Rover Metro
Erlend Kristiansen
I've heard some rumours that the engine and disc-brakes from the first versions of the Rover Metro fits on a Mini. Is this true? And how old/new should the Rover Metro be then? I'm looking for a cheap (but safe) conversion to disc-brakes for my Mini.
You can see some pictures of my Mini that I recently took: https://naf.as/mini
slewi
I am looking at doing the same thing, I had a chat with somebody else who has already done this and he had no problems, I dont believe it can be that simple though.
One thing is you will have to go to 12" wheels.
Also I think a servo will be called for so possibly some issues there.
I am looking for a fairly recent Metro this should make it in better condition.
aeronca65t
Many years ago (here in the U.S.) I converted an 850 Mini to Austin 1300 front disk brakes (and 12" wheels). It was not easy and I wasn't happy with the job (eventually, converted back to drum brakes). Not sure if a "Rover Metro" is similar to an Austin 1300, though.
slewi
The Rover Metro strated out as the Mini Metro in the UK, it was supposed to be the replacement for the mini but it wasnt well received.
Used loads of mini bits, I think the first ones were minis with a different body.
Dont know if it made it to the US.
In the UK it is a good source for 1300 engines brakes etc
I hadnt thought about the Austin 1300 probably because we dont have many scrap examples in the UK, they have all rusted away, the one that are around are in use by enthusiasts
aeronca65t
Found info on Metro disc brakes/Mini conversion on this site:
https://www.ime.org.uk/
Here’s some of the info from site:
When fitting Metro disc assemblies, it is important to make sure that you use the correct parts...
Metro bits to use:
- Discs
- Calipers
Mini parts to use:
- Hubs
- CV's
- Drive shafts (the metro ones are longer!)
- Swivel (ball-) joints.
- Steering arms (the metro ones give bad handling due to incorrect Arkaman angles (see under 'A')
The wheel mounting lugs also need cutting off.
If the Mini has disks on it already and you just want 4pot callipers just swap the callipers over on to the mini hubs and mini disks. You also need a set of Metro-mini conversion hoses BTW. If you want vented disks then you need a pair of vented discs with the Metro drive flange (with the wheel placement bits milled off) the vented/non-vented callipers are different BTW.
If you are going to put 12" wheels on your mini then I suggest you use mini disk hubs (Cooper S, 1275GT and Late minis disks hubs are the same) As Metro hubs require a little more work to fit on a mini as you would need to fit neg bottom arms and modified mini steering arms to fit them on to a mini.
So To convert to 8.4inch disks you need... Late mini hubs and CV's 8.4" disks.... You can fit vented at this point if you fit callipers from a
metro that had Vented disks on it and the drive flange modified as above. Callipers from either a mini or a metro (need conversion hoses if fitting metro) If you have the Brake master cylinder that looks similar to the clutch one then you will need it change it as it doesn't have enough capacity.
J Land Rover research Rover / Land Rover 4
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
F For Sale Rover V8 blocks for sale Other British Classifieds 1
C For Sale Rover Mini Blue Star Tribute Other British Classifieds 0
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
CJRams For Sale 1996 Rover MGF 1.8i - $15,000 MG Classifieds 3
A For Sale Rover V8 heads, 10 bolt Other British Classifieds 0
A For Sale Supercharger setup complete for Rover V8 3.9/4.0/4.2 Other British Classifieds 3
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
D Land Rover engine swop. Rover / Land Rover 1
BoyRacer Rover 3.5L (Buick 215 c.i.) Engine Swap Austin Healey 15
A MGB Donor Rover 3500 P6B for my MGB MG 5
albertemore Range Rover Classic Parts? Rover / Land Rover 5
G Rover P3 Brake Lining - Front Rover / Land Rover 2
hutten Wheel sizes for Rover Mini Mark VII British Motor Corp 1
PAUL161 Land Rover 73 Rover / Land Rover 0
Z MGB My 5.8 OHC Rover V8 build yes this is a P76 block from do under! MG 10
Steve Range Rover Evoque Convertible Rover / Land Rover 2
LarryK Land Rover Repair or just plain how to! Rover / Land Rover 1
catfood Land Rover Evoque Convertible Spotted 1
aeronca65t Landwind - fake Rover Rover / Land Rover 3
Steve Land Rover 90 vs. Dodge Ram Rover / Land Rover 1
Boink First Range Rover Rover / Land Rover 2
Nunyas Patrolicious - 1973 Land Rover Series III Other Cars 1
K Land Rover Defender - Mountain Rescue Team Rover / Land Rover 0
N Land rover and coffman cartridge starter Rover / Land Rover 0
HealeyRick A Visit to the Land Rover Factory Rover / Land Rover 0
B Rover V-8 main bearings Rover / Land Rover 5
G Rover 3.9 info?? Rover / Land Rover 1
JPSmit Land Rover Defender - and Home made special Spotted 1
aeronca65t Rover car carrier Rover / Land Rover 1
JPSmit Land Rover - hopefully good news. Spotted 9
M T16 engine, ecu and two key fobs, or Rover 820 Rover / Land Rover 0
aeronca65t Churchill's Land Rover For Sale Rover / Land Rover 1
aseriesspares LAND ROVER SERIES 3 Complete Hardware Sets 30% OFF Rover / Land Rover 0
Steve New Land Rover Defender Rover / Land Rover 9
58Custom Rover V8 in SoCal self-serve junkyard Rover / Land Rover 0
G Rover V8 interchange/swap question MG 9
rosalind Bye Old Rover...Hello new Rover Rover / Land Rover 2
aeronca65t Land Rover Forward Control Rover / Land Rover 0
T What car could use a Rover V8 Other Cars 3
Got_All_4 Wedge Rover 3.9 in a Tr7 Triumph 34
Steve Range Rover Evoque Rover / Land Rover 1
AngliaGT Rover 3500 Rover / Land Rover 1
M 2000 range rover????? Other British Cars 1
D 1935 Rover 10 wiring dia. and head lamp solonoid.. Rover / Land Rover 2
weewillie rover p6 and nissan skyline Spotted 0
racingenglishcars Land Rover collection for sale - in Norway, Dec 4 Rover / Land Rover 0
S Looking for a Rover 215 motor. MG 9
JPSmit Rover for sale Other British Cars 4
