Picked up my Midget, question for aeronca65t
JordanB
I picked up a '78 Midget that I'm going to convert to chome bumpers. I saw your page describing the process, thanks.
I was just wondering if the '74 fenders are required for the conversion, or just to eliminate the side marker lights?
I do have to replace one of the fenders anyways.
tony barnhill
Great Pumpkin - R.I.P
I'm not 'aero', of course, but you'll find that there are modifications that have to be done to the fender down behind the rubber bumper to affix the front parking light/turn signal as well as the front bumper....also, depends on whether or not you want the original chrome bumper look - if so, you'll have to change out the fenders; if not & you're willing to have a slightly different front appearance, the rubber fenders can be modified
Bugeye58
Tony, those "rubber fenders" you mention sound like exactly what I need for the race car! Where can I get some??!!!
Jeff
[ 03-31-2004: Message edited by: Bugeye58 ]</p>
tony barnhill
Matthew E. Herd
I actually found that using large washers and appropriate nuts allowed that the rubber bumper lights be fitted into the openings. Its not a perfect fit (the edges hang over the opening a little bit), but it does make the car legal to drive (according to lighting req's, at least, if not in any other way). Also for a jury rigged job, it's better than the fit on some Ford headlights I've seen that came straight from factory and went into undamaged fenders ... (not that I have anything against Ford ... wait, I really do ...)
aeronca65t
As the fellows above have stated, you can reuse the original rubber-bumper fenders, but the parking lights will have to be rigged since the newer fenders don't have the correct openings and they are in a differnt spot (and there is no normal parking lights that will fit these openings since they were not intended to hold parking lights).
On my car, I intended to put the parking lights in the grill and use the openings as brake-cooling ducts, but by chance, I was given a perfect pair of '62 box-Sprite fenders, so that's what I used. Last year at Watkins Glen, I crashed heavily and wrecked the left front fender, so now my car is sporting one new and one old fender! It looks goofy, but it's mostly a racer, so I really don't mind....I'm actually working out something to make it look better this week.
One thing to watch: there are *two* styles of "older" fenders. One has the parking lights mounted higher than the other (everything else is the same...headlights, mounting bolts, etc.). The actual parking light will fit either one. They look pretty close off the car, but will look funny if you mix-and-match.
tony barnhill
One thing you could do is find an old Midget & cut the area below the headlight off a set of bad fenders & graft it onto your 'rubber' fenders...
Tony, The only place to easily seam the fenders would be directly at the top of the wheel arch. Seaming it below the headlight(for example) will get you into the factory seam and all sorts of compound curves that you will never get quite right. I have a front fender seamed at the top of the wheel arch, and it fits very well and the seam is not noticeable(except for the underside). But if I had to do it again I would just keep looking for a fender in decent shape.
tony barnhill
Trevor...though I've never done it on a Midget, I've done it on MGB fenders several times - no big deal actually....just cut the desired panel from the good fender, line it up against the fender to be repaired, mark, cut, & butt weld...a little filler & you'll never know it was done. Heck, you can even do it without removing the fender from the car!
Ah, I see, I thought you were talking about seaming the fender together (roll edge and spot weld). If you want to patch them together and aren't a fiberglass snob then sure you can patch them together. But on a midget the fender is stamped from a single sheet of metal and it is seamed from the inner lower headlight opening to the grill mouth. (avoid this area if patching) The seam there is lead filled (obviously) so care needs to be taken not to overheat when welding your patch panel. I would still prefer to do a seam than try and match contours, but every one has their own preferences. And maybe I wouldn't feel that way if I was decent at controlling my welds with hammering.
tony barnhill
Don't think Jordan is thinking 'concours'...he's converting from rubber bumpers to chrome bumpers - my way is the easiest way!
