedo gear housings :TR3 and TR6 Triumph 3
S speedo gear Triumph 4
S speedo gear Triumph 1
2wrench Speedo gear/speedo angle parts Triumph 9
B looking for speedo pinion gear MG 8
B Speedo driven gear, '67 Tiger Sunbeam (Rootes) 2
M Speedo Drive Gear MG 3
R TR6 Speedo Experts: Troubleshoot question… Triumph 10
J TR6 speedo Triumph 0
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 4
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 0
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
J Wanted Original BJ 7 speedo Austin Healey Classifieds 0
algot1901 1950 Prefect Speedo Cable Other British Cars 8
George Zeck Speedo Cable? Spridgets 3
Dnickels Spitfire Speedo help Triumph 4
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
R Speedo High Beam Warning Light Color Austin Healey 14
P TR6 72 TR6 Speedo cable Triumph 2
N Speedo identification? Other British Cars 4
Jim_Stevens TR2/3/3A OD angle drive engaging the speedo cable Triumph 8
S TR2/3/3A Routing the OD speedo cable Triumph 9
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
P Help with Speedo Angle Drive Austin Healey 2
T TR2/3/3A Drive end of speedo inner cable to large for pinion Triumph 2
T TR2/3/3A Question on overdrive pinion & bearing assembly for speedo drive Triumph 11
Jeepster Oily speedo Austin Healey 8
Bob_Spidell Disassemble Speedo Adapter Austin Healey 2
S TR4/4A What is the routing for the speedo cable Triumph 2
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
MY66AH Speedo rebuild Spridgets 5
B TR2/3/3A Gearbox speedo drive seal Triumph 1
longbridgehealey Speedo cable from 59 Bugeye Spridgets 1
MY66AH Speedo problems Spridgets 15
doc50 TR2/3/3A Speedo WAY off... Triumph 10
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
Patrick67BJ8 Speedo calibration Austin Healey 22
paul9999 Speedo...just gets quicker and quicker! Other British Cars 2
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
mgedit TR2/3/3A Bouncy Speedo ... Lubrication Triumph 4
trotti Speedo ignition light Austin Healey 12
B Speedo needle Austin Healey 3
doc50 TR2/3/3A Speedo reads way too low Triumph 13
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
6TTR3A TR2/3/3A Speedo in KPH Triumph 21
Gerry M TR6 Speedo Angle Drive Triumph 2
