KVH
On my 4A, I'm removing the oil canister and pressure housing to address a leak, and plan to reinstall immediately.
I removed three bolts and the oil pressure line--and the housing won't budge. I assume it's just the gasket fused to the block? Nothing else is holding it tight?
Also, about that oil pressure line, I'm not seeing a hole in the little stud that the oil line slides over, but I assume it's there somewhere--otherwise how could the pressure gauge work? Dumb question, I know, and maybe I need to look closer, but it's certainly not obvious to my nubby fingers reaching down there.
thx
thx
