I'm Screwed, part II.....
TR6BILL
Well, I have the left half shaft out, brake lines removed, fuel tank drained and out. I have the diff suspended in mid air at the rear with a nice aluminum level stretched across the frame. Holds the diff approximately level 'cause I have no rear frame cross member anymore. I have to rig a cradle for the the diff to fit atop my floor jack. When I do, I will drop the diff so I can install the front stiffener plates from TRF. Will have to wait for the new cross member to come in, fit it and call the welder. This will entail several trips for him unless the do the front welding myself. Then coat the new piece with some frame paint and start the whole process in reverse. It will be at least a month before I can get this finished. Interestingly, the four bolts holding the diff to the half shaft were all slightly loose holding the two flanges together. That was a little worrisome. I noticed they were OE bolt but new all-metal locking nuts. I kinda think the OE bolts stretched a bit with all that torque. ALL hardware going back in will be new and grade 8 (and not from Lowes grade 8). Have a bolt specialty shop that services the oil industry in the area that will supply the good stuff.
My fingers are sore and my back hurts. Time to take it easy for a few days.
Are we having fun yet?
DNK
I know you don't drink Bill. Save the hi ball for me> :jester:
T
TR6BILL
Interesting what one finds when you go back into an area that you rebuilt in past years. Yes, the rubber brake hoses from the frame to the TA were showing signs of cracking. The whole car was rebuilt with new parts from 2000 to 2003. Replacing those with armored lines. And changing all fluids. (Yes, Brosky, I am going back with paint-remover fluid). The rear brake pads have a few more miles left on them, will leave them be. Greasing all U-joints, otherwise inaccessible. Changing all fasteners to new, high-end stuff. I know I certed the left TA with new fittings, the right was solid and still is. May go with new studs as there is some corrosion (aluminum and steel don't get along). New bump stops are in order. Reinforced front diff mounts will be done. Change a leaking fuel sensor gasket. Of course new cross member but might add a plate or two to the frame in the rear just to stiffen it up a bit. When I bought this particular car (I looked for 2 years), it was completely rust free, frame and body, so everything is still good to go. Trailer queen it ain't. Well, the first year after completion it won a few trophys but now it gets used. It's my Viagra, if you will.
tdskip
Bill - and observations on how well the bushings and rubber parts have held up under time and use and if you can see a difference in the longevity of the bits by vendor?
You made good progress - I'd need a drink too!
G I screwed up another part..... Triumph 9
7 I screwed up - Bosch VE pump. Other Cars 1
Intrisk BJ8 Front suspension screwed bush housing / threaded bush housing re-assembly gap Austin Healey 1
A almost screwed up Triumph 8
dklawson Oil Leak - I Screwed Something Up. Triumph 8
68_sprite CSI screwed up their facts Austin Healey 5
livinginthepast self-delete | sorry, i screwed up. Spridgets 1
T I'm Screwed! Triumph 37
jlaird Think something is screwed up Spridgets 20
regularman Important question [I might have just screwed up] Spridgets 8
LuckyLuke Big Healey heat shields screwed or also glued? Austin Healey 5
jlaird I screwed up, maybe Spridgets 13
DrEntropy Think I just Up-screwed... MG 2
G Got screwed by a local machine shop Triumph 14
A Polyurthane Bushing - Screwed Up? Spridgets 5
K TR2/3/3A Mystery TR Part Triumph 9
I MGB Help! What is this part for? MG 13
R Part Identification Austin Healey 5
Agrandshort TR2/3/3A Unknown part panel Triumph 5
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
J TR2/3/3A Part Identification Triumph 7
CARSINC Unknown Part Spridgets 5
equiprx Mystery part Other British Cars 2
R TR6 Help: Brake Part Source or …. ? Triumph 1
N MGB Electrical Part Identification MG 3
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
R Cool Remanufactured Part for Vixen 2500 TVR 7
N MGB Name that part MG 5
D TR2/3/3A Another mystery part(s) Triumph 2
P Wanted Part # BHA5138 Triumph Classifieds 0
AngliaGT MGB Dumb Question - What's This Part? MG 3
D TR2/3/3A Another mystery part Triumph 8
B Useful Part or Boat Anchor? Spridgets 1
R Wanted rib cage tranny part Spridgets Classified 0
B TR2/3/3A Hard Top Part Triumph 2
TR6Canuck TR6 TR6 waist seal clips - which side goes on which part? Triumph 6
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
BritBob TR2/3/3A Part restored TR3A in Oregon Triumph 0
Tr3aguy TR2/3/3A Gasket part way off Triumph 10
Healey Nut Mystery Part Austin Healey 2
Oldi.Tec Spare Part Re-Manufacturing using 3D-Printing Restoration & Tools 5
vping T-Series Looking for TD Part # MG 3
D TR2/3/3A Another mystery part..or two Triumph 14
T Trying to identify a steel plate part Austin Healey 2
Bayless Missing important part Spridgets 0
H TR2/3/3A Rimmerbros Part Triumph 7
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
Lin TR6 Do you know this part? Triumph 6
