Finally rebuilding the 8 engine
PATR8
Ok, after many false starts, delays, and probably good decisions, I am ready to start the rebuid. I took the engine and had the new cam bearings installed and the block cleaned.
So as I get ready to start the I have two concerns immediately, Woody's new cam I got did not come with the break in grease and I do not remember if there was new grease for the crank bearings...
Am I right in beleiving that there is special grease for that?
Mickey Richaud
Here's what you want:
Comp Cam
Mickey
WedgeWorks
You need cam lube typically a gray paste and if you have the crank rod and pistons installed the machine shop would use engine assembly lube. If you are doing it then you will need some engine assembly lube and dont forget the plasti-gauge to check tolerances.
AS for engine lube, different from camshaft lube, the Comp Cam suggestion is a good one. Ok back to engine assembly lube, the red stuff they sell in most auto parts stores is horrible, it drians off the parts you put it on, I and many professional engine builders swear by CRC Moly engine assembly lube, it comes in a tooth paste looking tube and you can get it at NAPA stores, it stays where you put it, and will not drain off on the engine stand, just don't put it on cylinder walls, I use 30 wt motor oil for that.
Mickey Richaud
Yep - sorry my post wasn't clear. That was for the cam only.
mctriumph TR2/3/3A Finally painted the 63 3b Triumph 14
J TR2/3/3A TR3A Finally on the Road! Triumph 6
AngliaGT Finally - A (Mostly) True craigslist Ad Other Cars 0
Grantura_MKI Pre-War Finally arrived. MG 7
HealeyPassion Finally, paint on chassis Austin Healey 17
Lou E Finally a Bugeye of my very own Spridgets 41
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
Bayless A Sprite gets some paint finally Spridgets 2
EricJNewman MGB Weird Brake issue finally solved. MG 1
Rob Glasgow Finally Found It (Original License Plate Number) Austin Healey 3
J Shroud Painting ["Finally done with these"] Austin Healey 3
Rhodyspit75 Finally on the road Spridgets 7
AngliaGT MGB FINALLY Got the Engine Out MG 5
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
Tr3aguy TR2/3/3A Tr3 frame work finally Triumph 93
Jim_Stevens TR2/3/3A Finally- the color coat! Triumph 12
Basil I finally joined Jaguar 4
J General TR Finally on the road Triumph 1
Bayless More Sprite progress finally Spridgets 23
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
Bayless Progress finally begins Spridgets 5
tinman58 General TR Finally almost Triumph 7
J TR2/3/3A Finally getting started Triumph 20
Elva164 Finally did another onboard video! Racing 4
J It is driveable! Finally. Morris 8 Other British Cars 8
M Finally Joining the Bugeye club! Spridgets 20
simon1966 Rain cleared up so finally got out. Austin Healey 31
tomshobby TR6 Finally finished my custom steering wheel. Triumph 12
B The Prince of Darkness on the dash board finally conquered Austin Healey 10
vickxxx T-Series Finally MG 3
Sarastro TR4/4A My TR4A finally arrived! Triumph 11
B Scuttle shake finally sorted Austin Healey 23
B Finally - BJ7 painted Austin Healey 3
Jer when something doesnt make sense... and you finally figure out why ! Spridgets 4
Basil Back to the EType finally Jaguar 5
Marvin Gruber Three rebuilt BJ8 engine- FINALLY! Austin Healey 17
J TR2/3/3A Finally started 17 year old rebuilt motor! Triumph 3
drooartz Finally found one Spridgets 8
L Are 100's finally eclipsing the 6 cylinder cars Austin Healey 6
trrdster2000 GT6 Finally got a photo of some of our work on the Spit 6 Triumph 2
T TR2/3/3A Finally found and fitted paper carb air filters on my TR3 Triumph 28
Steve P. Finally found a RWA Midget Spridgets 1
CJD TR2/3/3A TR4 Gearbox in the TR3...Finally! Triumph 3
R GT6 Finally Finishing Triumph 19
Sherlock It's driving season finally! Spotted 5
J Finally a fix for the SU pump Austin Healey 5
F MGB Finally got my 78 MGB on the road MG 5
F Spitfire Finally Mobile! Now Grind/Rubbing from Clutch, Gearbox Or? Triumph 5
mgedit General TR Finally a Sniff of Spring Triumph 3
