TR2/3/3A Fuel pump inertia switch vs. dead engine switch?
GTP1960
I've replaced my mechanical FP with a facet electric model.
I have a revolution electrical dead engine automatic cut-off switch, that I will be installing, but after reading several threads on inertia switches I'm wondering if I need that, also? ( or instead of)
If you have a preferred brand I'd like to know that too.
(BTW: Also a prefer brand of inline fuel on/off valve appreciated)
dont want to scrimp on something like this.
reminds me of a sign posted at my little local flying club AP, years ago;
"factory second parachutes sold here! Great prices!"
Thanks
bnw
The inertia switch in my TR8 was a royal PITA. Unavoidable pot holes and other road anomalies would trigger it. Killing the fuel supply in traffic on the interstate was annoying and very dangerous at times. Perhaps mine was over sensitive but none the less, with all the bouncing around a TR3 can go through, it might be a problem.
TR3driver
Great Pumpkin - R.I.P
Kind of belt vs suspenders, IMO. Triumph leaned towards inertia switches, and the ones on my Stags have never given me any trouble (although it's possible they don't even work). Other car makers (like VW) seem to prefer engine cutoffs. Modern cars typically do both (through the ECU).
I'm not convinced it makes all that much difference on a TR3 anyway. With the tank up so high and an open vent, gravity will most likely empty the tank even if the fuel pump doesn't.
bnw
Any serious accident in one of these is going to be a physical as well as financial disaster. You've got to drive one like you would ride a motorcycle. 110% defensive.
TuffTR250
Guy, what pressure does your Facet electric fuel pump work at? Are you planning to also install a fuel pressure regulator? The other day in one of my manuals I read a statement on the fuel pressure requirements for the 4 cylinder Triumph but today I cannot find the statement. Does anyone know what fuel pressure Triumph specified? I'll report back if I find the statement in one of my Triumph manuals. Thanks!
Regards,
TR3driver
The spec for the original fuel pump used on TR2-4A was 1.5 to 2.5 psi (or in other words, 2 psi +/- 0.5 psi)
GTP1960
GTP1960
Guy, Are you planning to also install a fuel pressure regulator?
Hey Bob,
missed your question about the pressure regulator.
Moss does not recommend it with the facet pump. In fact the moss video implies if you need a pressure regulator, then you have the wrong pump.
best regards
Guy
TuffTR250
Thanks Randall for the pressure spec!
Thanks Guy, I did not know that about electric fuel pumps. What model or part number Facet fuel pump did you get to ensure it has the right pressure?
Regards,
TR3driver
Facet makes several different pumps, each available in a wide range of pressure ratings. I don't know, but I would guess that Moss is supplying P/N 40104. If you wanted to stick closer to the original pressure, there is P/N 40163 rated at 1.5 - 2.5 psi (but only 17 gph, which should be plenty for a stock engine). There is a chart at
https://www.aircraftspruce.com/catalog/eppages/facetpumps.php
There has been some debate in the past over use of pressure regulators. Some claim it causes problems, others say it works for them. A lot of racers fall in the second category, so I'm inclined to believe it can be made to work well. One important point is that the pressure regulator requires a pressure drop across the regulator, so you definitely need a higher pressure pump if you are going to run a regulator.
Something else to consider: The little rectangular Facet pump makes a fair amount of noise, which can get greatly amplified if you bolt it directly to sheet metal. Good idea to mount it with rubber isolation. I actually did a double isolation mount on the Stag, which combined with being in the trunk, makes it inaudible when the engine is running.
That $10 filter shown by Moss is a standard Ford part, readily available at FLAPS for less than half the price. It does need to be replaced from time to time.
https://www.oreillyauto.com/site/c/detail/WIX0/33046.oap?pt=02515&ppt=C0023
TuffTR250
Thanks for that information Randall. A couple of questions: I got a used Facet pump but it has no p/n label on it. How do I tell which one it is? Also, I was considering mounting it in the same place as the old mechanical fuel pump using the same bolts that hold on the blanking plate. The problem is that the metal filter like the Ford one you noted points down and interferes with the crankcase breather pipe. Can I just put a hose barb elbow in place of the filter and use a separate inline fuel filter? Or is there some function that the metal filter provides?
Regards,
p.s. sorry for hijacking this thread.
TR3driver
Look carefully, normally the part number is stamped into the metal wrapping. If it's not there, I think you've probably got one of the 'clone' pumps. Only way I know to test it is to hook up a pressure gauge (and 12v and something for it to pump). Most vacuum test gauges will also read fuel pump pressure. (for carburetor type pumps, not fuel injection)
https://www.harborfreight.com/fuel-pump-and-vacuum-tester-93547.html
I don't know of any reason you can't put the filter remotely. The pump seems very tolerant of crud in the fuel, so I don't actually have a filter at the pump at all, just the stock in-line near the carbs. However, note that Facet recommends that the pump be mounted near the fuel tank.
https://www.facet-purolator.com/faq.php
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
steveg Fuel pump inertia cutoff switch Austin Healey 33
B T-Series Fuel pump inertia switch? MG 4
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
