General Tech Lubricating New Rod Bearings
KVH
A very old topic, I know. But what is better: plain motor oil, white lithium grease, or assembly lube when replacing rod bearings? Any difference really? A good mechanic I know says to use motor oil and quit fussing.
Brinkerhoff
Oil is just fine. I've taken apart engines that hadn't run for thirty years and the bearings were still wet so I don't think it will dry out or anything.
TomMull
I did my first few engines before I even herd of assembly lube and I agree with the comment above. However, ever since my machine shop guy gave me a tube of assembly lube, I use it on everything inside. The one I use has ZDDP in it too.
Tom
glemon
I have used STP too, don'the know if it is best, but seemed thick enough to stay put until the oil starts flowing.
ghawk16
Funny...was just going to start a post on here asking about what are peoples thoughts on lubricants or sealants or what not on certain bearings and gaskets when putting back together an engine. I'm getting ready to put my engine back together and it might be good to have it all in one thread for the future. That's of course if it hasn't been posted already.
Lin Lubricating Leaf Springs Austin Healey 29
T TR2/3/3A Instructions for cleaning & re-lubricating speedometer? Triumph 5
T Lubricating the steering rack on a Bug-Eye Spridgets 12
TimK Lubricating Speedometer drive Austin Healey 11
P Lubricating a new BJ8 water pump Austin Healey 3
T lubricating a pilot bushing Spridgets 9
M Lubricating the front suspension Triumph 25
T QUestion regards lubricating steering rack Spridgets 9
rchakr Lubricating Water Pump Triumph 2
S Lubricating Speedometer Cable Austin Healey 13
G Should I be lubricating my Strombergs? Triumph 8
B Rod & Main Bearings Recommendations Austin Healey 10
W Correct Tie Rod Ends Spridgets 0
D Separating the piston from the connecting rod. Spridgets 9
KVH General Tech Connecting Rod Bearings Triumph 8
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
B For Sale Connecting Rod Bearings Austin Healey Classifieds 0
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
A MGB MGB 1974 windscreen centre rod replacement MG 5
S For Sale TR-3 Tie Rod Assembly for Sale Triumph Classifieds 0
DrEntropy Shift rod seal in an automatic? Jaguar 7
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
Healey Nut Cross Rod Correct Length Austin Healey 14
7 General TR Hot rod Triumph 0
Healey Nut BT7 Panhard Rod Austin Healey 28
Walter74 Steering Rod Installation Austin Healey 6
red57 Rod Bearing Clearances Austin Healey 4
BoyRacer Odometer Reset Rod Austin Healey 4
K TR2/3/3A Removal of tie rod end? Triumph 7
TRopic6 For Sale Vandervell .010 Rod Bearings, MG TB, TC, TD, TF [Partial set] MG Classifieds 0
R TR2/3/3A Throttle rod spring location Triumph 3
I Brake rod questions Spridgets 7
Y MK V rod bearings Jaguar 1
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
K TR2/3/3A Inner tie rod ball joint. Triumph 6
R Connecting Rod Big End Specification Austin Healey 4
John Turney The Panhard Rod is Supposed to be Straight, Right? Austin Healey 7
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
T TR6 Air vent rod connection Triumph 1
F TR2/3/3A Throttle linkage cross rod Triumph 4
K TR2/3/3A TR3 Tie Rod Sleeve Triumph 2
K Wanted TR3 Tie Rod Sleeve Triumph Classifieds 2
Rhodyspit75 Bugeye bonnet prop rod Spridgets 2
Michael Oritt Center rod, bracket and mirror info needed Spridgets 8
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
M TR2/3/3A Connecting Rod Locking Tab Deformation Triumph 15
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
Got_All_4 TR2/3/3A Inner tie rod ends Triumph 4
