Horn replacement question
TR4
My TR4 currently has single terminal horns installed. Can I replace them with two terminal horns by grounding the second terminal? My electical knowledge is too close to zero so advice is appreciated.
T
Tinster
TR4-
Your ground wire concept should work. When I gutted and
rewired my entire TR6, I installed grounding blocks
throughout the car. Here is a photo of a temporary ground
block for one of my two terminal horns. I now have real
grounding blocks but you'll get the idea from the photo.
best of luck,
d
Geo Hahn
Without getting out of my chair...
I'm thinking the TR4 honks the horn by providing a ground (purple w/black tracer) via the horn button. In other words, the hot side (purple) at the horn is always hot.
If you have been successfully using a single-wire setup (presumably the present horn is grounded thru its mount to the body) then perhaps you have something quite different from the horn button in the middle of the steering wheel. In that case simply grounding one terminal may work.
If you grounded the original TR4 horn that way it would honk just fine -- but never shut off.
TR4nut
Having struggled to get a consistent ground on my TR4 horns (and not quite there yet), I agree completely with Geo's comments. A single wire to your horns implies that the original horn setup has been changed. The single wire setup you have has to be grounded, perhaps through the horn bodies themselves otherwise you'd be honkless.
Randy
T
TRDejaVu
I found that my horn problems were due to poor or nil continuity along the steering column. I have a temporary fix where I ran a wire from the upper column which by passed both column flex joints. No problems since and I will fix it properly when other more pressing (i.e. fun) projects have been completed.
TR4nut
Ian-
I have the same issue, using short jumper wires at the rubber couplings does not solve it - I suspect corrosion between the inner steering column/couplings may be the issue. It is quite a pain.
Look at the column design, I am very surprise Triumph didn't make a ground at one of the column bushings - those bushings have a metal insert, in my opinion that is a better place to ground than going all the way through the steering rack. Oh well.
Randy
T
TRDejaVu
I ran one long wire to completely bypass the center shaft and both couplings; held it in place with electrical tie-wraps so it won't flap. I cleaned up the wire attach points until I had continuity and the problem hasn't re-occurred - yet.
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
C TR2/3/3A Horn Control replacement Triumph 3
S replacement horn relay Triumph 9
C TR6 TR6 Dash replacement, now only the horn works Triumph 6
P TR6 Horn issue 1974 TR6 Triumph 5
P TR2/3/3A TR2 Horn Mounts Triumph 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB HELP, my horn does not work! MG 8
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A The horn and turn signal assembly. Triumph 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D TR2/3/3A Traffic at or and horn button not working Triumph 2
P TR2/3/3A 6 volt Oogah horn Triumph 8
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
jehuie Morris Minor horn mystery British Motor Corp 12
Sixpack TR6 Horn Mystery Triumph 3
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
R Horn relay Spridgets 2
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
P TR6 TR6 Horn Relay Problems Triumph 8
S Indicator / Horn Switch Austin Healey 10
nichola TR6 Help me - circuit breaker above horn relay Triumph 5
nichola TR6 What is this, connected to horn relay? Triumph 8
Bayless Wanted: Spridget horn button bracket Spridgets Classified 1
71TR6 TR2/3/3A Control Head horn contact Triumph 7
71TR6 TR2/3/3A Windtone WT618 horn current Triumph 9
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
D TR6 Replacing Horn insert in steering column Triumph 11
nevets BN6 horn button Austin Healey 17
Bayless Question on '67 horn button Spridgets 5
K TR2/3/3A Horn Button Removal Triumph 10
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
TRMark T-Series Horn/Dipper Switch MG 4
R German horn on BJ7 Austin Healey 8
K Is my BJ8 horn switch connected to ground positively or negatively? Austin Healey 3
longbridgehealey Horn question follow up Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
UmmYeahOk GT6 Steering Wheel Horn Troubles Triumph 11
K Restoring Horn Push Button Austin Healey 12
Jim_Gruber Intermittent Horn Spridgets 2
Joe_Healey TR5/TR250 Bubba Horn Triumph 0
G TR4/4A Horn Brush Question Triumph 7
edkap2002 TR6 horn brush Triumph 3
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
Jim_Gruber In need of a really loud horn Spridgets 13
T Lucas HF 1748 horn parts Austin Healey 5
S TR4/4A Horn relay Triumph 2
