Curved vs flat glass - what is the scoop w/ that?
tdskip
Is there a specific model and year the cut over happened? Let's see who pulls that detail out of their brain and responds first....
Mickey Richaud
I believe the change occurred in the TR4 models; early ones had convex, and later ones the flat. Don't know the change point, though.
TR3driver
Great Pumpkin - R.I.P
Assuming you are talking about the glass in the gauges, CT11308 was the first TR4 with the flat glass (according to the Moss catalog). The style of the gauges changed as well, it wasn't just the glass.
HerronScott
The Nisonger catalog page I have from way back when indicates the change to flat on the TR4 in 6/62.
Scott
Lou Metelko
The domed glass gauges had the entire needle exposed while the flat glass had approximately the lower half of the needle exposed. The domed glass gauge of the early TR4s were identical to the the late 3As and Bs. Good example of Triumph useing up old stock!
Lou Metelko
Auburn, Indiana
bgbassplyr
Mine, CT5586, has domed glass on the guages.
TexasKnucklehead
Not exactly. The first year TR4 had curved glass, but the temperature guage was electric, using a sender, not the type with a bulb/ether. The Speedometer and Tach also have different sized white rings painted on the face and the tach has a red area instead of a red line. Later the guages changed the visibility of the needle.
Subtle differences to the eye, but in the case of the temperature guage, they were definately not old stock.
HerronScott
Correct, part numbers for the TR3 include the following according to the Nisonger documentation:
SN 6319/00 3.7-1
SN 6319/02 4.1-1
SN 6319/04 4.1-1 5/56- (Note I found another reference showing
SN 6319/06 3.7-1 5/56- these part numbers for Michelin X tires)
Part numbers for the early TR4 include the following:
SN 6313/09 3.7-1 590x15
SN 6313/11 4.1-1 590x15
SN 6313/15 3.7-1 155x15
SN 6313/13 4.1-1 155x15
SN 6313/19 3.7-1 165x15
SN 6313/17 4.1-1 165x15
Scott
TR3driver
:iagree:
BTW, the TR3B still got a mechanical temp gauge, even when the TR4 was getting an electrical one.
P TR2/3/3A TR3A Windshield Frame Curved or Flat? Triumph 7
K For Sale Curved tube intake manifold...2" Triumph Classifieds 2
HerronScott Why convex/curved glass for gauges? Triumph 11
F TR2/3/3A TR3A Curved Windshield??? Triumph 6
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
B General MG Does odometer record when flat towing. MG 5
71TR6 TR2/3/3A New engine mounts not sitting flat Triumph 41
B TR4/4A Head gasket won't lay flat Triumph 13
J TR2/3/3A Trunnions - Chamfered vs Flat Top Triumph 3
T Modern Oils for Our Flat Tappet Engines Austin Healey 26
T Modern Oils for Our Flat Tappet Engines Spridgets 7
H Joan Baez flat floor '61 roadster, what did the Feds sell it for at auction? Jaguar 0
NutmegCT Flat head [L-head] engine question Other Cars 5
T TR4/4A Flat/dead spot on the starter? Triumph 5
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
H Joan Baex 1961 flat floor--silver exterior--anybody know what IRS sold it for? Jaguar 0
H Joan Baez flat floor series I e-type roadster: what did the authorities dump it for? Jaguar 0
R flat spot Spridgets 13
J Had a flat on the way to Mini Mania open house Austin Healey 4
drambuie Bonneville salt flat moment Austin Healey 15
M TR2/3/3A Repairing a flat tire on TR3 Triumph 15
glemon Series 1.5-2 E type, flat towed Spotted 0
J Oilcan spot on fender [IE: not flat, sticking out Triumph 2
Cottontop Flat towing a TR 4 Triumph 1
6TTR3A A FLAT TIRE ??? Triumph 13
J TR4/4A 67 TR4A IRS Hood Bumpers-Cones or Flat? Triumph 8
TR6oldtimer TR6 TR6 windscreen and rear flat black Triumph 4
Morris 9:1 flat top 1500 pistons Spridgets 0
Basil More Drool. A 3.8 Flat Floor EType! Jaguar 13
V flat towing? Triumph 10
Stewart Flat spots at 4k and 5k MG 13
B Stupid Question..flat tire issue Spridgets 3
T Flat. Stopped. First or second gear? Austin Healey 4
Steve Morgan Flat Rad on eBay Other British Cars 6
MadMarx Tappet - flat or domed? that's the question Triumph 5
T Daddy, can we take the flat car? Triumph 14
Kirk_Fisher 1st flat tire Triumph 7
V TR6 TR6 Flat Tappet Triumph 12
SpannerMan Tire repair or fix-a-flat [wire wheels]. Triumph 11
J Flat tire/tube issues MG 8
F GT6 Domed or Flat pistons? GT6 MK3 Triumph 10
M Flat Spot on my Weber 32/36 DGV MG 3
MattP Just flat wrong Other Cars 14
B '61 flat floor roadster Jaguar 5
Mickey Richaud MGB MGB Flat Bar Luggage Rack MG 13
C HS2's...big ole' flat spot! Maybe I need to just pay someone. Triumph 27
A Flat spot, hesitiation, call it what you will... MG 17
W Flat spot? MG 8
RCarr Windscreen Glass Options Austin Healey 2
W Glass Washer Bottle Lids Austin Healey 0
