TR6 Speedo Experts: Troubleshoot question…
Rocky_LC
I have a Smith’s Speedometer in my car.
It is reading very closely to kilometers per hour, if I am doing 64 mph (measured via GPS) it reads 100.
It is clearly marked “MPH”, and the bottom of the dial says:
Smiths S/N 5324/65 1000
Any easy way to figure out if the issue is in the speedo, or the drive gear in the transmission?
Any suggestions as to how to re-calibrate or repair, other than putting a piece of masking tape marked KPH over the glass where the MPH legend is located?
Does the gear come out of the transmission easily? Is the gear marked for easy identification?
Moss used to sell a $6 speedometer gear (now out of stock) and does sell a $56 speedometer gear assembly. What’s the difference (other than $50).
Thanks -
Rocky
CJD
I would start by running a measured mile on the interstate and see what your odometer says for 1 actual mile. The speedo can be out of calibration, but the odometer is always the same. Once you have the odometer reading, we can tell if you have a gear difference or calibration difference.
Sarastro
The odometer runs directly off the cable, through gearing, so it is not subject to calibration. Since you have a GPS, you could compare the GPS distance indication to the odometer, and that should tell you if it's really set up for miles. This is something you'll want to know in any case, for maintenance intervals and such.
Also, is the indication proportional to speed? For example, if it reads 50 is the real speed now 32 MPH? Check a couple more points and see if they are proportional.
That said, I think it's unlikely that your indication would be consistently right for Km in a MPH speedometer. That's more than just calibration being a bit off. But if something were not working right, you would see more strange behavior, like it failing to return to zero when you stop (which would happen if the spring had come loose).
So, as John says, step 1 is to figure out if you have an MPH or Km speedometer. the we can go from there.
R
Rocky_LC
I will give both of those tests a go in the next week, and report back.
Appreciate the responses!
Rocky
Kaybass66
Thanks -
Rocky
This is easy to solve. Contact Powl Speedometer in Lancaster Pa
Thanks -
Rocky
This is easy. Download a speedometer app on your phone. Take the car up to 60 mph on the app and record the speedometer reading. Then, contact Powl’s Speedometer center in Lancaster Pa at 717-898-2552. Send them your speedometer cable and the readings you recorded and they will do the calculations and custom make a dandy little gearbox that will splice into your cable just under the brake booster in the engine compartment. You will need to know the distance from the back of the speedometer to the engine compartment,(about 12 inches if my memory serves me) so they know where to cut it. They will install new ends to fit the gearbox to the cable. I’ve had this in my TR6 for ten years and it’s wonderful Bill Stumm
CJD
Well, that's an option. But!...that will only apply if he has a speedo for a 3.73 gear ratio and is running 4.11 gears. If the speedo gear is correct and the speedo is out of calibration, then adding a compensation gear will throw off the odometer.
We need to see how his odometer reads before we can continue the diagnosis...
R
Rocky_LC
OK, Got some data....
I have about a 15% error on my odometer reading.... If I travel 1.0 miles, my odometer reads 1.15 miles (based on the "tenths" digit of my trip odomoter. This held up over longer distances.
Here's a plot of my indicated vs. actual speed. The slope of the indicated speed line seems different from the "actual" speed, so it's not a precisely calibrated straight MPH / KPH error....
Anyway - heres' the data I collected...
GPS SpeedIndicated Speed
40​
64​
50​
78​
60​
92​
64​
100​
Comments & Suggestions welcome....
Rocky
CJD
The TR's were offered with 2 gear ratios...4.11 and the most common 3.73. Taking your last data point:
64mph X 4.11/3.73 = 70mph. This indicates your speedo is out of calibration, even greater than just changing the differential gear.
Now for the odometer... 1.00m X 4.11/3.73 = 1.10miles. This is still off from your readings, but not far off if you have a 4.11 tranny take off gear with 3.73 differential gears. The .05 difference could be from lower profile tires than original.
So...
My guess is your transmission was once driving a 4.11 differential, and still has the 4.11 speedo gear. This accounts for about 10% of your error and will bring your odometer much closer. Even with the correct 3.73 speedo gear, you will still be off significantly on your speed. This requires a calibration of the speedo, which should not be that hard, unless the clock spring has broken.
You have the option of sending the speedo off for calibration, or I can explain how to do it yourself if you are interested.