True, it is easy. And obviously he is not thinking concourse, but since he is wanting to switch to chrome bumpers for appearance (I think, but it could be performance) I would expect that he'll want it to look nice. And I agree that patching can be done and never be noticed. However, my personality wouldn't allow me to leave them in a "good enough" state. It is always my intention to get the body straight enough that no one will notice slight imperfections, but for what ever reason I keep working it fearing that someone will notice those imperfections. It is difficult to explain because I am NOT a perfectionist, but rather paranoid(of sorts). Bottom line he needs to do what he feels comfortable with in terms of cost, ability, and desired outcome. Now... about that rear fender. That is a little more challenging isn't it?
tony barnhill
Trevor - on an MGB its not a problem as parts are available to weld onto the rubber body to match the chrom body lines....again, I've not done it to a rubber Midget but I have taken the butt off a chrome Midget & put on a rubber midget - again, real simple welding job...
...oh, a good welder can mate 2 panels & you'd never be able to find it after the bodywork is finished....you should see ehat the body shop is doing to my '79 V8 car...here's just 1 example:
[ 04-01-2004: Message edited by: tony barnhill ]</p>
Interesting look. Looks like a good job. The part below the taillights is not available for a RB midget AFAIK. My dad builds street rods and now that he is retired I'm picking up the hobby as well. Before I went to college I spent many hours in the Garage restoring a 69 Falcon and repairing an old Toyota Celica after it was totalled. Anyway, my Midget is my learning project. I call it the Mongrel. It is a 1970 with a 1972 rear clip. My welding skills are crude enough that I've had my father weld any panels that required an excellent fit. Anyway...
A rubber bumper to chrome bumper conversion on a midget is more involved than the conversion on a MGB, but seems still very doable.
tony barnhill
Trevor - probably true...but, I'd just go out to my MG Graveyard & cut the butt off a chrome Midget & weld it to the butt of the rubber bumper Midget
I bought the Mongel from a fellow that has a similar graveyard. (over 35 MG's in various states of disrepair and assort other British cars)
tony barnhill
Trevor - that's just one view..other views would show Magnettes, MG1100's, MGB's & GT's, Rover, Corvairs, Morris's....probably on the average 50 or so cars!
C picked up the 62 midget today SALE wire wheel conv Spridgets 0
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
Rut TR4/4A Just picked up my frame Triumph 14
Rut Picked up an enclosed trailer today Spridgets 3
A Picked up this '77 today Spridgets 7
5 Picked Up the Wreath Spridgets 10
Banjo Just picked up a brake lathe Restoration & Tools 1
M_and_P Picked up my Bonnet Spridgets 4
T picked up a spider to part out Triumph 4
J TR4/4A 67 TR4A IRS picked up today! Triumph 23
H Look what I picked up for the Healey today. Austin Healey 13
A MGA hey guys picked up a 60 mga on craigslist MG 20
1 Picked up the car today MG 19
T TR2/3/3A Tush - TR3a louvres or not? Color picked out yet? Triumph 15
jaegzie Picked up my first British bike 07 Daytona 675 British Motorbikes 4
B MGB-GT 67 BGT picked up today. MG 1
jlaird Picked up Miss Agatha Spridgets 20
RickB Just picked up some parts... Spridgets 6
hilsideser need something picked up in Virginia Triumph 5
AngliaGT Picked Up Some Older R&T's Triumph 13
losmorob Picked up the motor today MG 5
B Picked up some vintage plates, now... Spridgets 18
PATR8 UGGGG!!!! I saw an 8 same color green I picked Triumph 7
jlaird Picked up trailer yesterday Spridgets 12
B Just Picked Up Spridgets 10
B TR6 Picked up my TR6 Triumph 12
jackq Picked up my XJ6 today...FINALLY Jaguar 10
macino62 Picked up another motor....... Triumph 5
kennypinkerton Just picked up the LTD... Other Cars 24
jackq MGB Picked up the MGB MG 7
B Picked up my BJ8 today - First ever time to drive! Austin Healey 15
G Picked up my new [200] Landcruiser yesterday. Other Cars 3
philman Wedge picked up my "new" 76 tr7 fhc Triumph 6
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
