Cigarette Ash Tray?
62BT7
I'm on the verge of finishing my interior (yeah!) and need to install the ash tray in my '62 BT-7. The install is easy enough, but a simple question emerged today: Does the ash tray top/lid flip forward or backwards? I looked in the concours guidelines and another source but couldn't find anything. I know, I know...petty/trivial, but if I'm gonna install it the whole point is to do it sorta right, right? Any ideas? Many thanks,
-Tom
LEERIVAS
Member
In 1968 I was a heavy smoker (remember Lark cigarettes?) and remember the ash tray well. It seemed so small then and filled up so quickly with my butts.
As to your question, I remember the ash tray as flipping open like a BBQ top. I used my thumb to leverage it open.
I stopped smoking "cold turkey" New Year's Day 1970.
LEERIVAS said:
In 1968 I was a heavy smoker (<span style="font-weight: bold">remember Lark cigarettes?</span>) and remember the ash tray well. It seemed so small then and filled up so quickly with my butts.
I remember the "show us your Lark pack" t.v. commercials...
flips forward. :savewave:
62BT7
Perfect, many thanks. Off to install the ashtray that will never be used, at least not for ashes...
-Tom
I did the same thing about a month ago!
Shane
-Tom
It's a great place to put coins that you can never get out again...
Johnny
I would add one thing. The inner part only goes in one way! Trial fit first because if you put it in the wrong way you can't open the lid!
judow
Darth Vader - R.I.P
I was curious about my ashtray in my Healey 100. I never thought about how it worked, I just opened it without thinking so having nothing better to do, I checked it out. It opens vetically toward the engine, which I guess is forward. Then if you grasp the hole area, the second layer will open to the right (Passenger side)and you can get at that small change, extra fuses or in my case a spare gate key in case the electricity goes out. I can also remove it by just pulling up. Now that I've confused you all, just go to your Healey and play with the ashtray when you have nothing better to do. I've only one query - "Why an ashtray when I don't have a cigarette lighter?" Just wondering out loud.
roscoe
All the old Healey ads showed men smoking pipes. You could possibly light a pipe with a car cigatette lighter, but you end up with a bunch of smoking tobacco stuck to the end of the lighter, which then falls in your lap. Its been 30 years, but ask me how I know. For that matter, when did cigarette lighters first appear in cars?
judow
Darth Vader - R.I.P
"1931: Safco is established by A.G. Busch, Safco is credited with engineering the cigarette lighter plug for Ford's first automobiles." That's what I came up with for an answer to your query as to when car lighters first showed up. I googled the query. I can guess how you knew about the pipe thing.
I'm still wondering why the ash tray and no cigarette lighter. BTW I quite smoking June 16, 1991. Just for the record.
:angel:
John_Progess
When I did this I checked the pictures in my tursty books and found what appears to be cars with it installed both ways so maybe I installed mine wrong. Mine flips rearward to open the lid. I guess I can change it some day. Have a good day!
John
NutmegCT Ozone generator - cigarette smoke smell in car? Restoration & Tools 11
B TR2/3/3A Cigarette Lighter Install Triumph 7
B Cigarette lighter socket Austin Healey 15
D Cigar/cigarette lighter Spridgets 4
B MGB 78 MGB cigarette lighter..anyone have one? MG 5
DerekJ Original Cigarette Lighter Austin Healey 10
T Mounting a cigarette lighter - where? how? Austin Healey 20
TimK cigarette lighter - accessory plug Austin Healey 12
tahoe healey healey cigarette lighter Austin Healey 0
DanNagy Cigarette Lighter Triumph 15
Camshaft MGB MGB Cigarette Lighter MG 10
I TR6 TR6 cigarette lighter placement? Triumph 4
NutmegCT cigarette lighter wiring MG 13
W ash tray for a 1972 MGB, MG Classifieds 5
P For Sale MG TF Ash Frame parts for sale MG Classifieds 0
J Wanted Re: WANTED TO BUY: TRIUMPH TR3 ASH TRAY PULL KNOB Triumph Classifieds 1
T TR2/3/3A Ash tray Triumph 4
T TR 3. Bakelite ash tray front Triumph 1
SkinnedKnuckles Ash on plugs Triumph 9
O Ash wood work in a 61 Austin Princess Restoration & Tools 5
Popeye General TR Battery Tray - yes or no? Triumph 11
K Diameter of Washer Bottle Hole in Parcel Tray Austin Healey 4
D Battery Tray Size Austin Healey 1
TomMull Post-War Other Herald 13/60: I didn't get the battery tray quite right Triumph 4
Jim_Gruber Battery Tray on BE - Pop Riveted in place Spridgets 12
TR6BobNF Battery Tray Repair/Replacement Triumph 3
bugedd Removing battery tray Spridgets 3
I Pic of original Bugeye battery tray? Spridgets 9
T TR4/4A Correct front radiator tray for TR4a sway bar? Triumph 6
jvandyke battery tray rust band aide Spridgets 12
Team_Sprite Needed: Bakelite Battery tray, and two braces. Spridgets 1
B Bugeye Engine tray? Spridgets 10
G MGB coffe cup tray for MGB MG 30
