TR2/3/3A Horn not working unless I rotate the control head
Stavri
I just bought a TR3 and the owner just put a new control head on and it worked. I decided to take off the steering wheel to paint and re installed it. I hooked up all wires and oriented the head correctly and the signals work and cancel correctly but not the horn. If I take the grub screws out and pull the head out a little and rotate it upside down I can get the horns to work. Whats going on? now I am second guessing myself. Did I paint the center of the steering wheel and cause it not to ground? is there somewhere the head is not grounding in the wheel. Any help or thought is appreciated. Never fun going backwards!
thanks,
Steve
sp53
I would think it would case ground somewhere in the stator tub also. Perhaps a lose wire in the head. Not sure where, but at least it is not stuck on. You can probably get to it by only loosening the 3 screw on the head from the back and split the plastic case open without doing a total take apart; the horn button is right there and maybe you can tighten one of the brass nuts from there, not sure. There are some good pictures of the inside of the head on the forum. That is probably where I would start after I check the connections on the bottom by the horns.
steve
Skidude
Do you have to disconnect the wires in the engine bay and remove the whole control head - or, can you just remove the 3 screws from the back of the control head to remove the outer part to get to the copper horn ring?
CJD
You can pull the wires back through the tube to get enough access to work on the trafficator in place, assuming the wires are in relatively good condition.
S
Stavri
It was the metal washer on the back of the horn button. Who knew a 6 month old new control hub was poorly made. The little amount of glue they used let go. Sanded up, new epoxy and horn works as it should.
Snowkilts
You also make a spark in there and get scorch marks every time you hit the horn. I must have sanded mine off 3 times or so and the **** thing still wouldn't work when I needed it. I finally added a relay to the circuit to reduce the current going through the control head and stop it from sparking. So far (several years) it still works.
Edit: Today I Learned that the forum automatically censors non-disney words! :glee:
D TR2/3/3A Traffic at or and horn button not working Triumph 2
T Horn and rear right indicator stopped working...head scratch imminent Austin Healey 16
B Horn Quit Working Austin Healey 14
P TR6 Horn issue 1974 TR6 Triumph 4
P TR2/3/3A TR2 Horn Mounts Triumph 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB HELP, my horn does not work! MG 8
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A The horn and turn signal assembly. Triumph 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
P TR2/3/3A 6 volt Oogah horn Triumph 8
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
jehuie Morris Minor horn mystery British Motor Corp 12
Sixpack TR6 Horn Mystery Triumph 3
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
R Horn relay Spridgets 2
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
P TR6 TR6 Horn Relay Problems Triumph 8
S Indicator / Horn Switch Austin Healey 10
nichola TR6 Help me - circuit breaker above horn relay Triumph 5
nichola TR6 What is this, connected to horn relay? Triumph 8
Bayless Wanted: Spridget horn button bracket Spridgets Classified 1
71TR6 TR2/3/3A Control Head horn contact Triumph 7
71TR6 TR2/3/3A Windtone WT618 horn current Triumph 9
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
D TR6 Replacing Horn insert in steering column Triumph 11
nevets BN6 horn button Austin Healey 17
C TR2/3/3A Horn Control replacement Triumph 3
Bayless Question on '67 horn button Spridgets 5
K TR2/3/3A Horn Button Removal Triumph 10
TRMark T-Series Horn/Dipper Switch MG 4
R German horn on BJ7 Austin Healey 8
K Is my BJ8 horn switch connected to ground positively or negatively? Austin Healey 3
longbridgehealey Horn question follow up Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
UmmYeahOk GT6 Steering Wheel Horn Troubles Triumph 11
K Restoring Horn Push Button Austin Healey 12
Jim_Gruber Intermittent Horn Spridgets 2
Joe_Healey TR5/TR250 Bubba Horn Triumph 0
G TR4/4A Horn Brush Question Triumph 7
edkap2002 TR6 horn brush Triumph 3
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
Jim_Gruber In need of a really loud horn Spridgets 13
T Lucas HF 1748 horn parts Austin Healey 5
S TR4/4A Horn relay Triumph 2
F TR2/3/3A Horn/Directional Assembly Triumph 2
