Lucas Electrical Theory and other silly bits
JohnB
Bronze
Came by this recently, enjoy..................(sorry if it's been on before)........ A bit long but worth it.
ELECTRICAL THEORY BY JOSEPH LUCAS
Positive ground depends on proper circuit functioning, which is the
transmission of negative ions by retention of the visible spectral
manifestation known as bsmokeb. Smoke is the thing that makes electrical
circuits work. We know this to be true because every time one lets the smoke
out of an electrical circuit, it stops working. This can be verified
repeatedly through empirical testing.
For example, if one places a copper bar across the terminals of a
battery, prodigious quantities of smoke are liberated and the battery shortly
ceases to function. In addition, if one observes smoke escaping from an
electrical component such as a Lucas voltage regulator, it will also be
observed that the component no longer functions. The logic is elementary and
inescapable!
The function of the wiring harness is to conduct the smoke from one
device to another. When the wiring springs a leak and lets all the smoke out
of the system, nothing works afterward.
Starter motors were considered unsuitable for British motorcycles for
some time largely because they consumed large quantities of smoke, requiring
very unsightly large wires.
It has been reported that Lucas electrical components are possibly
more prone to electrical leakage than their Bosch, Japanese or American
counterparts. Experts point out that this is because Lucas is British, and all
things British leak. British engines leak oil, British shock absorbers,
hydraulic forks and disk brake systems leak fluid, British tires leak air and
British Intelligence leaks national defense secrets.
Therefore, it follows that British electrical systems must leak smoke.
Once again, the logic is clear and inescapable.
In conclusion, the basic concept of transmission of electrical energy
in the form of smoke provides a logical explanation of the mysteries of
electrical components especially British units manufactured by Joseph Lucas,
Ltd.
And remember: A gentleman does not motor about after dark.
Joseph Lucas The Prince of Darkness
1842-1903
A Few Lucas Quips:
The Lucas motto: Get home before dark.
Lucas is the patent holder for the short circuit.
Lucas - Inventor of the first intermittent wiper.
Lucas - Inventor of the self-dimming headlamp.
The three-position Lucas switch--DIM, FLICKER and OFF. The other three
switch settings--SMOKE, SMOLDER and IGNITE.
The Original Anti-Theft Device - Lucas Electrics.
If Lucas made guns, wars would not start
Back in the 70s, Lucas decided to diversify its product line and
began manufacturing vacuum cleaners. It was the only product they offered
which did not suck.
Q: Why do the British drink warm beer? A: Because Lucas makes their
refrigerators.
The smoke theory is: When the smoke comes out, it is finished...cooked
or done for.
jsfbond
If Nikola Tesla had gone to England from the old country instead of to America, things could have been way different!AC Broadcast powered British cars, The AC Cobra for instance.
hondo402000
I think you forgot to include the induced smokealators, or owners that work on fixing lucas smoke generators
Twosheds
JohnBazzano said:
The smoke theory is: When the smoke comes out, it is finished...cooked or done for.
Everyone gets this old saw mixed-up.
As my Electronics professor told it:
"Smoke is what makes electronics work! As long as the smoke is inside the component, it works.
If the smoke escapes, the component no longer works, proving that the smoke is necessary for the proper functioning of the component."
3798j
Bronze
Some more quips:
* Lucas denies having invented darkness. But they still claim "sudden, unexpected darkness"
* Lucas dip-switch positions: LOW and BLOW
* "I've had a Lucas pacemaker for years and have never experienced any prob...
* It's not true that Lucas, in 1947, tried to get Parliament to repeal Ohm's Law. They withdrew their efforts when they met too much resistance.
* Did you hear the one about the guy that peeked into a Land Rover and asked the owner "How can you tell one switch from another at night, since they all look the same?" "He replied, it doesn't matter which one you use, nothing happens!"
* Alexander Graham Bell invented the Telephone.
Thomas Edison invented the Light Bulb.
Joseph Lucas invented the Short Circuit.
* How to make AIDS disappear? Give it a Lucas parts number.
* Recently, Lucas won out over Bosch to supply the electrical for the new Volkswagens. So, now the cars from the Black Forest will come with electrics supplied by the Lord of Darkness -- how appropriate!
* Lucas is an acronym for Loose Unsoldered Connections and Splices.
JImEgan
Whats that hiding in the garage behind the TR4A
I like your favorite color
M Refurbishing Lucas Electrical Items Triumph 10
G Parts Available? and Lucas Electrical Jaguar 4
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
L TRW-Lucas Brand Master Cylinders Austin Healey 2
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
MGTF1250Dave T-Series Lucas Generator MG 1
T Lucas Flasher Unit Austin Healey 5
D Lucas Low-Tension Leads Austin Healey 1
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
B Wanted Lucas wing mirror Other British Classifieds 1
B TR6 Swapped Lucas to GM alternator Triumph 9
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
M Looking for Lucas parts catalogue British Motor Corp 13
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
B Delayed charging Lucas alternator Triumph 1
S Stag Lucas 18ACR alternator conversion Triumph 5
Lin Lucas coil question Austin Healey 8
red57 Lucas 1748 horns Austin Healey 19
B TR2/3/3A Lucas, SU, and the rest Triumph 3
K TR2/3/3A Who owns the "Lucas " brand name? Triumph 7
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
F How do I get rid of "Lucas"? FORUM Navigation Questions 2
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
F T-Series Lucas m133 headlamp? MG 2
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
S Intermotor or Lucas Sport Coil ? Austin Healey 14
C General Tech Lucas Fog Lamps Triumph 2
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
R LUCAS 17L Batteries for Healey 100s Austin Healey 3
C TR6 More fun with Lucas Triumph 5
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
Michael Oritt Lucas 576 lights Austin Healey 4
J MGC Lucas alternator/regulator MG 3
Rob Glasgow Weird Lucas Headlight Austin Healey 7
CJD General Tech Boeing using Lucas parts? Triumph 7
D Wanted lucas wt618 Triumph Classifieds 0
Basil SOLD!! Lucas Spot and Fog lamps Jaguar Classifieds 1
H Lucas Prince of darkness Austin Healey 4
NutmegCT Lucas 432 bulb Restoration & Tools 6
T Lucas HF 1748 horn parts Austin Healey 5
T TR5/TR250 Question on Lucas Hazard relay Triumph 14
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
Patrick67BJ8 Lucas SLR Driving Lights installation Austin Healey 26
