TR2/3/3A Dash Restoration
DornTRoriginal
Anyone have some good recommendations for restoring the dash panel? I sprayed some glossy black paint on it and it was terrible so I quickly wiped it off. Is this painted or a sticky backed covering? Stripe and start over? Power coat? what to do? Anyone have a suggestion on how to make the panel look great? Restored instruments that are fabulous, newly covered dash and trim etc. the panel needs to look great! Ideas and suggestions please and thank you!
charleyf
The original finish for TR3A and B is to use black wrinkle paint. Available from TRF and I would expect Moss as well. I have also found it at local stores.
Follow directions and it can produce a very attractive result. I will admit that I have added the use of a heat gun to produce a better result.
mrv8q
I used Eastwood black wrinkle paint back in 2005, and it still looks fine. Using a heat gun did the trick.
TR3driver
Great Pumpkin - R.I.P
There is also wrinkle black powder coat. I had Fred Thomas do mine about 15 years ago and it still looks great.
martx-5
I used a black wrinkle (I'm pretty sure it was Rust-O-Leum) and cured it in my oven...while my wife was away! :glee:
Gordon_Dedrick
+1 with Art for paint plus heat. There is a gent here on the forum that sells councours quality TR3 cluster rebuilds. He was kind enough to give me his recipe: Preheat oven to 225, Four light coats of wrinkle paint, bake in the oven for one hour, and let it dry for a week. Unfortunately my wife came home before I could get the odor out of the kitchen.........but the gauge cluster still looks "original" after 8 years !
Gordon
Mickey Richaud
VHT wrinkle paint, available at most auto parts stores. I did the BGT dash several years ago, and heat is critical. My method was to hang it in front of the fireplace (winter project), and it came out perfect! Wife was happy, too... :wink: Did the valve covers and brake/clutch master cylinder housing as well.
Kleykamp
I, too, used the wrinkle paint out of the can. I believe I bought it at Advance Auto Parts. I just followed the directions on the can ( apparently a novel concept ) and it produced excellent results with even coating and texture.
6TTR3A
I favor the VHT Wrinkle rattle can for my restorations. It only comes in 4 colors
but I discovered a trick to finish it in any color. Do the wrinkle in black or
gray, then, when it is fully cured, spray the finished product in a light coat
of enamel in whatever color you choose. I did a Morgan plus four panel in
black, then dark brown. So close to factory no one could tell.
Dr_Mike
My TR3A came with what seems to be a TR2 dash panel: never painted and covered with leather(?). I have an unopened can of wrinkle paint (circa 1998) from Eastwood if any one wants it, as I like the look of what I have!
J Temperature check and dash restoration advice Triumph 10
P Dash Restoration Austin Healey 8
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
BoyRacer Blue Vinyl Dash Material Austin Healey 3
jfarris TR2/3/3A Dash Lights Triumph 3
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
R Ground wires under dash Spridgets 5
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
B TR4/4A Dash Color? Triumph 3
EWD TR6 TR6 top dash trim paint Triumph 2
TomMull Dash wiring Plus 2 S Lotus 16
I TR6 Dash light issues Triumph 19
J Attaching BT7 Dash Facia Panel Austin Healey 2
EWD TR6 Dash Pad Replacement Triumph 3
longbridgehealey Bugeye dash Spridgets 6
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
Basil New Dash Cover in the Telly Other Cars 3
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
steveg TR6 Metal Dash - does anyone make one? Triumph 13
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Dash repair Triumph 7
M Getting behind the dash on BJ8 Austin Healey 4
Rut TR4/4A Dash color Triumph 9
Rut TR4/4A TR4 wood dash Triumph 26
J Walnut veneer for the dash, Look what I found! Austin Healey 12
I TR6 Thickness of original TR6 dash Triumph 2
S TR2/3/3A Dash Pot Oil Triumph 14
TRMark T-Series Dash for Sports/Racer MG 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
TomMull replacing walnut veneeron the dash Lotus 17
K TR2/3/3A Dash Lights Triumph 3
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
Zitch For Sale OE Under Dash Speaker refinished new speaker installed Triumph Classifieds 0
BillyB62 TR2/3/3A Wood dash & center console examples Triumph 7
