flat spot
radibob
I have a 66 Sprite with a rebuilt 1275, new distributor and Petronix. My problem is that exactly at 2500 rpm's I have a misfire and rough running, above that point it smooths out and below it's also OK. I've checked the carbs over and over again but they are the only "old" part on the car so I suspect them. I've checked the float levels too but I suspect that they could be the problem. Recently retarded the timing with no effect.
Any ideas before I tear into the carbs again.
R
radibob
So I was just reading some of the other forums and I have been using MMO in my dashpots and there is a bit of a stumble occasionally on acceleration, so I am thinking I need to use a heavier oil in the dashpots???
AN5Sprite
Change the dashpot oil, check the dashpot springs too. Should be A. the same and B. not all stretched out. I've seen mismatched and worn needles too. Check those.
My .02$
Bayless
Yes, heavier oil in the pots will help with the stumbling on acceleration. It server the same purpose as the accelerator pump in more typical carbs, enriching the mixture for acceleration. But it will not affect steady speed running at any rpm. Also, there has long been a wise old saying, "90% of all carb problems turn out to be electrical." That said though, I don't have a suggestion yet.
jlaird
I don't either but do not think fuel. do you have another electrical system besides the new one?? is the distributor indeed new or rebuilt, who did the rebuild? I would suggest that the distributor needs to go on a sun machine.
F
fixitright
Have you checked your automatic advance mechanism, I dont know if you hace a vaccum controlled advance or just straght manual weight controlled advance mechanism. Also see if you have a broken or missing return spring. Check to see if the distributor rotor will move on its shaft. This is the most neglected part of any lubrication procedure. Most distriburors have a felt pad as a way to retain oil for the shaft under the rotor and should be oiled lightly during each routine oil change.
R
radibob
The distributor is new from Northwest Auto Parts (not sure of exact name) I checked the advance (Vacuum)and it looked like it was working. I will check Distributor again for cracks, arcs and advance though. Thanks for the great ideas. I am on my way to Advance Auto for 20 W oil for the dashpots...
jlaird
Shucks, anything will work in the dash pots all else being ok. Sewing machine oil, etc, I use what I run in the engine.30W. Know that I have never had an engine tuned to the point that dash pot oil did or could make a difference.
Call Jeff Schlemmer at Advanced distributors, 612 804 5543. He is the expert on all distributor things and has the right equipment to check them out and is a nice guy. www.advanceddistributors.com tell him hi for me.
He rebuilt Miss Agathas 50 year old unit that was really bad and made it like new. Runs like new as well.
R
radibob
So you guys will love this. Before going to get the oil I pulled the Distributor cap. I was using for the first time my Costco LED light and it is REALLY bright. I noticed on the inside of the cap sort of a spray of brass particles after each contact. The rotor looks Ok but has been obviously scoring the Distributor contacts and creating a dust of brass particles on the under side of the cap which you can't see in day light. The rotor is a proper orange one with the riveted contact but the cap is black with a rounded top. Not sure of its origin but It looks like a new cap and rotor is in order.
Not sure if this is THE problem but with new dashpot oil and a new cap and rotor things would have to be better.
jlaird
So, throw in your spare, you do have one right? Hows that work?
Or does that mean that your new distributor has a bad or worn shaft bearing?
The good race ready rotors do not have a rivet to get loose if that is the problem, could be.
R
radibob
Lookin for my spare cap right now. Yeah I know, it should be in the car...
Jim_Gruber
And Jeff has the correct Red not orage rotor that you need.
jlaird
Sure is quite on this thread, supose we touched a nerve or..........
BWA
Also, there are two lengths of rotor, a short one for the two earlier style caps, and, a longer one for the later cap.
I had a customer with a Spitfire that did exactly that at mild throttle openings, stumbled slightly about 2500 rpm, but, was fine above or bellow that, and, under hard throttle. It had the short rotor with the later cap which requires the longer rotor.
T TR4/4A Flat/dead spot on the starter? Triumph 5
J Oilcan spot on fender [IE: not flat, sticking out Triumph 2
M Flat Spot on my Weber 32/36 DGV MG 3
C HS2's...big ole' flat spot! Maybe I need to just pay someone. Triumph 27
A Flat spot, hesitiation, call it what you will... MG 17
W Flat spot? MG 8
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
B General MG Does odometer record when flat towing. MG 5
71TR6 TR2/3/3A New engine mounts not sitting flat Triumph 41
B TR4/4A Head gasket won't lay flat Triumph 13
J TR2/3/3A Trunnions - Chamfered vs Flat Top Triumph 3
P TR2/3/3A TR3A Windshield Frame Curved or Flat? Triumph 7
T Modern Oils for Our Flat Tappet Engines Austin Healey 26
T Modern Oils for Our Flat Tappet Engines Spridgets 7
H Joan Baez flat floor '61 roadster, what did the Feds sell it for at auction? Jaguar 0
NutmegCT Flat head [L-head] engine question Other Cars 5
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
H Joan Baex 1961 flat floor--silver exterior--anybody know what IRS sold it for? Jaguar 0
H Joan Baez flat floor series I e-type roadster: what did the authorities dump it for? Jaguar 0
J Had a flat on the way to Mini Mania open house Austin Healey 4
drambuie Bonneville salt flat moment Austin Healey 15
M TR2/3/3A Repairing a flat tire on TR3 Triumph 15
glemon Series 1.5-2 E type, flat towed Spotted 0
Cottontop Flat towing a TR 4 Triumph 1
6TTR3A A FLAT TIRE ??? Triumph 13
J TR4/4A 67 TR4A IRS Hood Bumpers-Cones or Flat? Triumph 8
TR6oldtimer TR6 TR6 windscreen and rear flat black Triumph 4
Morris 9:1 flat top 1500 pistons Spridgets 0
Basil More Drool. A 3.8 Flat Floor EType! Jaguar 13
V flat towing? Triumph 10
T Curved vs flat glass - what is the scoop w/ that? Triumph 9
Stewart Flat spots at 4k and 5k MG 13
B Stupid Question..flat tire issue Spridgets 3
T Flat. Stopped. First or second gear? Austin Healey 4
Steve Morgan Flat Rad on eBay Other British Cars 6
MadMarx Tappet - flat or domed? that's the question Triumph 5
T Daddy, can we take the flat car? Triumph 14
Kirk_Fisher 1st flat tire Triumph 7
V TR6 TR6 Flat Tappet Triumph 12
SpannerMan Tire repair or fix-a-flat [wire wheels]. Triumph 11
J Flat tire/tube issues MG 8
F GT6 Domed or Flat pistons? GT6 MK3 Triumph 10
MattP Just flat wrong Other Cars 14
B '61 flat floor roadster Jaguar 5
Mickey Richaud MGB MGB Flat Bar Luggage Rack MG 13
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
L Tight spot on steering box is way off Austin Healey 18
Basil SOLD!! Lucas Spot and Fog lamps Jaguar Classifieds 1
