jlaird
Restored:
Stearing wheel spacer, bakealite.
Heater shutoff valve.
Heater feed tube.
Intake manafold.
Engine water intake fitting.
Engine drain valve.
Jack, jackhandle and lug wrench, preaty red.
Good engine stuff:
Cam
Timeing gears and chain, a double chain type
Rockers
Lifters
Pushrods
Block
Head
Crank shaft, standard both mains and journels
Rocker covers
Timeing cover
Engine mount plate front
Flywheel
Pressure plate
Clutch disk
Had to get new .040 over pistions and having block bored from .030 due to wear.
As my dizy vacume advance is so rusty, a fine sole on this board (Jeff, Bugeye58) is giving me one, thank you, this one seems not to work as well but have not had apart yet.
Tony has found an undamaged drivers side door.
ChrisS has donated a defroster elbo.
Anyway, not a lot of progress for three weeks, but as you all know I hurt my back and can only do a bit, but getting better fast now.
The reason I am shareing this experience is because of you guys. What a friendly place, what nice folks I have met here. I want to share my joy and appreciation of your assistance combined with our joy of the LBCs.
More as we go along.
Jack
Heater feed tube.
Intake manafold.
Engine drain valve.
Good engine stuff:
Cam
Rockers
Lifters
Pushrods
Block
Head
Rocker covers
Timeing cover
Flywheel
Pressure plate
Clutch disk
Jack
