MGB OEM Original MGB Chrome Bumpers
princetn1
Member
SOLD...Yah. OEM Original MGB Chrome Bumpers
This seems to be a very educated forum so please educate me. I'd like to know and see the differences (difinitively) between the originals and Classic Gold reproductions. Thanks so much.
Sold...actually bartered and traded. Both won!!!
Flash_Harry
Not sure, but the bumpers on our GT may be after-market units. At both ends, the edges are quite rough, like maybe the die used to stamp the metal was past its prime. I don't think the originals would have been that rough, plus the metal seems a bit lightweight, maybe. I'll see some originals tomorrow, and check them against mine.
Joe Reed
"Classic Gold" is sold by Moss. I believe it's their proprietary brand....like Duralast at AutoZone...
I can't answer your question in any detail but, from what I've heard from other owners, the repops are made of thinner metal, the chrome isn't as good (less durable) and the bumper ends are a completely different shape from the OEM bumpers...
princetn1
princetn1
Member
I got front and back Classic Gold bumpers from Sports Car Parts Ltd mentioned earlier. I replaced the
front yesterday and am very happy. It led me to believe the PO misled me thinking I had originals. Therefore the fit is what I am used to and perfect finish! My old bars, won a trophy with them, will be hitting the classifieds soon. I look forward to seeing the difference.
JPSmit
Glad it worked out! new parts can be a bit of hit and miss - and as mentioned, generally keeping the original is better. That said, I have used a number of new bits - shiny and otherwise and have had quite good luck. There have been some issues with tolerances (that I have experienced) With parts being made in a country far across the sea (the other direction from England) - My sense is that the original tooling gets worn, plus little things like a metric fitting instead of imperial might make its way in - and, let's be honest - jobs going to the lowest bidder. That said, I Also believe that whatever the label the parts themselves are coming from the same places (i.e shop on price) I recall Tony (a previous member of the forum) years ago noting that a part he had ordered from one parts company arrived with a sticker from another parts company on the part in the box. All that said, all's well that ends well - and, other than you now needing to post a picture or two we can get on to the next job! cheers
Platinum
I had the front original rechromed, it looks better after five years than the repo I got from Vickie Brit. That one is starting to pit. And decidedly thinner than the original.
The car had been punted in the rear and repaired (in Chicago, a decade before we got it) poorly, the bootlid overhung the lower panel by a quarter inch. Think: overbite) After I'd hydraulically pushed that back into place and fitted another bootlid ( an original, sans luggage rack holes and rust), all is well. The fitting of the bumper was a fiddly task likely due as much to "slop tolerances" in its manufacture as the changes to the mounting points due to the prior shunt.
princetn1
princetn1
Member
I actually priced re-chroming locally (no shipping costs) and it was $400 per bumper. Well, since I found out that I didn't have originals anyway, I went with front and rear Classic Gold repro's for less than $400. If they wear out and pit in 10 years, I'll do the same. My car is not concourse nor original so I'm good with making it look as good as possible.
JPSmit
which is a major part of the decision as well - if you just want to drive repros are great! (besides original or repro bumpers aren't going to help us much in an accident anyways! ;p
Grantura_MKI
I would recommend fitting repos to a driver that is garage crept and keep the originals and re plate for future use. Repos do not have the same profiles and are thin. Would not recommend the repos for showing purposes.
Administrator
Boss
I would expect that most of today's repro parts for these cars are going to be of somewhat lesser quality that OWM parts - bumpers included.
JPSmit
Not necessarily Boss, I would qualify it to say shiny bits. In my experience (assuming the fit is right) anything "chemically arrived at" is typically better now - rubber, gaskets, hoses etc. not to mention sealants and adhesives etc. There are also things that are being improved on (The AH chassis comes to mind) but almost everything has better tolerances and a better understanding of the properties of metal than there was 50 years ago - but alas, then there is the "lowest bidder thing." Maybe the real advice is Buyer Beware :cheers:
Grantura_MKI
I do not agree with the above. I call it flash chrome, and doesn't last for a years time in the real world. Rubber bits are even worse. These tend to crack often before the vehicle is even put in service.....look at your rack boots!
Gokart
The reproduction bumpers may have a slightly different profile than originals. Sometimes with a repro front bumper one can see the last bolt head on each side of the valance to body line where the originals covered that bolt.
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
M General MG OEM Radio wiring help MG 4
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
H TR6 OEM Connecting Rod surprise Triumph 4
C BN1 OEM Rubber Floormats Austin Healey 1
toysrrus TR2/3/3A OEM TR3 Luggage Rack Triumph 7
J Moss OEM AIR DEFLECTOR ASSEMBLY Does it do anything? Austin Healey 9
5 TR2/3/3A Who was OEM glass manufacturer for tr3 windshields Triumph 1
Scotsman TR2/3/3A Should inner tubes be used with TR3 OEM steel wheels Triumph 3
S ride difference oem vs poly bushings Triumph 4
T What to do with OEM calipers? Triumph 8
M Help with OEM Jaguar Parts ID Jaguar 5
R TR2/3/3A TR3 Hardtop OEM or Aftermarket Triumph 21
bcbennett OEM side mirrors still available? Triumph 10
Brosky Crappy OEM Parts Triumph 14
G E-Type OEM hose clamps Jaguar 2
C Non OEM/aftermarket parts suppliers. Spridgets 3
B T-Series vintage new OEM MG mechanic uniform patch 4 sale MG 3
V Where to find an OEM hardtop? Triumph 2
S TR2/3/3A WTB a tr2 original grill Triumph 0
S Wanted tr2 original grill Triumph Classifieds 10
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
P General TR What color is original for engine parts? Triumph 7
EWD For Sale β€˜74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale β€˜74 TR6 original radio Triumph Classifieds 0
EWD For Sale β€˜74 TR6 original starter Triumph Classifieds 0
EWD For Sale β€˜74 TR6 original steering wheel Triumph Classifieds 0
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
PAUL161 T-Series Original transmission sold MG 2
T For Sale TR3A Original Radiator Triumph Classifieds 3
N MGB Not original to my 70 MGB? MG 18
C For Sale BJ8 original dash Austin Healey Classifieds 3
PAUL161 T-Series Original 1955 MGTF Photos MG 6
A For Sale '74 TR6 original seat frames Triumph Classifieds 0
W Wanted Servo for BN4 has to be original 1957 or before any condition considered. Austin Healey Classifieds 11
K TR2/3/3A Is a 25 AGC fuse equivalent to an original 30 amp fuse? Triumph 10
J Wanted Original BJ 7 speedo Austin Healey Classifieds 0
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
R For Sale TR6 TONNEAU COVER ( FACTORY ORIGINAL ) Triumph Classifieds 4
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
LAW75 Concours: Original Gas Hose Austin Healey 12
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
R For Sale Original AC Ace/Cobra seats. Early 60's, hand made Leveroll by A.W. Chapman, London Other British Classifieds 12
T TR2/3/3A Wanted - Picture of TR3A original firewall layout Triumph 5
