I have still not completed this project and as with so many things Healey another issue (small I hope) has appeared that keeps the car up on jack stands:
After finally receiving the new timing-cover-with-lip-seal-conversion from DW I attempted to button everything up last weekend. Rather than glueing the fiber gasket to the inside of the timing cover before assembly with Yellow Peril or the like I (unwisely) opted for Permatex Ultra-Copper to use on both sides of the fiber gasket.
To make locating the cover easier I pushed the inner shoulder of the front pulley into the lip seal and started the pulley onto the crank snout. TWorking from I slid the cover/seal back against the front plate and began loosely fastening the cover down starting at the top.
It was not easy accessing the bolts and by the time I got to the bottom I found that the gasket had sagged perhaps 3/8" and though I finally succeeded in getting the gasket back under the flange with small flat tools, etc. I had the feeling that I might have damaged it in the process, creating a new path for oil leaks. Plus I found that several of the bottom bolts were soft, undoubtedly by someone's having overtightened them in the past (who could that have been?).
So, I removed everything and ordered a new gasket and fasteners from BCS and will start over in a couple of days. MORE NEWS AS IT HAPPENS.
