Cometic head gaskets
PeterK
Cometic has a TR4 CFM-20 - Perforated steel core head gasket w/elastomer coating .043" 88mm.
Is anyone using these on a street TR4?
I am looking for options for slightly modified cumbustion chambers with better sealing potential than solid copper.
Is this one of their MLS type head gasket meaning three piece metal with external grommets to hold them together, if so, yes on high compression MG race engines and they did nicely on 15.0 to 1 race engines. OH and those gaskets, like copper gasket have to be coated, I use Permatex Hitack for that.
PeterK
PeterK
No not a MLS, it's a CFM but coated. The only one they list for the TR4 btw. I don't know if they install dry like a MLS yet either.
Well if it's of any great interest to you, if they make your application in their copper version, which is also the only way they offer it for the BMC 948 engine as well, then you can special order the MLS gasket in that application, we did that very thing with the 948, If I rember correctly my buddy had to get three gasket to getthem to do it. The MLS are neat gaskets, they have three separate sheet of steel, the top and bottom are of what they call memory steel, everywhere you would have steel insert in a fiber, or copper gasker (cylinder, water jackets, oil passage, etc.) on the MLS is press to have a ridge that does the same thing as the steel inserts in the other gaskets, the bottom is the same construction, the center is a stainless steel shim, if you will, you have a choice of about 5-6 compressed thickenesses if needed. The the whole thing is held to together by 4 tabs, to on each side in all of the three sheet with a brass grommet to hold them together, you alway know a engine has a Cometic gasket if you see those 4 gormmeted tabs hand out of the block/head joint on the engine. Since they are nothing but bare steel, they definately have to be coated for assembly.
B Experience with Cometic Head Gasket for BN2? Austin Healey 8
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
F TR2/3/3A head light buckets Triumph 3
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
R Big Healey 100 Head Austin Healey 4
R For Sale 100 engine block w/head Austin Healey Classifieds 3
B Surprise screw head Restoration & Tools 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
B Head Re-Torque Austin Healey 8
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
KVH General Tech Head Gasket Sealant Triumph 4
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
KVH General Tech ARP Head Studs/Liner Protrusion Triumph 10
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
T TR2/3/3A Water pumps/head cooling Triumph 22
T TR2/3/3A cylinder head ,valves and springs Triumph 0
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
T TR2/3/3A tr3 head gasket Triumph 38
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
DrEntropy MGB Head gasket R&R goes on... MG 13
