General Tech Check those brake hoses!
drooartz
Just a little reminder to check your brake hoses. I didn't know when the hoses on my new GT had last been changed, so I went in to replace them all. Fronts didn't look too bad on the outside, but you never can tell so they got replaced. Then I moved to the rear hose.
Not good!
Wound up taking a grinder and a quite a few swear words to get the rear hose off -- the nut was just not going to budge. Nothing a Dremel can't remove. Upon inspection the outside covering was cracked. Scary stuff indeed.
So check those hoses, folks. They're easy to replace, nice cheap safety insurance.
Platinum
Go Drew! They can even look FINE on the outside and fail on the I.D.
If they've been on the car for five years or you have no idea HOW long, ditch 'em and get new ones.
PAUL161
Drew, Make sure you check the flex fuel hose coming from the gas tank, I had one go bad and the pump was sucking air. Just a thought. PJ
Platinum
That too.
drooartz
drooartz
Fuel lines need a bit of attention, once the axle is out I'll have some room. Some PO put in a Facet and it's poorly mounted with some odd runs of fuel line.
Stewart
I hate to be the one to say this but if the brake hose is in that condition the much less fun to change clutch hose might not be far behind.
drooartz
drooartz
It's on my list, Stewart. Hoping to make it until fall if possible, then I can try and tackle that job. I've heard it's not all that much fun...
Stewart
It's one of those jobs where if the engine's out it's a 45 second job. With the engine in much much longer and thats without having to deal with an out of place steering shaft.
WillR
While turning on an off ramp I pressed the brake down only to get nothing all the way to the floor. Earlier that day was perfect. Good thing I had recently replaced the parking brake cable. The small brass t behind the battery box and crusted up and popped apart. Here I thought replacing all the rubber hoses had me safe. :grin:
Sarastro
The lines on my TD were pretty bad, too. This seems to be one of those things that POs often don't take care of, even though old rubber lines are a perpetual source of problems. Even stranger in my case, as the car clearly had received a full brake job--four wheels, new shoes, new wheel cylinders, even a rebuilt master cylinder.
Anyway, it's nothing a few new parts, cleaning, and paint can't fix.
blueosprey90
I track my MGA and installed steel braided lines. My rubber hoses still looked good and functioned well, but were probably about 10 years old. Cheap insurance.
busybrit
Changing the hoses isn't much fun and can be sometimes difficult if they have been on for a while or are rusted. I suspect that's why I see so many customers cars needing the hoses changed. I actually cut a new hose in half and the old nasty one to compare the bores, the new hose was about .080", while the old hose, well I managed to get a fine needle into the bore !
So change those hoses, and stay away from the stainless hoses, they cost too much and you cant tell how old they are until they fail!
www.britishcarmechanic.com
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
rick_ingram Check those splines! MG 7
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
AngliaGT In Check,VA Today Spotted 2
Rob Glasgow Check Strap Assembly Austin Healey 5
F TR2/3/3A Check strap alignment Triumph 11
T General Tech Once again, check the easy stuff Triumph 2
S Price check on TR3A valve cover Triumph Classifieds 0
Twit TR4/4A early tr4 check straps Triumph 4
F Check for matching nrs Austin Healey MK2 Austin Healey 3
Lukens For Sale Check out this tr3 project for sale... A real treasure trove Triumph Classifieds 0
V TR2/3/3A Vertical link check Triumph 2
R TR4/4A Door check straps Triumph 7
68_sprite Check the August Oprah Magazine Austin Healey 5
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
HighAltitudeTR3 TR2/3/3A Door Check Assembly Triumph 19
S Door Check Strap Austin Healey 5
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
C Rough Idle - What to check? Austin Healey 12
KVH TR4/4A Door Check Straps Triumph 11
S Overdrive Wiring Check Austin Healey 12
Michael Oritt Door check installation Austin Healey 7
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
warwick-steve Brake drum check and lubrication Austin Healey 9
Rut Sanity check! Spridgets 2
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
Mickey Richaud General Tech Always Check the Fundamentals MG 10
F Check out this new restoration diary - BT7 - very brave! Austin Healey 7
D TR2/3/3A Door check bracket? Triumph 7
C Brake issue on my 1969 XKE - what to check first? Jaguar 14
Martinld123 Compression check 1956 BN2 Austin Healey 7
M BN1 door check replacement Austin Healey 9
R Last minute check before engine install Austin Healey 26
Boink Check out some Sprite shots at the Portland ABFM... Spridgets 1
Rut TR4/4A Get out your check books! Triumph 10
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
S How to check Dwell on a MK I 3000? Austin Healey 27
K TR2/3/3A Re: TR3 Bump stops and check straps. Triumph 18
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
jlaird Check Spam folder Spridgets 3
I TR6 Got in a wreck - need some help on who to take it to and what to check Triumph 48
HealeyDave Door Check Friction Adjustment Austin Healey 12
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
sundown TR6 1973 TR6 door check straps Triumph 3
DanLewis Weber 40DCOE - Does it need a check valve in the fuel supply line? Spridgets 4
sundown TR6 Door check strap Triumph 3
