Is been a while since I posted, so here's a quick update. The frame has been POR15'd, the trailing arms have been cleaned back to aluminum, goodparts adjustable brackets, urethane bushings front and rear, seals in the differential, seals and gaskets in the transmission, the engine has been taken apart and re-assembled ( gaskets and seals, thrust washers ), Nickle/copper brake lines and fuel lines, brake hoses.
The chassis is together basically waiting for the tub. The tub has had sheet metal repairs....new floors, rockers have been repaired, battery tray, and many small rust spots have been repaired. Today I started the last thing to do to the tub before getting it ready for primer ; the rear valance. I got the old valance off, and all the mating surfaces have been prepped. There were many spot welds to drill and alot of grinding to clean the old spot welds !
