Revamped the BJ7 seat cushions
bob hughes
Wow what a difference
Just finished fitting new foam in the seat cushions, did both in the end and it also entailed rebuilding the seat pans which were shot, what a real pleasure to drive now, nice and comfortable, and the navigator has given me extra brownie points - whey hey.
Win - Win all round
:cheers:
Bob
GregW
Brownie points good! :thumbsup: Did you have to make any of those holes or are the foam replacements softer now-a-days?
davidb
Bob, since you brought up this subject, you raised a question about my fitting of the horseshoe type seat covers on my BT7. The new foam bottoms from Moss went on fine along with with new (vinyl)seat covers, altho they did require some stretching and refitting of the vinyl to get a smooth straight finish on the piping. The seat backs are a different story - I got the foams nicely glued in place to the metal seat back, but are you supposed to then glue the centre part of the seat back vinyl to the seat back foam? I tried working the vinyl over the seat back foams on a nice warm day, and they're still not fitting well. It seems as though the rounded top edge of vinyl on the seat back is not cut quite right - I may have to beef up the seat back with some extra foam to get a smooth fit at the top edge...
Anyone else had this problem, or am I just being too picky about the fit?
Thanks
Dave
You have to pad the top (and backside) of the seatbacks.
Yes, the center (pleated) section requires gluing to the foam, then once dry (PATIENCE!) you can work the top seam into submission.
Best way I found to hold the center section to the foam while the glue dries (I left them overnight):
B
bob hughes
Greg
No, I did not form any holes, but it was suggested at Rawles that I did.
On the passenger side there is no seat adjuster on my car so I just put the foam in as received, having checked the head room to the top first.
On the drivers side there is a seat adjuster so that raises the base up, I ended up cutting 1.25 inches off the base of the foam - still no holes.
I found the seats comfortable built this way, some may think that they are a bit stiff and you do not sink into them much but I like it that way. I have no need to have the cushion grip the rear end like a bucket.
Having said that, I took both seats apart again after the first fitting of the covers. In the first one I found that I needed to pad out the central section as the covers appear to be 'home made' by a PO and did not include padding in the ribs, it looked really bad without some central padding. On the second one I included padding first time around but it was the head room issue, I trialed it without cutting and determined that I needed to cut something off in the region of 1" to 1.5", not wanting to screw it up I took a 5/8" slice off, stuck it all together - clips and glue an rivets and tested it, I had to remove clips and rivets and ease the cover off the bottom of the pan, keeping the cover glued to the top of the foam and trimmed another 5/8" off the foam. I kept the foam from the front gear box side and stuck it back on but outside the pan, as there is a big overhang - pan to foam, on that corner, I felt that it helped keep the line on the finished work. What I am getting around to in a long winded way, is that you can always cut holes in the base of the foam after if you do not like the feel of the seat, without too much effort.
:cheers:
Bob
Dave - I have no info on refurbing the seat backs, I did not intend to do anything with them at this moment and did not ask the upholsterer for any tips, so go with Randy on that one.
:cheers:
Bob
davidb
My thanks to Bob for his comments and to Randy for his excellent photos (obviously you're making your own ethanol with those bags of corn), which were self-explanatory and extremely helpful. You know, it's the fact that enthusiasts like yourselves (and a solid core of regulars) take the time to reply and share solutions for the rest of us, that makes this website a real treasure.
Cheers and regards
Dave
Elva164 I've totally revamped my shop website! Racing 2
Kim de B Revamped MG2004 site MG 0
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
HealeyRick BJ7 Side Window Alignment Austin Healey 31
B BJ7 Interior Finishing Details Austin Healey 2
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Door Seal Austin Healey 5
chicken BJ7 Rear Quarter Panels Austin Healey 6
B BJ7 Boot Trim Austin Healey 7
T Early BJ7 Vent Window Seal Austin Healey 2
D BJ7 Underdash Trim Austin Healey 9
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Rear rail trim Austin Healey 0
D BJ7 Hood frame mounting plate Austin Healey 7
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
T Installing Garmin GPS in a BJ7 Austin Healey 19
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
P BJ7 Upholstery Austin Healey 1
B BJ7 back end rebuild Austin Healey 1
Marvin Gruber BJ7 door panels Austin Healey 4
Marvin Gruber BJ7 Top Installation Austin Healey 1
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
Marvin Gruber BJ7 tach cable location. Austin Healey 3
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
