Heat Booster Fan
memphis
Hi All!
Is there a way that I can test the heat booster fan? I am in the process of taking the dash switch out for testing, but would like to know if there is a way to test the fan without the switch? This way I know at least the fan itself is working.
Thanks in advance for your help and advice.
Bob :smile:
memphis
memphis
Thanks Randy!
Obviously I am not an electrician, but I guess this would complete the circuit and run the fan :confuse: .
This is my first British car and first car with a positive ground system. I am not yet comfortable with this system.
Looking forward to the day that the light clicks on and I'm "in the zone". I guess I just need to keep working on her.
Many Thanks!
Bob :smile:
memphis said:
... This is my first British car and first car with a positive ground system. I am not yet comfortable with this system. ...
It may help to think in terms of 'common' instead of 'ground' (most cars are electrically isolated from the ground by the tires, except a few I've seen with a metal strap which drags the ground, I guess to dissipate static electricity). Common is simply a convenient way to complete the circuit to the battery using the metal chassis (otherwise, you'd need two wires to every electrical component).
Negative 'ground' and positive 'ground' behave no differently--the electrons flow in the same direction regardless of which battery terminal is connected to the chassis. The main issue is that most modern electrical devices--e.g. GPSes--are wired for negative ground (common), so you can't just plug them into the power circuit on your Healey (unless they are isolated, and possibly have the leads reversed). There are several discussions on this forum on how to do this.
Rob Glasgow
Speaking of heater booster fans, somewhere I heard that the fan motor used in the Datsun 240Z was a clone of the Smiths fan used in our Healeys. I've seen photos of the Datsun blower motor and they do look similar. Because they were build in the mid 70's, they may have been multi-speed, but I don't know for sure.
Question - (1) Anyone know if the Datsun motor will fit the Smith fan case relatively easily? (2) Anyone ever install one on their Healey and what do you think? (3) Is the Datsun fan multi-speed?
Answers to any of the questions would be appreciated.
red57
Rob,
I have been using a 240z fan in mine for 20 years or so. Wasn't a big plan to do but one day my fan died and I am cheap and I had a dead 240z out back and.......
I don't know if the guts could be put in in a Smiths case or not. I just used the complete 240 fan. Don't remember all the details, but I just bolted it in the same location as stock. The only 'modification' needed is to the output side of the fan - the 240 has a square outlet and I had to make a small sheetmental adapter to go from the square to round to accept the Healey round duct. The inlet side of the fan is round and the right size for the Healey duct.
When in place the inlet and outlet are pointing the right directions to fit the Healey ducts.
Don't know if they can be run as multi-speed, I just have an on/off switch.
Blows a lot more air then the Smiths fan did, and has been very reliable.
You will need a relay if you want to use the stock fan (boost) switch - I'm guessing it draws more current because it cooked my stock switch quickly. I mounted a heavy duty toggle switch but a relay and the stock switch would be better I think.
I really like it - it actually demists!! Don't have a way to measure it but it sure feels like a lot more air is moving. And it was free.
Dave
memphis
memphis
Hi Guys!
I tested the fan by connecting the wires together at the switch.
No luck....
Is the fan 12 volt? Can I test the fan, at the fan. The fan has one wire connected to the chassis (common). The other wire is connected to a green/yellow wire that goes into the main harness.
Can I simply find a power source in the engine compartment and test the fan? Any suggestions on where I can find a 12 volt source in the engine compartment?
I do see a brown wire connected at the starter. Use that one?
Thanks!
Bob
5
57_BN4
Hi Bob,
Try connecting a test-light or a park light bulb between the fan supply wire and a clean earth with the ignition and fan switch on.
Light = power = probably a burned out motor.
I got a box of spares with my BN4 and in there is a fan motor that looks like it has caught fire inside. If you need a replacement motor I'd be 99% sure it will be common to a heap of vehicles around the era. Pretty sure it is the same as Ford Zephyr.
If testing the motor, be a little careful using the starter cable as a test power source, it is unfused and if your test wire touches the chassis many bad things can happen.
Andy.
