dash bulbs
jvandyke
Can dash board light bulbs be had easy off the shelf somewhere? NAPA had nothing like them. I'm looking for the little screw base ones for the ignition warning light and high beam indicator.
JPSmit
I couldn't find them anywhere but through Moss
I think those bulbs are E10 base. Use the Google young Skywalker...
jvandyke
jvandyke
Well looks like all the same bulb for each gauge as per Moss but on my new harness the sockets with the prongs, that press into the back of the main gauges, are different, bigger "thread" area. What's up with that?
scoutll
Jeff,
Here you go. The best price I have found on them.
Search Ebay Item 130252068905
The sockets on mine look bigger, but the threaded area is the same size. Should be the same on yours, unless some grafting was done.
Bryan
jvandyke
jvandyke
Thanks for the link. Okay, bulbs do fit in new sockets, took a bit of tweaking with a screwdriver and some convincing but they will thread in.
AUSMHLY
Hi guys,
Can I come over and play?
If you have Smith gauges like the ones I have in my Austin Healey, the bulbs are 12v 2.2 watt.
jvandyke your link above, Radio Snack.
14.4V 100mA incandescent flashlight bulbs. Wrong voltage.
I did a lot of research on this very topic of replacement bulbs.
Actually, it was about how to put a brighter bulb in.
You can purchase stock 12v 2.2 watt E10 base bulbs from British Car Specialists in Stockton California.
If you want a brighter bulb, 12v 5 watt E10 you can get them from Bulb Connection.com
https://www.bulbconnection.com/ViewItem/bcrw/itmid/2681/oc/12V5WMS/item.html
If you want to change out your filament bulbs to led's then here's a link to my post on the Austin Healey side.
https://www.britishcarforum.com/bcforum/ubbthreads.php/topics/514840/1
Cheers,
Roger
PAUL161
Thanks Roger, Very nice article. I book marked it for future reference.
jvandyke
jvandyke
I am very electrickity challenged but I thought a 14.4v bulb could handle that many volts, 12v should still light it fine? No idea how 100 mA relates to watts and all that.
Read the thread on LED conversion too, cool.
My situation is a bit unique in that my dash is 1" thick oak so the fuel and oil/temp gauges (that normally just get incidental light through their little blue windows from a bulb shining on the back of the dash) were not lighted at all.
Since I wanted to install a pointless ignition which led to converting to negative earth, which led to an engine bay clean up, which led to a full harness replacement which led to pulling the dash which led to re-doing the whole dash....I cut tunnels in the wood around the perimeter of these two gauges and am mounting the old harness's high beam warning and ignition warning lamps to shine into these tunnels. Works great but leaves me a couple bulbs short.
theleisure
Bronze
ain't that how it goes.... geez
I think my girlfriend just realized that about me & the sprite. We're getting close to her threshold I think.
jvandyke
jvandyke
Oh it keeps going too....led to seeing some rust under battery/heater box, led to touching that up, tearing down, stripping de-denting and powder coating the heater box...oh and the harness upgrade also led to headlight relay install and probably redoing the headlight harness.....and on and on.....having fun though.
BugEyeBear
theleisure said:
...I think my girlfriend just realized that about me & the sprite. We're getting close to her threshold I think.
<span style="font-size: 12pt"><span style="font-weight: bold">I have an EX-girlfriend who used to call my Sprite project "Camilla".</span></span>
-Bear- :cheers:
tweety
funny, I've been described as a "couple bulbs" short also.... But that was not in reference to my LBC
jvandyke
jvandyke
I stopped by a Radio Shack on my way home and bought some of the above (or something similar) they work, a tad dimmer to the naked eye maybe. They'll do in a pinch if you lose a bulb on a trip or something.
BugEyeBear
Does Rad-Shack have a Halogen equivalent bulb??
...just a thought...
-Bear- :cheers:
JPSmit
-Bear- :cheers:
and that is why my wife named mine Ms. Triss
jvandyke
jvandyke
-Bear- :cheers:
I don't know. The manager helped me. We talked about a brightness hit and he didn't suggest anything else but that doesn't mean much. I ordered the correct bulbs anyway and will keep these for some spares.
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
Rob Glasgow E10 Base LED Dash Bulbs Austin Healey 17
K TR2/3/3A LED dash bulbs again? Triumph 2
PAUL161 General MG LED Dash and Instrument Bulbs POS or NEG ground. MG 8
RAC68 Dash Lighting [cost and access of incandescent Bulbs] Austin Healey 37
charleyf TR6 Wiring harness/ dash bulbs Triumph 2
D Dash light bulbs Spridgets 7
S LED Dash Bulbs Spridgets 10
Boggsy64 MGB LED dash bulbs MG 3
T BRIGHTER DASH BULBS.......anyone have numbers Spridgets 10
O TR2/3/3A TR3 Dash Bulbs Triumph 13
K TR2/3/3A TR3 Dash lights:Conversion to green bulbs? Triumph 3
jvandyke Best dash bulbs? Spridgets 7
G TR6 TR6 original dash bulbs as bright as newer bulbs Triumph 1
2wrench TR6 Need replacement bulbs ID'd for under dash '74 TR6 Triumph 4
J dash bulbs and choke cable Triumph 6
Brosky Dash light bulbs Triumph 51
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
BoyRacer Blue Vinyl Dash Material Austin Healey 3
jfarris TR2/3/3A Dash Lights Triumph 3
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
R Ground wires under dash Spridgets 5
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
B TR4/4A Dash Color? Triumph 3
EWD TR6 TR6 top dash trim paint Triumph 2
TomMull Dash wiring Plus 2 S Lotus 16
I TR6 Dash light issues Triumph 19
J Attaching BT7 Dash Facia Panel Austin Healey 2
EWD TR6 Dash Pad Replacement Triumph 3
longbridgehealey Bugeye dash Spridgets 6
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
Basil New Dash Cover in the Telly Other Cars 3
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
steveg TR6 Metal Dash - does anyone make one? Triumph 13
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Dash repair Triumph 7
