coj
Member
My 3000 came with side curtains that had not been used. They have a protective advesive paper covering over the plexiglass.
My problem is that this covering has been on the plexiglass for so long it is very hard, if no impossible to safely remove without scratching the plexi.Does anyone know of an adhesive remover that can be use for this? Is there a way to soak them off, I have already tried leaving them in water, both hot and cold, no luck. Thanks for any info.
