TR2/3/3A Source of TR3 Gearbox Leak?
RedTR3
For several years I have had a gearbox leak at the rear of the gearbox and I just keep topping it up every couple of months (oil is still fairly cheap). But if the fix is easy I should try to do something....in looking underneath, there is a lot of oil at this item that looks like a plug with about 1" across the flats. What is this plug? I do not see it in any catalog diagrams. Is there a gasket associated with it? Thanks!
Moseso
Re: Source of Gearbox Leak?
Did you know you have an overdrive? That's the drainplug/filter-screen access on the A-type overdrive. Yes -- there is a washer that goes under it. Mine has a fiber washer. Your picture looks like there's an aluminum washer under there. For some reason or another, the socket in my collection that fits it best is the 30mm.
RedTR3
RedTR3
Thanks! Yes I know I have the overdrive, it is not working due to (most likely) a bad solenoid and since I drive just on city streets it has not been a priority for me to repair it.
So I assume it is safe and wise to remove this plug and replace the gasket and refill?
TR3driver
Great Pumpkin - R.I.P
I would suggest first trying to be sure it's really that gasket that is leaking. Since it's the lowest point on the OD, any other leak tends to run down and drip from the plug. I know I spent a long time and many oil changes trying to get mine sealed, only to find that it was the adapter plate that was actually leaking.
I also use a 30mm socket, but I ground away the tapered portion at the lip of the socket to give it a better grip on the plug.
As Moses said, the gasket should be fiber. Some Hylomar may help it to seal. If you do remove the plug, you should also clean the screen and magnets.
PS, Depending on the vintage of your OD, you may need to remove a bolt to get the screen out. Don't lose the washer and spacer that go on the bolt.
TR3driver
The drain plug gasket is available from TRF as P/N 500641
pjsmetana
Don't forget RTV!
TR3driver
pjsmetana said:
Don't forget RTV!
Please do forget RTV!
That stuff has no place around hydraulic systems, like overdrives. Much too easy for the bead that always squeezes out inside to break off and clog tiny passages, like the bleed hole in the operating valve on an A-type OD. That can literally lead to destruction of the unit (although the odds of that actually happening aren't very high).
HealeyDave TR2/3/3A TR3 Dash Cover Source Triumph 9
B TR2/3/3A Best source for new top for TR3 Triumph 3
mgedit TR2/3/3A Source for Brake Pipe 56 TR3 Triumph 9
B TR2/3/3A Advice on TR3 rear bumper overrider source Triumph 7
K TR2/3/3A Source for TR3 wheel studs that are 1" longer? Triumph 8
HealeyDave TR2/3/3A TR3 Frame Source? Triumph 2
R TR6 Help: Brake Part Source or …. ? Triumph 1
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
Jayplum TR2/3/3A Source for quality parts Triumph 11
B Vacuum Source Austin Healey 4
W Best source for Bugeye front shocks Spridgets 3
B TR6 Source for Carmine Red Triumph 4
steveg TR6 Source for fuel line P-clip Triumph 17
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Michael Oritt Tenax fastener source needed Austin Healey 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
R TR6 Body Parts Source, Upper Midwest Triumph 6
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
S TR2/3/3A source for those little drain hoses Triumph 6
I TR6 Source for Elevator Bolts? Triumph 16
I TR6 Source for license plate light bracket? Triumph 5
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
MikeAH100M Whitworth Source Austin Healey 8
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
K Healey Blue Paint Source Austin Healey 30
D Body work finishing supplies source. Restoration & Tools 0
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
JPSmit DC Power source thoughts Restoration & Tools 11
B TR2/3/3A Locating source of oil leak Triumph 6
J Half round tube or D tube source ?? Restoration & Tools 2
B New frame candidate or parts source? Austin Healey 12
S Bay Area source for 60 Sprite Roll Bar? Spridgets 6
Jim_Gruber Source for PosiDrive Screws Spridgets 7
R TR2/3/3A Source for rubber seal on A/M side curtains Triumph 4
J TR4/4A TR4A rear wheel cylinder source Triumph 3
I Bigeye transmission source? Spridgets 7
Rut TR4/4A Good interior source Triumph 29
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
Jim_Gruber Source for Small U Bolts on 1/4 Elliptic Springs- Spridgets 11
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
Csarneson Source for BN4 2nd Gear Austin Healey 8
CJD TR2/3/3A Source for Horsehair Padding? Triumph 10
Michael Oritt Rear upright casting--source needed Racing 4
