Removing chrome from threads
lbcfan
Just when I think I'm home free...
I had the BE grab handle re-chromed, and the plating left a thickened area on the end of the 1/4-28 threads- can't get the nut on.
I tried a cheap die but it wouldn't start on the thread.
I've read that hydrochloric/muriatic acid will remove chrome, but the area is coated pretty thick. Does anyone have a better "solution"? A wire brush wheel didn't touch it.
Thanks,
Michael
kalist
I would try using a small file to clean the excess down to a point where you could run a die down the threads. Be very careful you don't jam the die and snap the stud off.
Rut
IIRC, HF has a cheap thread restorer that might do the job. I don't know if this would work, but you might be able to set up a plating bath in reverse and remove it that way.
Good luck, Rut
L
lbcfan
Thanks everyone for the suggestions. I took the easy way out and cut off 1/4" of length where the blobs were. Still left plenty of thread for proper fastening.
If you are having parts chromed for the first time ask about this issue, and also whether they properly finish only the front side of the bumper, or both sides. That was another surprise.
Michael
rkep01
Michael
I've got an original B/E bumper and it looks like it was chromed on both sides, but only the front side is polished and shiny. The back of the bumper looks like chrome, but it's very dull, as if the back was not polished.
Whitephrog
Michael
The grab handle is pot metal as I recall. Did your chome guy have any special issues with that?
L
lbcfan
The handle was fine- it didn't seem like pot metal, and the threads were longer than needed. My motorola radio face was pot metal and the chrome finish was poor, with a lot of pinholes. Fortunately all but the bezel is concealed behind the flat chrome plate that covers the dashboard cutout.
It's funny but I get no reception on the radio, but a little static. Are there still am stations? I was hoping to get Cousin Brucie one more time.
After 42 years I noticed that the radio has the 2 conelrad stations marked on the dial. That brought back some memories as well...
Sarastro
Yeah, there are still AM stations, but they're not worth listening to. Here in LA they are just a source of ads for scam products.
Look around ebay a bit. The AM-only period radios are pretty cheap. Unfortunately, the AM-FM ones tend to go for much more dough.
I'm old enough to remember Conelrad, too. Very cool! I remember periodically testing the system when I was a tech at AM and AM-FM radio stations.
Billm
I still have my old "period correct" JC Whitney AM/FM converter from my Sprite in 1969. Doesn't need to be rechromed yet!
BillM
startech47
The plater can mask off the threads and eliminate the growth problem if asked, both for external and internal holes.
We had parts that needed to be hard coat anodized in sections and irridited in other sections. They would mask off the areas to be irridited, anodize the part, remove the masking, and finally irridite the part. The internal threaded holes were masked off and after the part was finished we would insert helicoils in the holes. Without the masking the screws would not fit. Tapping the holes was too hard to do and we needed the finish under the helicoils.
The hard coat anodize was for radiative heat transfer and the irridite type 3 was for electrical conductivity.
L
lbcfan
I remember JC Whitney was the go-to place, way before the internet. Of course I also remember the Sears catalog...
aeronca65t
lbcfan said:
.......It's funny but I get no reception on the radio, but a little static. Are there still am stations? I was hoping to get Cousin Brucie one more time.
My MGB also is fitted with the original AM radio, but it's a '69 so too new for Conelrad (replaced by the Emergency Broadcast System in the mid '60s).
Yes, there are still AM stations in the NJ area, but in my opinion, they are not worth listening to.
Cousin Brucie is still around. He's on Sirius XM satellite radio, on the "'60s on 6" channel. For a while, he owned an AM station in Dover, NJ (near me).
nomad
I really miss decent AM radio. You could drive across the country tuned to just a couple stations. With FM you have to go looking every hour or so. Sure theres Satelite and cd's but I am really mad at haveing to pay for everything now days that used to be free. I'll never forget driving all night to get to the Sturgis motor cycle races and listening to old radio drama's on WNAX. After midnight they would air stuff from the 30's and it was so interesting that it kept me wide awake.
Kurt.
Deleted member 9684
Michael, Who did your chrome?
Also looking for someone to strip, polich and anodize my windshield frame and cockpit surrounds if anyone knows of a shop in the northeast(really prefer not to ship if I don't have to)
L
lbcfan
Seano-
I went to a local plater in Asbury Park- the closest to my home that I could find- Merchant Superchrome. The result looks good for my driver- I can add some photos to my Imagehosting page if you like.
I had the hubcaps, the front bumper and bumperettes, the radio bezel and plate (mine is the same as yours) the grab handle and (of course) the turn signal light bezel for $425, and he dropped off the parts when finished!
The problems were the buildup on the threads on the handle, and the fact that I did not know enough to ask about doing both sides of the front bumper.
One other issue- if you have the gearshift lever done do not plate the ball at the bottom. I had that done earlier and found that the lever wouldn't move when first installed. The plating began grinding off the ball as it moved. Have them avoid plating that part.
I'm watching your progress with interest. Thanks for the photos.
Michael
W Chrome strips and removing paint. MG 6
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
KVH TR4/4A Removing Glass Windshield Triumph 4
KVH TR4/4A Removing the Differential Triumph 7
