Dropped radio antenna into fender.
2wrench
Okay. Painting the car. Removing the antenna and, oops,
slipped through my fingers and dropped right down into
the abyss of the fender.
Thought little of it at the time. So now it's time to
retrieve that little sucker and I can't seem to find it
in the fender. Poked around with a magnetic tool for
picking up dropped nuts and the like. Nothing.
Using the flashlight through the hole in the top of the
fender, cannot find the antenna.
Anybody suggest how to get it out of the fender -- oh,
yeah, the car is a '74 TR6.
Thanks,
Brosky
Pull the carpeting back. Three or four small screws hold it, easy to rip past them, so be careful.
It will be there. And when you fish it back up, wrap a big wide strip of masking tape around it like a flag, so if it slips, it isn't going straight down again.
tdskip
Wimps - remove the fender!
and then the old rust proofing
and then sort out some minor rust spots
and then, since access is pretty good at this point, decide the rebuild the front suspension
hey, that frame could use some paint
gee, it is kind of hard to the the frame painted properly while the body is still on it...
You've been warned. <grin>
AltaKnight
Beware the deadly "Shipwrights Disease"
2wrench
2wrench
Uhhhh, wellll, uhhh, maybe I'll go fer ripping back
the carpet at the footwell thing. I'm still reeling
from painting the thing.
Ain't nothing like a fly in the paint. (Did this job in my front driveway, you know.) Hey, these little insects buzzz on over the car, get high off the fumes, lose their breath
and fall right in.
Dang! I got a mask! This stuff is enough to kill a guy.
Thanks to all for your responses.
Tomshobby, (wish I could figure how to know your real names), I like the tool idea. Might be good just to have around. My mind keeps thinking about other things I
could use it for...... but actually, I'm kinda drawing
a blank. Certainly might go there if antenna not seen in the footwell, though.
Thanks again for the help from my friends on the
net.
tdskip
Where exactly is the fender hole located on your car?
So in all seriousness, I think you might need to pull the fender. If it fell down into front fender it is likely stuck in the air gap between the inner and out fender.
swift6
If it is too far forward to have fallen inside the cockpit and is between the outer and inner fender, then you should have a mud guard inside the fender area that you can unbolt and access that area. There should not be a need to totally unbolt the outer fender.
R
RonMacPherson
Left click on the poster's name, drop down box will come down, select user profile, or Pm him. He's also built a very nice TR6 that crops up on the 6 packorg site regularly.
TR3driver
Great Pumpkin - R.I.P
I've got a really neat telescoping magnetic pick-up tool that also has an LED light built into the tip. It's great for hunting things inside dark cavities. Might not be strong enough to lift an entire antenna, but I'll bet it would get the tip up where you could grab it with something else.
Sure wish I could remember where I bought it /bcforum/images/%%GRAEMLIN_URL%%/frown.gif
Might have been Horrible Freight; but I don't see it listed on their website.
BOXoROCKS
A magnet wont work if its brass. Get a long thin dowel,wrap it with duct tape backwards,sticky outside,stab around until you snag it.
TR3driver
True, but all of mine have steel in the top section.
Darrell_Walker
I assume this antenna has a cable that connects to the radio? Could you track it down that way?
Geo Hahn
My antennae (sp?) are all stainless steel, thus a magnet would be useless.
I just did this task (antenna retrieval) on a friend's Porsche the other day using one of those grabby tools. Fortunately he is a Stanley tool rep and had a little flexing LED that let us get light into the cavity and see in at the same time (hard to do with a regular flashlight).
JPSmit Dropped off the engine for the Vauxhall last week Spotted 3
stretchit2 Oh No I Didn't or the Dropped Not Blues Austin Healey 6
philman Wedge Dropped another engine in my TR7v8 Triumph 11
ChrisS Almost dropped a valve Spridgets 7
BugEyeBear Healey-Abbott - For Sale - PRICE DROPPED!! Austin Healey 0
hondo402000 TR6 TR6 dropped the Diff out and half shaft question Triumph 2
S Dropped off the garage space at Drew's yesterday Spridgets 1
healeyboz Dropped in the motor and transmission Spridgets 2
zoohow radio and console mount Restoration & Tools 1
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
J TR2/3/3A TRIUMPH Radio? Triumph 13
S Radio Antenna Spridgets 5
D Removing Old Radio Austin Healey 4
T TR2/3/3A Question on old radio from my TR3 Triumph 9
Got_All_4 TR5/TR250 Pros and Cons to Wiring The Radio Direct Triumph 6
E Alpine radio for a US Model Db7 Volante Other British Classifieds 0
Hangtown Healey Barbie Clock-Radio Austin Healey 9
M General MG OEM Radio wiring help MG 4
pkmh Radio Knob Design For A 67 BJ8 Austin Healey 16
red57 Positive ground radio Austin Healey 17
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
T how to have music/radio when driving Spridgets 33
7 Strange A/C - radio problem Other Cars 7
Jim McCauley TR6 TR6 Radio recommendation Triumph 4
M Fitting a modern radio Austin Healey 9
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
1 MGB '66 MGB radio measurements MG 3
6 Spridget Radio/Speaker Case Spridgets 4
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
Tim Tucker TR4/4A BENDIX Radio Model: 5SMTR manual? Triumph 2
T Wanted Wanted: BE Sprite Original Motorola Radio Spridgets Classified 8
F TR2/3/3A radio mounting plate Triumph 4
H Vintage Radio Austin Healey 9
Zitch TR4/4A Original Radio knobs Triumph 12
M S1 e type radio console Jaguar 2
wangdango BJ8 radio delete plate? Austin Healey 2
Got_All_4 TR2/3/3A TR3 radio console Triumph 30
Marvin Gruber Becker Mexico radio Austin Healey 7
kennypinkerton MGB Radio console removal question MG 4
D Radio! Other Cars 0
Zitch General TR WTB - Triumph AM radio. Triumph 11
roysimpsonjr TR4/4A Will an 8 inch wide radio fit? Triumph 3
Scotsman General TR Radio Triumph 4
M TR2/3/3A Phone charger & Radio can I put these in my car??? Triumph 7
K TR4/4A Stock Triumph Radio Troubleshooting? Triumph 4
G original radio 1961 e series jaguar Jaguar 3
TulsaFred Bugeye radio in-dash Spridgets 10
B orginal BMC radio Austin Healey 9
Mink TR4/4A Radio plate/dash support orientation Triumph 6
C TR2/3/3A Triumph radio installation date code Triumph 7
