Seat floor position
vette
Well, I lost my pattern. I thought that I had seen someone post the dimensions of where the seats should be bolted to the floors but have searched and can,t find anything. Can anyone post some reference dimensions of where the holes should be drilled in the floors on a BJ7. Thanks Dave.
Patrick67BJ8
I downloaded these from the web. I don't know who the authors are but my car is a BJ8 and I used the "blue" one.
vette
vette
Thanks Patrick, I messed around with it a little today, playing withdifferent positions and seeing how far the seat would move on their tracks and how close it would come to the tunnel. Then sat in it to see if I liked the leg positions. Made marks on the floor. Now I,m really curious how the dimensions in your drawings will come close to what I have done. HAVEN,t drilled any holes yet. thanks again. Dave C. (Typing really bad, using wife's IPad and she wants it back!). :smile:
Griz
For what it's worth, I used the dimensions shown in the third picture above for my BJ7. Still have not installed the seats so don't know for sure how things will work out. The mounting holes on the driver's side did match up well with the heat shield holes however. - Griz
bob hughes
I also used the third picture, the position is not too bad, but the seat belt fixing on the floor is quite close to the seat frame when installed, but there again it was before I put the new floor in.
:cheers:
vette
vette
Thanks all. Still sneaking iPad. My computer in for repairs.
andrea
The second photo are make and used from me, to make a cardboard 1:1 pattern for holes and insulation panel, for drive side LH it appear correct to me, car is finished and driver position is good and comfortable
I have reversed the pattern for passenger side and I HAVE A PROBLEM (easy) I must modify the seat base holes-
passenger seat are very nearest to the hand brake in particular the bolt of the seatback articulation
I hope that advice can be useful. and my error will not repeated
Cheers
Andrea
Patrick67BJ8
My biggest problem was getting the holes where they should be and once I used the center of the chassis for a referrence point of dead center it all fell into place. As Anrea indicates in his post about the emergence brake being to close to the seat on the passenger side...I need to check that one next. I am planning on going to see a friend who has an unmolested BJ8 and getting exhause mount hole locations, etc. and I'll check the emergence brake on it. I have purchased a trammel tool for use to accurately measure the distances between the seat, exhaust & insulation panel mounts.
vette
vette
I compared the specs of the 3rd drawing with what I laid out yesterday in my experimentation. My proposed position was one inch to the rear of the specs in the drawing and 1/2 inch inboard of the specs in the drawing. It is good that I had those specs because my rear ward position would have put the rear bolts too close to the rear outrigger. But I would have seen that eventually but the drawing was a big help. I am going to compomise on the side to side specs in that I will use the position I came up with that is 1/2 inch inboard of the drawing. I have put the seat in place many time in the last few days and I feel confident that my adjustment to the lateral position won't interfer with anything such as the width of the tunnel if the seat is pulled way forward. all this has been with the drivers side seat. Andrea's point is well taken and I will probably do some trial and error when fitting that seat as well. But I believe also that the first drawing presented by Patrick is of a passenger's side. It should help alot. Dave.
B TR2/3/3A anyone help me identify the screw attaching seat slide to the floor? Triumph 8
C MGB Re strapping a MGB seat bottom MG 2
T TR4/4A TR4 seat buffer problem Triumph 5
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
A MGB Seat Cover Installation MG 1
tr6nitjulius For Sale 4$ale: 3 Point Seat Belts Red Triumph Classifieds 0
D TR2/3/3A layout for lap type seat belt Triumph 5
R Vixen 2500 Seat Buckets TVR 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Celtic 77 MGB Seat webbing replacement. MG 1
B BJ8 Seat Sliders Austin Healey 4
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
TomMull MGA Rumble seat MGA MG 3
T Three-Point Seat Belts Austin Healey 8
B Seat Inserts Austin Healey 6
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
Celtic 77 MGB Seat Diaphragm replacement MG 0
D New seat covers Spridgets 11
Celtic 77 MGB 1977 seat webbing replacement. MG 1
shadowfever Seat runner with lever Spridgets 2
F TR4/4A Seat rail extension Triumph 4
KVH General Tech Seat Upholstered Panel Triumph 2
shadowfever Midget seat nuts and bolts Spridgets 2
shadowfever Moss Motors MG Midget seat covers Spridgets 6
shadowfever 65-69 Spridget seat Diaphragms Spridgets 5
Challenger TR4/4A Seat Retainers Triumph 1
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
D Rear Seat Side Panels, BT7 Austin Healey 3
M For Sale vintage 3-point retractable seat belts MG Classifieds 0
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
A For Sale '74 TR6 original seat frames Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
C Seat Slide Bearings Austin Healey 3
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
EricJNewman MGB Modern Seat Tracks in MGB Solution MG 8
crispy BJ8 Rear Seat Back Upholstery Hardware Austin Healey 7
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
mrv8q TR2/3/3A TR3A TRF vinyl seat reupholstery kit Triumph 7
J TR4/4A TR4A seat retaining clip Triumph 5
R BJ7 Back Seat-Rest Austin Healey 1
A TR2/3/3A Seat position Triumph 2
jlaird Wanted One Bugeye seat Spridgets Classified 0
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
J TR4/4A Seat install, Spring clip Triumph 0
M 1972 Midget Seat Belt Replacement Spridgets 4