R
Rocky_LC
Thanks, John -
Looks like my car (a TVR Vixen 2500, which uses the TR6 engine, transmission, rear end and drive/halfshafts) was originally spec'ed with 165 SR-15 wheels (diameter 25.4") and currently has 195-65 R15 on it. So tire diameter is within about .3" in diameter of the original design - my current tire is a little taller (looks like it's within about 1%). Current tire is about an inch wider, but that doesn't matter.
The rear end ratio in the Owner's manual is 3.45 : 1.
I guess I probably need to confirm my rear end ratio, first.
So - are you saying I should consider a different gear in the transmission speedometer drive, as well as calibration of the speedo?
Thanks -
I would be interested in learning about Speedo calibration.
Regards -
Chuck
Ricks74
My guess is that you have the exact opposite issue I have in my MGB. Changed to OD gearbox and the speedo reads low. Smith made both 1000 and 1280 tpm (turns per mile) speedos. The 1000 is for OD and the 1280 is for non-OD. Switching out the speedo to a 1280 tpm then would correct the issue. If the face of your speedo is compatible with what I have perhaps we could trade?
R
Rocky_LC
Rick…. I’ll consider it as an option as I work through this engineering problem…. Thanks!
Continuing (to gain knowledge): I jumped under the car this morning, and determined I have an “open” diff (not posi- or limited slip). So following my instructions, I put one wheel on the ground, and rotated the other.
Luckily, a strategically aligned zerk fitting on the driveshaft allowed me to clearly measure ~1.75 driveshaft turns for each wheel revolution, confirming a stock 3.54 : 1 rear end in the car.
Now maybe I have to do the 52’ 9 1/2” speedo cable trick?
Rocky
J TR6 speedo Triumph 0
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 4
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 0
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
J Wanted Original BJ 7 speedo Austin Healey Classifieds 0
algot1901 1950 Prefect Speedo Cable Other British Cars 8
George Zeck Speedo Cable? Spridgets 3
Dnickels Spitfire Speedo help Triumph 4
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
R Speedo High Beam Warning Light Color Austin Healey 14
P TR6 72 TR6 Speedo cable Triumph 2
4tecdog Speedo drive gear Spridgets 15
N Speedo identification? Other British Cars 4
Jim_Stevens TR2/3/3A OD angle drive engaging the speedo cable Triumph 8
F TR6 speedo gear reduction Triumph 3
S TR2/3/3A Routing the OD speedo cable Triumph 9
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
P Help with Speedo Angle Drive Austin Healey 2
T TR2/3/3A Drive end of speedo inner cable to large for pinion Triumph 2
T TR2/3/3A Question on overdrive pinion & bearing assembly for speedo drive Triumph 11
Jeepster Oily speedo Austin Healey 8
Bob_Spidell Disassemble Speedo Adapter Austin Healey 2
S TR4/4A What is the routing for the speedo cable Triumph 2
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
MY66AH Speedo rebuild Spridgets 5
B TR2/3/3A Gearbox speedo drive seal Triumph 1
longbridgehealey Speedo cable from 59 Bugeye Spridgets 1
MY66AH Speedo problems Spridgets 15
doc50 TR2/3/3A Speedo WAY off... Triumph 10
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
Patrick67BJ8 Speedo calibration Austin Healey 22
paul9999 Speedo...just gets quicker and quicker! Other British Cars 2
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
mgedit TR2/3/3A Bouncy Speedo ... Lubrication Triumph 4
trotti Speedo ignition light Austin Healey 12
B Speedo needle Austin Healey 3
Rut MGB OD install, speedo drive gear MG 0
doc50 TR2/3/3A Speedo reads way too low Triumph 13
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
6TTR3A TR2/3/3A Speedo in KPH Triumph 21
Gerry M TR6 Speedo Angle Drive Triumph 2
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
E TR4/4A Speedo v Tach cable Triumph 2
krswen Looking for advice on XJ6 overdrive unit speedo drive Jaguar 2
Gerry M TR6 Speedo Angle Drive Triumph 9
F Speedo problem BT7 - cable rotates but speedo does not Austin Healey 25
Gerry M TR6 Speedo stopped working Triumph 6
M TR2/3/3A TR3 Speedo cable Triumph 4
M Speedo pinion on Overdrive Austin Healey 1
G MGB Tach and speedo rebuild. MG 3