Johnny
Hi Bob, do you have a shop manual for the Healey? If so go to the NNN section and look at how the fan is wired. Pretty simple stuff actually. Most likely you have a loose connection somewhere or the fan has seized up. You need a volt-ohm-meter or test light of some sorts to check if voltage is getting to the fan motor.
Good luck at finding your problem, and please let us know what you found, no matter how simple.
memphis
memphis
Thanks Guys!
I turned on the fan switch and with a test light: one end connected to the chassis and the other to the main fan wire in the engine bay, the test light lights up!
So it is getting power. Bad news, its a defective fan.
It looks fairly easy to replace, correct?
Thanks!
Bob
memphis
memphis
Success! Got the blower working this morning. Turns out it was a rusty female socket on the fan wiring itself. When I tested with my test light, I tested the male (wire harness) end and always got power. Tested the female end (fan wire) this morning and no power. Cleaned the female socket, connected and got power, but fan still didnt spin up. Took rubber hammer and tapped on the fan, and whala... fan works!
Bob :yesnod:
Johnny
Hi Bob, the green wire can be touched any 12V terminal and you should be able to hear the fan run. That green wire runs to your switch by the way, then the other side of the switch (probably another green wire) goes to the green fuse on the firewall. It's common to have all those green wires separate at the fuse. Also it's possible a wire came loose at the switch.
Good Luck, let us know what you found to fix the problem.
memphis
memphis
Hi Johnny,
The old fan ran for a short while, then locked up. I guess old age...
I ended up replacing the fan motor inside the housing.
All works great now.
Thanks,
Bob
HealeyPassion Reducing Muffler Heat Austin Healey 2
steveg Heat Shields Austin Healey 17
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
V heat shield Triumph Classifieds 7
EWD TR6 Sound/Heat Mat installation - 74 TR6 Triumph 14
M Heat-related carb issue on BN1 Austin Healey 7
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
AH67 Heat Shield finish 66 Type Jaguar 5
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
K TR2/3/3A Revington alternator heat shield. Triumph 0
60TR3A Is It Safe to Heat My Garage All Winter While I Am In Florida? Austin Healey 34
K TR2/3/3A DIY Alternator heat shield>>> Triumph 2
L 100/ Moss Heat Shield Austin Healey 2
wangdango Keeping the heat out? Austin Healey 11
DornTRoriginal TR2/3/3A Heat Shield Issues Triumph 6
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
GTP1960 TR2/3/3A Carb. Heat shield location? Triumph 11
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
T TR2/3/3A Fuel line heat shield Triumph 39
NutmegCT heat valve control cable Other Cars 0
MikeAH100M FYI - Hardie Board for Heat Shields not Recommended Austin Healey 9
H The heat shield for the Longbridge between the exhaust manifold and carbs Austin Healey 1
69mgbgt No cabin heat in my 1997 jaguar xj-6 Jaguar 1
I Spitfire If you can't stand the heat.... Triumph 7
J Side exhaust heat shield Austin Healey 23
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
T TR4/4A Heat shield for tranny cover Triumph 4
R Heat Shield Detail Austin Healey 3
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
T General TR heat proofing floor boards Triumph 10
R Heat shields and other hot topics Austin Healey 36
tahoe healey Dynamat heat shield Austin Healey 8
R securing heat shields Austin Healey 11
KVH Carb Heat Shield Installation Triumph 2
D Carb Heat Shield Spridgets 12
HealeyDave Intake manifold heat shield fitting issue Austin Healey 2
NutmegCT heat barrier Restoration & Tools 3
NutmegCT TR2/3/3A TR3 cockpit - summer heat! Triumph 12
M Supercharge Heat Sheild Question [pics] Triumph 3
Russ Austin Heat ah at least warmth. Triumph 11
R TR4/4A Tr4a, alternator heat shield Triumph 9
E Asbestos heat shielding. Austin Healey 8
R Need more heat - which thermostat MG 15
J T-Series electrical heat and smoke from the switch MG 4
G HEAT SHIELD! Austin Healey 10
R No Heat Shield Cause Dieseling? MG 1
I How do I install Bugeye heat shield? Spridgets 4
Gliderman8 Heat Shield - will it solve my problem.... Triumph 15
