John Loftus
The threads on the gas tank hold down strap and seat frame pivot bolts had worn so I gas welded the damaged areas and then used a die to cut new threads (see images below). Should I heat treat the threads and if so what is the procedure? I recall heating things red hot and quenching in oil a few times back in junior high shop class but that was a few too many beers ago. /ubbthreads/images/graemlins/grin.gif
Cheers,
John
Cheers,
John
