Cobalt top entry wires question
steveg
I'm installing a Jeff Schlemmer-tweaked 22D jag distributor which is similar to the BJ8 25D and uses a later top-entry cap.
Moss is selling both the really expensive Magnecor and cheaper Cobalt wires for our cars with top entry caps. I have a 2016 catalog which shows the same Magnecor PN fitting 6 cyl Triumphs as well as our cars. The PN for the Cobalt wires was 171-665 - a search for this now leads to the expensive Magnecor set PN 143-560. 171-665 is now listed for the 68-69 MGC.
Question: would like to know if anyone has used this Cobalt set on a top-entry cap on a 6 cyl Healey. Or if anyone can verify the sets which fit 6 cyl Triumphs will also fit our cars.
ozhealey
Steve,
I have used both the cobalt (for a long time) and the new Magnecor wires. Both work well, however I prefer the Magnecor, however be careful.......
I ordered the Magnecor wires from Moss and they did not fit (too short) on my BJ7. The box said “Triumph” as you point out. Initially I was told by Moss they fit the BJ8 but not the earlier cars (noting the slightly different distributor overall length and configuration). So I tried the Moss Magnecor wires on three BJ8 cars here in Australia and they DID NOT fit any of the cars. Moss were excellent and refunded me without question.
I then went direct to Magnecor and got a set for the Austin Healey 3000 (yes they make and sell the correct set). Perhaps one day Moss will stock the Healey set to sell to Healey owners.
Just my experience.
Cheers
Tony
steveg
steveg
Steve,
Just my experience.
Cheers
Tony
Tony, thank you for the response.
I've ordered an 8 cylinder universal set from Pertronix and will build my own. Pictures to come. Ordered the 8 instead of the 6 because Pertronix for some reason doesn't include a coil wire.
RAC68
Hi Steve,
I have had a set of Magnecor wires on my BJ8 for a few years now with NO issues. I purchased them directly from Magnecor and found the set to fit well (including the Coil Wire. Since I use a standard Side Wire distributor cap, I did have to set up the wires for wire penetration. However, they have provided as secure plug firing as did my copper wiring set … but without the radio issues.
I appreciate you may want to purchase these wires from Moss because of other benefits, however, I have found my direct Magnecor purchase to be no more expensive and delivery quite fast with all the correct sizes.
Between the Magnecor wires, Crane EI and a good rotor, I have not had any ignition or pre-ignition issues since installation.
Ray(64BJ8P1)
steveg
steveg
Received my Pertronix 7mm stealth wires. Built this setup from their 8 cyl kit.
This is my Schlemmer-tweaked 22D distributor with top-entry Lucas cap. He convinced me to go back to points & condenser:
steveg
steveg
I call baloney.
Possibly. Nevertheless, here's a guy who does distributors for a living who's dead set against them. When he says he's seen a lot of problems with them over the 15,000 distributors he's done, I'm inclined to give weight to that.
My old DM6 with Pertronix 1 and metal wires worked fine as far as I could tell, though I did get a flash from the knock sensor under hard acceleration approaching 5000 rpms.
Am still going to run points/condenser for at least a while.
Reliable condensers built to original Lucas specs are available now from Distributor Doctor in UK.
See: https://www.distributordoctor.com/
Keoke
Jeff of Advanced built my 22D with them; told me he had seen a car down 40 hp with Pertronix. I basically decided to go with his setup and give it a whirl.
HE Prolly did not have his specks on that day.
DerekJ
I was always a big fan of originality and stuck to points and condenser, however in competition we could not elimate a slight fluffing an hesitation under full load. I decided to try Powerspark, which is exactly the same as Pertronix. The problem immediately disappeared and the car was also much better at idle and low revs!. If your distributor shaft is slightly worn then it will affect the points operation but Pertronix is not affected by it. Power spark is available in the UK for around ÂŁ30 so I always have a couple of spares. Unless you are absolutely wedded to originality and enjoy adjusting and replacing points then Pertronix is the way to go. I have no idea what he is talking about regarding power loss, I believe that the more efficient operation could give a small power gain.
Keoke
TO conclude this discussion I would like to submit : There is no mechanical or electromechanical device that is more reliable or improves performance over it's all electronic replacement item .
steveg
steveg
Keoke, that's an interesting observation. It sounds like a law - is there a formal name for it?
Not sure the pertronix is ultimately as reliable as the points & condenser if a good condenser is involved. Points will gradually wear down but will always get you home. Pertronix are susceptible to catastrophic failure, either from bad polarity in troubleshooting or internal failure of the coil itself, or heat from leaving the ignition switch on. I've experienced these failures. I've also experienced many years of successful use of these somewhat fragile devices.
Also, I started this discussion but you have decided to conclude it??...got a better idea - let's just leave it open.
Keoke
Well Steve:
WE would neva have gotten to da moon on a set of points they would have worn out before we got there , but chu can keep on talking about them if you like'---LOL
Keoke
dougie
Ditto for me....I've raced with both the Pertronix Ignitor and currently Ingnitor II. Jeff built my race distributor years ago base on a Lucus Jaguar D type unit. I've had issues with coils in the past and I'm currently upgrade my system with the Pertronix Flame Thrower HP coil and new Digital HP System. My new race motor willing living at 7000 rpm.
Keoke
You Fellas: Spot on Dougie---
Carlover325 Chevrolet Cobalt Other Cars 2
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
S TR6 Soft top material Triumph 10
Sarastro TR4/4A Convertible top installation problem Triumph 12
A TR6 TR 6 Soft Top Triumph 4
D BJ8 Top Installation Detail Austin Healey 3
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
B TR6 TR6 convertible top frame Triumph 0
zoohow BN4 Top Frame Installation Austin Healey 1
L Do you have a picture of these convertible top details? Spridgets 4
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
Frameman 1949 Soft Top Webbing Austin Healey 2
Overdrive45 Convertible Top Cover Fit Austin Healey 6
D Top installer recommendations NYC tri-State area Austin Healey 0
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
S For Sale FREE HARDTOP.. top is in Palm Springs, Cal. Call Bob ,562 400 5983 MG Classifieds 1
E Spitfire '69 Spitfire hard top Triumph 2
Celtic 77 MGB B-pillar repair kit for convertible top MG 1
Popeye TR4/4A Tonneau or top cover? Triumph 12
7 Top, hard Triumph 0
JPSmit Today's top tip - Rain X Restoration & Tools 3
Popeye General TR Old robbins top in box Triumph 7
KVH TR4/4A Closing the Soft Top Triumph 11
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Bayless How does '67 Sprite top attach to body? Spridgets 3
D Top Door rubber and fuzzy seal Spridgets 5
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
Donald1107 TR2/3/3A Soft top Triumph 14
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
luke44 TR2/3/3A Tr3 top - corner fastener Triumph 4
N MGB Convertible Top Frames MG 7
roscoe New / old hard top Austin Healey 16
nevets BN6 Soft Top Webbing Austin Healey 2
R BUGEYE SOFT TOP FIT Spridgets 2
AngliaGT For Sale Two Piece Top Frame - MGB '62 - '70 MG Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
M Wanted TRIUMPH TR3A Hard Top Triumph Classifieds 14
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
EWD TR6 Top Install Triumph 3
B TR2/3/3A Hard Top Part Triumph 2
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
JamesD BJ8 Top Frame Bumpers Austin Healey 12
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
S TR2/3/3A new Robbins top Triumph 11
Neil Z For Sale MG TC NORS Convertible top and Side Curtains MG Classifieds 0
