Mini Cooper clutch problem
MitchellG
Hope someone else out there has run into this same problem and can maybe help me.
I stored my 1999 Mini Cooper in the garage over the winter for 6 months until the start of April this year. When I took it out again I noticed the cluth fluid was only lasting two days then needing to be refilled. To cut a very long story down to a long story I discoved the rubber seals on the clutch master cylnder were cracked and leaking clutch fluid into the drivers foot well.
To fix the problem I removed the clutch master cylnder, dismantled it, cleaned it and bought brand new replacement rubber seals for it.
After refiting my refurbished master cylnder I filled it up with clutch fluid and tried to bleed the system, but after 30 mins of pumping the clutch pedal with the bleed screw turned open in the engine bay there is still no resistance from the clutch pedal!!
The bleed screw did spit out some fluid but whenever the clutch pedal is pressed down air blows out the hole in the middle of the screw and when the clutch pedal is released it sucks air back in again so I'm getting nowhere fast.
I'm sure I must be doing something wrong here, but I just don't know what. Anyone got any ideas???
Thanks for any help or words of support!
aeronca65t
Be sure the clutch master cylinder is full with clean fresh fluid and keep an eye on it....it has a small capacity.
Have a friend pump the clutch pedal up and down several times and then push down the clutch pedal and hold it down. Loosen the bleed screw for a moment...and then tighten it back up......then your friend can let the clutch pedal back up.
Wait a moment and, once again, have your friend pump the pedal up and down several times....and then hold it down. Loosen the bleed screw for a moment...and then tighten it back up......then your friend can let the clutch pedal back up.
Repeat this process until the pedal starts to "firm up".
Some folks like to place clear plastic (fuel-proof) tube over the bleeder nipple and submerge the other end of the plastic tube in a container of brake fluid. This can improve the process a bit, and is a bit less messy...but is not absolutely required.
There are brake bleeding devices to assist this process, but I have never needed them.
G'luck and welcome. Let us know how you've made out.
Gary Pope
Going by your message (I may be wrong), but you can not pump the clutch with the bleed nipple open as you will be sucking air in and out infinately. In other words it will never get air out.
I recommend that you push the pedal down slowly with the nipple open and hold the peddle down.
Close the nipple and repeat until resistance is felt.
I use a self bleeder kit that allows one to keep the nipple open .. but just press down the pedal slowly.
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
Sherlock Mini Cooper patina Spotted 0
J 2006 Mini Cooper S British Motor Corp 6
R Tyres for Mini Cooper British Motor Corp 7
U Mini Cooper S Roadster ! British Motor Corp 1
C Car of the Week [Mini Cooper S MkII] Racing 2
Brooklands Mini Cooper Pick Up Truck British Motor Corp 2
69MGC B with Mini Cooper Headlights MG 9
HealeyPilot Starter motor replacement - Mini Cooper S British Motor Corp 3
S 2005 Mini Cooper British Motor Corp 20
G mini cooper v. cooper clubman British Motor Corp 3
Morris OT: Mini Cooper Spridgets 16
S Why Mini Cooper vs Cooper Mini? British Motor Corp 10
M WANTED: AUSTIN MINI COOPER British Motor Corp 2
C Hi Im a neewbie with a Mini Cooper ! British Motor Corp 4
David McLaughlin Movies! - Jaguar E-Type, Lotus Elan, Mini Cooper and many more! Jaguar 4
J 64 Mini Cooper British Motor Corp 3
78Z Nice article on new Mini Cooper S British Motor Corp 1
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
C For Sale Rover Mini Blue Star Tribute Other British Classifieds 0
TomMull For Sale 10 inch Mini Rims (2) Other British Classifieds 1
Basil Mini Pick Up Spotted 8
pbraun Alex Moulton's special Mini Moke for sale Other British Cars 0
C Autocrossing a classic Mini problems Other British Cars 2
Basil The Queen in a Mini! Spotted 3
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
GB1 Classic Mini Mayfair Auto Other British Cars 1
Baz 2012 Mini CEL - Now it begins........ British Motor Corp 0
N Classic Mini Engine Identification British Motor Corp 6
P Classic Mini advise British Motor Corp 1
D Possible Mini Gauges? British Motor Corp 6
S For Sale Austin and Morris MINI Factory Workshop Manual on CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
HighAltitudeTR3 TR2/3/3A Mini Pulses at Idle Triumph 6
tr6nitjulius Mini @CCBCC All British Meet 7/14/19 British Motor Corp 0
JPSmit Green Mini - with halo headlights Spotted 0
Alfred E. Neuman Austin Mini Breadvan Spotted 0
AngliaGT Real Mini Spotted 0
S TR2/3/3A Tr3/Mini Girl Triumph 0
T Will Mini Spin on Adaptor work on Bug Eye? Spridgets 10
Bob Claffie Ultimate Mini British Motor Corp 3
coldplugs Jensen Interceptor & a Mini Spotted 8
pbraun Mini Meet East 2017 British Motor Corp 4
bcliff For Sale 1972 Austin Mini for sale Other British Classifieds 0
Basil Mini? Spotted 5
hutten Wheel sizes for Rover Mini Mark VII British Motor Corp 1
JPSmit Mini + iphone question Other Cars 3
Chuck9482912 Mini Spare Tire Austin Healey 9
B Mini Windscreen Wiper Parking British Motor Corp 3
3798j AACA Museum's Micro & Mini Exhibit Other Cars 1
