Curious about 1966 Jaguar S-Type Saloon
karls59tr
Bronze
Hi I'm visiting from the Triumph Forum I was wondering about the desirabilty of this model Jag. I think I read somewhere where some Jag afficianadoes thought that the rear of the car with its Mk X infuences was ugly? I suppose the Mk II Jags are the ones most people want. I heard of a 66 S-Type that has been garaged for 20 years and looks complete with 134,000 on her. I was wondering what this model generally sells for when unrestored?Looks clean, no damage,2nd owner. If all it needs is freeing up the engine with some diesel, a good tuneup,go thru the SU's,clean out the tank and go thru the hydraulics(I'd stay away from redoing the leather upholstery $$$) it might be a good opportunity to own an old classic Jag for under 5K! Any thoughts or advice from the Jag enthusiasts?
Deleted member 8987
Ahhhhhh....
"S" types have their own following, for sure.
The arse end looks odd to me, but I believe it was done that way to allow boot space with the IRS.
Just a WAG.
Usually parked for 20 the leather is toast, and the wood has delaminated, but worth a look anyway.
Some think anything Jaguar is worth a bundle, but not always so, when you calculate restoration costs and resale value.
Jags do not like being parked.
Getting one to re-lite after 20 may involve more than the purchase price of the car.
And, at 138K, well, depends on the maintenance it had for tose 134K.
Seals dry out, gaskets dry out, valves stick.
Gonna take a lot of playing with the plugs out and a careful watch to make sure no valves hang open and impact the piston OR the opposing valve.
First question I would ask is "Why was it parked?"
Automatic?
Did it die?
Head gasket?
Wiring?
Something simple usually won't get them parked.
You'll need to do carbs, pump, flush tanks, calipers, master, booster, trans, engine seals and probably a head gasket.
Tyres.
Exhaust is probably a rust streak on the ground under the car.
Front and rear suspension bushes, were the ball joints and tie rod ends lubed regularly?
REALLY hard to place a value without seeing it, but a pig-in-a-poke, go low, as you really won't know what it's going to need until you get it home.
My MK2 ran, drove it the day I got it, and I am STILL un-doing 30 years of gas station maintenance, in addition to things it needed and normal wear and tear.
Complete and presentable, running, a good price, but $500 for an unknown, for me, would be tops.
There are stories in the Jag Club of going out to look at a restored Concours winner for big bucks........guy had died, wife left the car in the garage for a LONG time.
Headliner fallen down, paint shot, tyres flat, leather toast, wood delaminating, wouldn't run.....they walked away from it.
MikeP
You'll want to inspect underneath for rust damage too since in your area of the world I'd think it's early life could have included lots of all weather use.
K
karls59tr
Bronze
Thanks for the responces. You sort of brought me down to reality. Good point about not knowing why the car was parked ie. blown headgasket?...damaged valves? $6000=engine rebuild? It's a gamble. Ideally I would ask the owner if I could squirt some oil or diesel into the spark plug holes...see if could turn the motor over by the fan...run the carbs off a fuel can source...clean up the points...install a new battery and try to fire the old Jag up.That way I'd know if I had a runner or not. If the owner was reluctant to let me do this I'd have to walk away. Car was lady driven untill 1980 so I'm assuming she took it in for servicing and there should be bills and hopefully an indication from the owner of why it was parked. While there I would take a look underneath to see if the tinworm had gotten to the frame. I love those old Jag saloons but I dont need a money pit.
Platinum
On th' bright side, it'd be a money pit that rolls around. :jester:
Deleted member 8987
Before you start trying to rotate, watch the valves.
If one is hung up (as in rusted stem), you WILL impact the piston and/or the opposing valve.
That is going to get real expensive.
Apparently, there are limited/no power steering box parts available anymore.
Pump runs off the back of the generator, most folks seem to end up with an electric rack and an alternator.
All do-able, and since you have unlimited funds and tme, a great project!
That said, lots of locals have "S" types and like them.
Hopefully, minimal issues and dry storage, and you'll get a peach!
D TR2/3/3A curious tachometer take-off Triumph 5
D TR4/4A now I'm curious Triumph 7
glemon Curious Part II Spridgets 0
N Curious?? Spridgets 13
matmire Curious if these photos tell you anything about my car. Spridgets 24
M_Pied_Lourd TR2/3/3A Just a Curious TR2 Question... Triumph 3
J TR4/4A TR4A Just Curious Triumph 15
M Just curious Triumph 20
B Curious question..Engine Coolant container MG 10
5 Curious BN4 engine pic Austin Healey 3
M Curious Spridgets 42
M Just curious Oil Question Spridgets 5
Jim_Newman A Curious Hole Austin Healey 5
T Just curious - 1971 Jag XKE 6 cyl value Jaguar 13
SkinnedKnuckles Just Curious - Where are the Old Pro's Triumph 28
G Just curious while waiting on parts!! MG 30
B I'm just curious- what do these fit? Spridgets 4
wkilleffer Curious about compression check results MG 5
JPSmit Tonights curious solution Spridgets 3
AUSMHLY Curious, what is the most view topic Austin Healey 3
G Curious.... Triumph 30
JPSmit Curious ad Other British Cars 11
ronzet Curious glowing on my Tail lamps MG 28
G Just curious Rover / Land Rover 1
T Curious holes? Triumph 1
D BJ8 Interior Panels - Just Curious Austin Healey 3
G Curious.... MG 24
Gray_Cat Curious Carb "Accessory" 55 BN 1 Austin Healey 5
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 0
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J MGB 1966 MGB won't start MG 1
J MGB Just bought a 1966 MGB MG 50
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
D Is it a 1965 or a 1966 MG Midget? Spridgets 2
S 1966 Austin cab British Motor Corp 2
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
K 1966 Austin 1100 carbs? British Motor Corp 1
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
C MGB 1966 MGB windshield glass MG 4
Keoke 1966 AH BJ8 on eBay Austin Healey 18
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
M 1966 BJ8 Top Austin Healey 1
3798j General TR 1966 12 Hours of Sebring Triumph 0
1 MGB 1966 MGB hard shifting into 3rd MG 1
AHS Spitfire 1966 Spitfire with title for parts Lancaster PA NFI, $100 Triumph 3
Zimmycobra For Sale Misc. External Engine Parts - 1966 TR4A Triumph Classifieds 1
