MGB Fair price for an MGB radiator re-core?
Scott_Hower
So the rad shop called over lunch. The pressure test revealed that the radiator is leaking, which really does not surprise me. Shop boss told me that he could probably patch it, but that soldered copper joints subject to constant water/corrosion/vibration wear out over time and he would not guarantee his work due to the age. He is working up an estimate to recore it and remove a dent from the brass lower tank, which he will guarantee. He told me it would look exactly like the old one, which is sort of important to me. Anyone have an idea of what this is going to cost? Should I go with a 3 or 4 row core?
Moss has MGB radiators in stock, but I understand they are on "quality hold" or some such and won't ship one. Anybody bought one recently? If the quality is questionable, I probably don't want it anyway.
Platinum
Recore the one you have with a four row core and go merrily down the road. I'd not risk money on the *new* one anyhow. Not unless I'd run out of old ones to re-core first. You're lucky to have a shop around that'll take the time to DO that work!
sparkydave
FWIW, I had my Midget's radiator re-cored for $100. The only problem was when I went to install it the guy had soldered the lower bracket on backward, not realizing that the mounting holes were offset from the center. Oops. But he fixed it quickly and I haven't had any trouble with it.
Platinum
The MGB here had a re-core with a foour-row a number of years back. Great improvement in cooling efficacy and was about the $100 range. But that's been a while ago, and it was a "jobber" price as the guy who did it was the fella we used for all our shop work... he loved us: Rolls rads are NOT cheap! /ubbthreads/images/graemlins/wink.gif
Scott_Hower
Scott_Hower
[ QUOTE ]
Recore the one you have with a four row core and go merrily down the road.... You're lucky to have a shop around that'll take the time to DO that work!
[/ QUOTE ]
Thanks; the shop is only a few miles away from me. Owner seemed like a nice guy.
Scott_Hower
Scott_Hower
[ QUOTE ]
[/ QUOTE ]
Got the quote. It's more than a new repro radiator /ubbthreads/images/graemlins/shocked.gif
I gave them the Ok to rebuild it anyway. They're going to remove a dent from the lower tank and glassbead the tanks and the frames. Comes with a 3 year warranty. It's only a three core, but the tubes are spaced closer, and they swore it would have at least as much cooling capacity and likely more than the original. Or so they claimed. They cannot do a four core "flat-fin" radiator. I would have had to go with a corrugated fin which they said would look weird on an MG. My temp gauge has never made it beyond halfway, so hopefully it'll be Ok.
Will post photos when it's done.
tony barnhill
Great Pumpkin - R.I.P
WOW!! I have em recored & repaired around here for around $100 also - the new ones aren't all that bad - quality-wise...but anything OE is always the best to use.
sultanoswing
I got a recore recently..cost me $380 NZD - which, compared with new/repro items, and what you guys are quoting is a bit of a price gouge. Having said that, I think it's one of the things that is just more expensive here in NZ. Sigh. At least it's only a 10-yearly (at least) job.
Platinum
I think we had this dance before but: You're onna north island, yes?
tony barnhill
$380NZD...how does that convert to US or Canadian?
Platinum
Like he's been gouged.
sultanoswing
$380 NZD = $240 USD. Yup. Gouged. Ouch.
DrE - North Island...but I'm actually in the UK and have been for a couple of months (and two more weeks) on study leave in York. Rest assured my luggage is loaded (to the 20kg limit) with cheap, VAT & duty-free MG bits. Makes me feel better about the radiator. Actually, so do the cheapish Superpro (=Superflex) bushings I just bought from a NZ supplier, which are a good deal compared to the US/UK, since they only have to come from Australia.
Scott_Hower
Scott_Hower
[ QUOTE ]
[/ QUOTE ]
Then I'm getting bent over.
Edit: I hate to feel like I'm being ripped off. I wonder if we are talking the same thing. They are not going to remove a tank and rod out the existing core. They hot tank, completely dissasemble the entire radiator, glass bead the components and hand solder a new custom made core into the tanks. Reassemble, pressure test, paint. My lower tank has a pretty good bash in if that they are going to remove as well.
I called back and told him that folks are having this job done "in the $100-$125" range, he flat out told me that his wholesale price on the core itself was close to that and that price was simply not possible for a recore.
Maybe I'll dig out an old Hemmings and call around...
