TR2/3/3A Removing the silentbloc rubber pieces. From the steering linkage bush
GTP1960
I was able to push the silentblocs out of the linkage bush Housing with a gear puller, but the bushings left a lot of rubber behind, (that is real stubborn!).
I don't want to damage the linkage housing by scraping it out. Does anyone have a suggestion or standard practice?
I' m replacing with the delrin pins from TRF.
thx
Guy
TR3driver
Great Pumpkin - R.I.P
No need to worry about the rubber; there is a steel sleeve on the outside of the rubber that you'll have to get out as well. Tap it out with a punch. If it won't budge (mine were pretty well stuck), try cutting most of the way through the sleeve with a hacksaw blade. Then you should be able to break the remaining bit with the punch & BFH.
CJD
There is a metal shell on the outside that needs to be pressed out. It is the part the rubber is bonded to.
Don Elliott
I used my pneumatic-driven die grinder (like a Dremel) to remove that outer steel bit from the hole. I've also used a hack-saw to take off the top flange to hammer out the center pin and most (some) of the rubber. I too have installed the new delrin-designed "silent blocks" but I put in some red synthetic grease from Amsoil to keep them sliding and "silent". They have been there about 3 years now with no issues and the steering seems to have less slop in the steering wheel.
TR3driver
What kind of bit did you use, Don? I seem to have a terrible time controlling my die grinder in situations like this, so I almost never use it inside relatively small holes.
GTP1960
GTP1960
Thanks guys,
i didn't realize the sleeve had to come out too.
i scored them in 3 or 4 places with a jig saw (tough stuff: went thru four blades) & then tapped them right out.
Don Elliott
Randall - The bit I used in my die grinder had a 1/4" shaft and about 3/8" diameter double cut bit. I held the assembly in my vice and took great care to grind away that outer barrel without touching the part holding it. If you get that tubular wall really thin in one or more grooves from one end to the other, you can tap or tear out the remnants you need to remove.
Cheers
Don
TR3driver
Thanks, Don.
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
KVH TR4/4A Removing Glass Windshield Triumph 4
KVH TR4/4A Removing the Differential Triumph 7
T TR4/4A Removing wiper motor - inner cable Triumph 4
