Craigslist - Spitfire trans for RB Midgets?
aeronca65t
That trans will fit a 1500 Midget. My last trans (when I was running the 1500) was a single-rail Spit trans.
There are no Sprites that use that trans, since no Sprites had the 1500.
The seller says the trans will "Also fits 74-80 Austin Healey Sprite and MG midget". No A-H Sprites made during those years.
RickB
RickB
He lists a LOT of stuff so he's not entirely correct about everything he writes but really just search the Portland OR area Craigslist for "541-680-0641" and you will see what I mean.
What are the good points about that trans?
taskadog
You can put the Spit overdrive tranny in a 1500 Midget, Probably the best 5 speed alternative available for RB Midgets
RickB
RickB
Is there a chance that one is it?
aeronca65t
The O/D trans will fit a 1500 Midget, but only with a bit if tunnel bashing. I'm told it's a tight fit but not too hard to do.
The 1500 trans (often called the "Marina trans") is a decent unit in terms of shifting, and has syncro on all four gears.
But it's not as nice to shift as the older "ribcase" trans used in 1275 and 1098 cars. Even with a non-syncro first gear, the ribcase in nicer to use in my opinion.
The 1500 also has abysmal gear ratios (a gigantic jump from 3rd to 4th) and is not as sturdy as the ribcase.
Remember, the 1500 trans will not fit the 1275 or 1098 engine in the older A-Series cars. Completely different bell housing pattern. Also, the 1500 trans has a cast iron bell housing so it weighs a ton!
Finally, one trans that would be interesting to try to fit to a 1500 Midget would be the 5 speed TR7 trans. I'm told it has been done, but have never seen one.
bthompson
The ad doesn't say, but I'm guessing it's not an overdrive Spit trans...if it was, it would surely be a major selling point.
In fitting a Spitbox to a 1500 Midget, (I've done a bit of research here!) the non-overdrive tranny is substantially the same as the stock 1500 Midget trans, and it's a bolt-in replacement. The overdrive must be a J-type Laycock unit; any other style will NOT fit. (A J-type Laycock overdrive can't be bolted to a non-overdrive tranny, BTW; the output shafts are different lengths, and there are minor differences in the mating flanges.)
If you DO find a 1500 Spitbox with a J-type overdrive, it will take a bit of massaging to fit it in the tunnel. Since the overdrive fits smack in the path of the U-channel reinforcement under the tranny, the access hole underneath needs to be cut out towards the front, the center part of the U-channel removed, and the remaining U-channel needs to be reinforced with box section steel tubes driven inside them. Another box section tube is bolted underneath the missing length of U-channel, with trailing arms running rearward to make a new mounting point subframe for the tranny. A scissor-jack put crossways in the tunnel at the proper point will push the extra half-inch out to clear the overdrive. Then the overdrive trans just bolts right in, using the existing driveshaft.
All this is rendered largely academic, though, since the new higher diff ring gear from Moss apparently gives final ratios very close to the overdrive values; and the torque of the 1500 is enough to cope with the taller first gear. It's worlds easier to just put in a new ring gear than do all that cutting!
Boink
Bronze
That's not in Portland (though nowadays you never know with transferred cell phones). The area code is down the valley... could be Eugene or Corvallis.
PAUL161 Spitfire 75 Triumph Spitfire on Craigslist Tulsa Triumph 1
Moseso Spitfire Funny Spitfire Listing on Craigslist Triumph 6
J Spitfire nice spitfire on craigslist Triumph 4
AngliaGT Finally - A (Mostly) True craigslist Ad Other Cars 0
AngliaGT General TR Triumph Herald Being Parted Out [craigslist] Triumph 0
TRMark Craigslist 1959 Sprite Spridgets 3
LarryK TR2/3/3A Craigslist St. Louis under 1959 Austin, Jag, Triumph Triumph 2
S TR2/3/3A The hard top on Seattle craigslist Triumph 1
Sarastro TR4/4A TR4 saga continues: why does Craigslist attract so many flakes? Triumph 16
RickB MGA Looks like a nice MGA grille, $50 on Seattle Craigslist MG 1
RickB Datsun 210 5 speed dogleg on Seattle Craigslist $350 -nfi Spridgets 5
Geo Hahn TR6 Interesting TR6 on OC Craigslist Triumph 12
Sarastro T-Series Nice Mark II TD on the LA Craigslist MG 1
RickB 79 Midget on Seattle area Craigslist - nfi Spridgets 0
RickB Nice 66 Sprite on Seattle Area Craigslist -nfi Spridgets 2
Marvin Gruber BN7 on Craigslist, Nashville Austin Healey 0
Marvin Gruber TR2/3/3A TR3 on Craigslist in Birmingham, Alabama Triumph 2
RickB Nice looking RWA Seattle Craigslist [nfi] $900 Spridgets 2
Sarastro Lovely Midget on Craigslist Spridgets 10
RickB Found on Craigslist - 2 Midgets, one is RWA for $600 Spridgets 1
RickB 74 Midget $1K Seattle Craigslist [nfi] Spridgets 1
RickB 79 parts Seattle Craigslist [nfi] Spridgets 0
RickB Seattle Craigslist - Free 77 Midget Spridgets 6
BillyB62 Post-War Other '49 Triumph 2000 on Craigslist Triumph 4
TR4A_IRS General TR Calipers for Sale on Seattle Craigslist Triumph 3
RickB Seattle Craigslist - 70 Midget $1750 [nfi] Spridgets 4
RickB 64 Sprite on Craigslist $800 [NFI] Spridgets 3
RickB Seattle area Craigslist - 79 RWA[!!] for sale Spridgets 3
RickB Poor little MK2 Sprite - Seattle Craigslist 'Sebring bonnet' Spridgets 24
GlennG Post-War Other Heralds on Dallas Craigslist Triumph 1
K TR2/3/3A Odd looking modified TR3 on Craigslist...saint luis obismo Triumph 24
RickB RWA on Seattle Craigslist Spridgets 12
sjuengst 1967 BJ8 on Austin Craigslist Austin Healey 2
DanLewis Bugeye for sale on Craigslist - NFI Spridgets 6
RickB As seen on Craigslist [Seattle area] 1969 Austin Hensley [SIC] Spridgets 0
RickB 72 Midget on Craigslist $1200 - NFI Spridgets 7
LarryK TR6 72 TR6 Craigslist Triumph 1
RickB Craigslist find - nice 66 Sprite $850 Spridgets 4
B Interesting car on Craigslist [Sabra] Other British Cars 9
RickB Datsun 5 speed on Seattle craigslist Spridgets 0
RickB Craigslist find - nice 68 Sprite $650 Spridgets 2
RickB As seen on Craigslist: "MG Midget Replica" Spridgets 9
RickB Datsun 210 on Craigslist Spridgets 5
I Advice for Craigslist Triumph 11
John_Mc TR6 TR6 Hardtop on Bay Area Craigslist Triumph 0
RickB HI craigslist Spridgets 19
RickB Sprite on Seattle Craigslist [NFI] Spridgets 4
glemon Spitfire Craigslist Spit Triumph 2
justin_mercier Post-War Other 63 Herald in rough shape, MA craigslist Triumph 2
Mickey Richaud Bugeye on PA Craigslist Spridgets 1
