Midgetboy your spelling is atrocious, and so is the punctuation. You know your MG already has all the easy bolt up mods (header, Weber, electronic ignition) and I'm sure you have found out you can't wind this motor up if you read those links above. Let's keep it below 5000 rpm.
When do you want to try the Mini wheels?
Spend a little more time when you post, this is not instant messenger.
Dad