Grantura_MKI
Cooling is made by the number of fins per inch. If you add more tubes, you are creating a heater core. /ubbthreads/images/graemlins/yesnod.gif The trick is flow and fins. Hope this helps.
Cheers, David.
tony barnhill
Well, another reason north Alabama is the best kept secret in the country! Course I probably do a dozen or more radiators a year plus gas tanks with my guy so he might give me a deal.
...that N everyone who knows you thinks your a reseller anyway - hehehehehehehe. /ubbthreads/images/graemlins/thumbsup.gif
tony barnhill
Well, true, they know I'm shipping them to customers....
Platinum
Scott, as I said: this was a while ago and it was at a "jobber" price in my case. It wouldn't shock me to find it would cost $200~$300 for that job on a "walk-in" basis. I'd still have it done over a replacement with a "new" one.
Scott_Hower
Scott_Hower
[ QUOTE ]
[/ QUOTE ]
Ok, thanks.
I don't understand the comment on fins and cooling capacity. The fin surface area is exactly the same. I've always been told by the hot rod guys that adding more rows (going from 3 tube to 4 tube) of tubes increases radiating efficiency. I don't understand how you can add more fins to a given radiating area. Someone said this would be analagous to building a heater core - I'd think that's exactly what I want to do - transfer heat from the coolant to the rad. And let the fan/roadspeed airflow carry it away.
The shop I'm using specializes in radiators, that's all they do. I really dont want to second guess them (at least not on price).
Platinum
As I commented before: you're lucky to find a shop that'll DO this kind of work, IMO.
Most just rod 'em out and send ya packin'.
S TR4/4A Fair price for a crankshaft? Triumph 2
Bmekosh TR6 Fair price for this car? Triumph 16
J TR6 Is This a Fair Price for TR-6? Triumph 25
HCE What is a fair price for a ’69 XKE? Jaguar 19
C What is a fair price for a Caterham? Other British Cars 2
Rut Fair price for a Midget? Spridgets 10
D TR6 TR-6 Steel Hardtop -- fair price? Triumph 4
G Fair price on O/D switch and knob? Triumph 5
PATR8 What would be a fair price Triumph 1
H Fair Price for a Hartop? Austin Healey 1
B Fair price? Triumph 9
M What would be a fair price?? Jaguar 3
R Fair Market Value Triumph 15
T Last OT for today - psychic fair Triumph 5
L Does this seem fair? Spridgets 6
G Incorrect Temperature Guage: a fair assumption? Triumph 14
G TR6 Fair value for a rebuilt TR6 engine Triumph 6
Trevor Jessie Fair trade? Spridgets 4
A Fair Value? Jaguar 5
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
UltimateQuestion For Sale Price Reduced! 1972 GT6Mk3 Project Cars and lots of parts Triumph Classifieds 0
tr6nitjulius For Sale "PRICE REDUCED" 4Sale: TR6 (L/R) taillight assembly Triumph Classifieds 0
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
S Price check on TR3A valve cover Triumph Classifieds 0
G TR2/3/3A Valvoline VR1 price Triumph 3
Healey Nut If you want a M but cant afford the real M price tag Austin Healey 24
K For Sale TR3 Wheel spacers...Never Used...1/2 Price Triumph Classifieds 0
Morris Price drop Spridgets 1
B For Sale 1959 Austin Healey, Bugeye Sprite with 74k Miles Price Drop- NEED TO SELL Spridgets Classified 0
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
W At this price..... Spridgets 3
C 100-4 At Mecum Kissimmee Auction-low price? Austin Healey 22
jlaird Miss Agatha has a new price Spridgets 45
AUSMHLY Going price for BJ8 glovebox lock Austin Healey 6
PAUL161 General MG Automotive Paint Price! MG 13
1 Price for original 57 100-6? Austin Healey 22
Editor_Reid T-Series Original Price in US Dollars for an MG TF 1500 MG 4
W Good price on Pacesetter Monza Muffler Spridgets 0
sqbsprite What will be the real price? Spridgets 11
B Hard Top Price Guestimate Spridgets 1
J Help me price my Bugeye? Spridgets 37
PAUL161 T-Series Engine rebuilds going up in price! MG 14
Jim_Gruber BE Bonnets - OMG the price Spridgets 5
BoyRacer BN2 bellhousing - how rare - price? Austin Healey 2
G [Price] King Midget ? Spridgets 12
K Reasonable price for a Morris Minor project car? Other British Cars 4
aeronca65t Replica Price Lotus 3
